Timer Switch Questions: Answers & Solutions
  • Thread starter Thread starter MES
    Switch Timer
The discussion revolves around the feasibility of connecting a timer to a pellet stove's control board, specifically addressing how to simulate the action of a momentary push button switch for the stove's "on" function. Participants explore various timer options, including programmable thermostats and timer relays, while considering the electrical characteristics of the stove's control circuit.
  • One participant inquires about the possibility of using a programmable timer that mimics a momentary push button switch for their pellet stove, questioning how such timers operate.
  • Another participant suggests using Allen Bradley timer relays, noting their reliability and adjustable timing features, based on their experience with similar applications.
  • A participant expresses concern about the voltage running to the switch, indicating a desire to avoid damaging electrical components while experimenting.
  • Another participant proposes testing a thermostat designed for HVAC systems to see if it can function as a momentary switch, emphasizing the need for a device that completes a circuit briefly.
  • One participant raises a potential issue with using standard thermostats, explaining that they typically maintain a closed circuit when activated, which may not align with the stove's momentary switch requirement. They suggest wiring modifications to integrate a thermostat effectively.
  • A later reply indicates willingness to try the suggested wiring approach and expresses gratitude for the advice received.
Participants do not reach a consensus on the best approach to connect a timer to the pellet stove. There are multiple competing views regarding the type of device to use and how to wire it effectively.
Participants discuss the electrical characteristics of the stove's control circuit, including the need for a holding circuit and the nature of the push button switch. There are unresolved questions regarding the specific voltage and current requirements for the components involved.
MES
I am trying to figure a way to hook up a timer to my pellet stove. The control board of the stove has an "on" button and a separate "off" button. The on button is a push button switch. My question is: is there a programmable timer that closes a circuit for a second and releases the switch like some one pushed the button? I was considering a programmable thermostat with a timer built in. Does the timer operate by completing the circuit and releasing? Or does it switch on and keep the circuit closed? Or am I way off and it is sending a small amount of electricity thru the wire and it’s not a switch. Does this project even sound possible? I don’t really want to take the stove apart if it’s not worth doing.
Allen Bradley makes excellent timer relays that you can do this with. They have many functions and even an adjustable dial with adjustable time units so you can set the timer anywhere from under a second to a couple of days. They are bulletproof. I have retro fitted many of them into use for antique elevator wye delta transfer timers. Never had a problem.
Ok thank you very much for the info. I’m going to dig a little deeper to check how much voltage is running to the switch just to get an idea what I am working with. The last thing i want to do is fry all the electrical components.
I haven't really messed with it because I have been busy but its found its way back to the top of the to do list so I am back to looking. I was thinking to use a thermostat for an hvac system that would control when the unit came on. I am going to get one and test to see how the thermostat acts like a switch. I know that i need something that completes a circuit for a brief moment. If I find one ill let you know.
the only issue that i can see with what you are trying to do is that most thermostats are held contacts, so when they're on its held closed. it sounds to me like your stove has a momentary contact PB for the 'ON'. that being said, your control circuit still needs power, so there must be a holding circuit that is bypassing the 'ON' PB.
if you want the thermostat on it, what i would do, is bypass/jumper out the 'ON' PB and install the thermostat before the holding circuit by wiring it directly after the 'OFF' PB.
PHP:
       ORIGINAL
-----------------------___-----x------___-------x-----------(holding coil)-----
                     nc 'off'  |    no 'on'     |
                                  no  'holding'
          TO THIS         |--------____--------|
         |     'thermostat'   |
----___--x   x------___-------x-----------(holding coil)-----
                  no 'holding'
           OR THIS                                    jumper
------___--------------___-----x--x---___---x---x-----------(holding coil)-----
  'thermostat'       nc 'off'  |    no 'on'     |
                                  no  'holding'
I will try this and see if it works, Thanks!
  • · Replies 38 ·
