Too much energy -- thought experiment
  • Level: High School
  • Thread starter Thread starter Martin Jediny
    Energy Fluid Generator
42 replies · 7K views
Martin Jediny
1/ Have a closed hydraulic circuit. Two columns of fluid. One hot, one cold, which are connected at the bottom and top. Let's have small heat loss and small hydrodynamic resistance to fluid flow and incompressible fluid.
I heat the lower interconnection, I cool the upper interconnection. I have constant flow, constant temperature difference.
I need a heating power P0 to heat it.
There will be a flow of liquid. The movement is caused by the different density of the liquid in the hot and cold columns. At hydrostatic head h1, I get some pressure difference that replaces the pump in the system and causes the liquid to flow.
( The above description is a common thing, also used industrially in the past, in natural circulation central heating.)
2/ If I insert a small propeller with a generator into a flowing circuit with hydrostatic head h1 and draw a small electrical power P1. I will call this flow with the inserted device a constant flow Qv (m3/s) and thus supply a constant heating power P0, when the column temperatures are kept constant.
If "n" is a real number, then n * P1 = P0
(It's not our job to build anything right now, so please let's avoid answering that "n" would be a terribly large number. With a column h1=1km high, n << 1000 000. For now, it suffices that some n exists. Let's skip the design "dimensional" issues for now, I'm asking about the principle now.)
3/ At a flow rate of Qv , at a hydrostatic head of 2 * h1 , can I draw an electrical power of 2 * P1 ?
4/ XXX
I don't ask question (4) because usually people stop talking to me. And I would love to know if I have a mistake in the definition of (1) or (2), and I would like to know the answer to my question (3)
... But whoever can answer question 3 will also know the answer to question 4.
I don't see that you defined "n" anywhere, but that probably doesn't matter. The main issue is you don't mention the heat rejection or write a full conservation of energy statement: heat rejection is lower than heat addition if you are extracting mechanical work.
Martin Jediny said:
Have a closed hydraulic circuit. Two columns of fluid. One hot, one cold, which are connected at the bottom and top. Let's have small heat loss and small hydrodynamic resistance to fluid flow and incompressible fluid ...
So what you are describing is essentially an external combustion heat engine. I think your description is closest to a closed Brayton cycle.
https://en.m.wikipedia.org/wiki/Brayton_cycle
Using an incompressible fluid is not a good idea, but other than that it is pretty standard.
The propeller is typically called a turbine.
Thank you, very good view.
(n is not really important now. it only says that the power I get from the circuit P1 is much less than I need for heating, P0. Then n=P0/P1)
Your comment is much more important. The law of conservation of energy,
If P0 is the power needed to heat the circuit, then Pcooling is the power of the cooler.
I think (but don't know) that for water, P0 = Pcooling,
as long as I approach the ideal conditions of thermal insulation and laminar flow with low friction.
But then I have the problem that if I take P1 out of the circuit, because I can slow down the fluid, the outputs Pcooling + P1 > P0.
And that's the problem.
In order to keep the equality I would have to reduce Pcooling, then Pcooling + P1 = P0, but I don't know the formula according to which the water cools down after the work is done.
The other solution to the equality is Pcooling + P1 > P0 + Pxy.
I know that in calculating P1 I consider gravity, the difference in density of the medium. But where to find the source of the additional Pxy, I have no idea.
Dale said:
So what you are describing is essentially an external combustion heat engine. I think your description is closest to a closed Brayton cycle...
I have also considered the Brayton cycle. but as you have noticed, I do not use a pump
I'm using a hydrostatic height.
Then if I take P1 out of the circuit, at hydrostatic height h1, at flow Qv and temperature 90°C and 95°C, I will need P0 for heating. (In parallel, we are solving the question whether I need Pcooling = P0 for cooling.)
(The use of a non-compressible fluid is interesting because it does not undergo adiabatic processes.)
If I keep the Qv and temperatures 90/95°C but increase the height to 2x h1, will I still need only P0 for heating ?
Can I take 2x P1 ?
Dale said:
This is false. These cycles are well understood. They don’t work this way.
Ok thank you.
Please, can you help me, how much does the temperature of the water drop when it passes through the turbine?
That is the correct conservation of energy statement, showing that there is no inequality/"too much energy". The details....well, you'd need to design the cycle. It's not a simple/single equation, you need to analyze the state of the water at every point in the cycle.
Note though that cycles like this usually use low pressure water and steam because just using the density change in liquid water gives almost zero head to drive the flow. If you insist on that, you're sifting through the rounding-error trash that is usually thrown away.
Edit: also, of course you can't simultaneously assume the water is incompressible but changes density. That's an oxymoron. And this is what I mean by "trash": youre looking for excess energy in things that are discarded with simplifying assumptions.
Martin Jediny said:
I do not use a pump
That is fine. It will just slow things down so that the power output will be reduced.
Why would a non-compressible fluid flow at all? There is a really good reason why existing engines don’t usually use incompressible fluids.
He's assuming an oxymoron: that an incompressible fluid can have variable density, so the density differences (weight difference between the water columns) would drive the flow.
I know the steam cycle very well and can design steam turbines with superheated steam and regenerative cycle. (apologies for the propeller)
I'm really interested in incompressible fluid now and I'm not going to revolutionize the energy industry. An incompressible liquid is really unsuitable for that.
Can you please advise me by how much the temperature of the water drops when it passes through the turbine? Or where does the temperature drop occur so that we have the law of conservation of energy?
We are not talking about statistical errors here, but real measurable values. admittedly small, but measurable.
Martin Jediny said:
I know the steam cycle very well and can design steam turbines with superheated steam and regenerative cycle. (apologies for the propeller)...
No. If you can design a steam cycle you can design this one too. But if you have trouble, we can help you through it(that's PF's mission). Regardless, your diagram has no numbers so we couldn't answer that even if we wanted to!
You have four states associated with the four normal processes in a thermodynamic cycle. Since it's your cycle, you pick the states and calculate the energy flows. As I said, if you get stuck we can help you through it.
If you make a self-contradictory assumption, it's an error.
...If you make a self-contradictory assumption, it's an error.
Thank you for giving me your time.
I don't have any temperature in the formula at the turbine.
Turbine power:
P1 = dp * Qv * ni
dp pressure difference inlet/outlet
Qv Flow rate (m3/s)
ni efficiency
dp = h1 * dRo *g
h1 hydrostatic head
dRo density difference between hot and cold column
g 9,81 ms-2
then if
n= P0 / P1
Then there must be a height n * h1 where n * P1 = P0 ?
Where am I wrong?
The heating of the fluid is at a higher pressure than the cooling due to hydrostatics. This means that the work done by the heating is higher than by the cooling. This is why Pcool has to be smaller than P0.
A turbine will not cool down the fluid, it will convert some mechanical energy into heat. If you assume incompressibility (due to pressure that is, heat will of course change the density) the turbine cannot have a cooling effect on the flow.
You cannot use the full dp due to difference in rho for the turbune power. Because the system has to overcome a small amount of friction as well.
If you don't include that friction it becomes a problem where you do not need any energy at all to keep the flow going (Newton's first). In that case the heating causes a force imbalance leading to indefinite acceleration, which is not realistic of course.
Martin Jediny said:
n= P0 / P1
I don't get this, first you define n = P0/P1, then by definition n*P1 = P0? Why would the height influence this relationship?
For an incompressible fluid there is no temperature drop. The efficiency of an ideal Brayton cycle is given by $$1-\frac{T_1}{T_2}=1-\left(\frac{P_1}{P_2}\right)^{(\gamma-1)/\gamma}$$ Since for an incompressible fluid ##\gamma=1## the efficiency is zero, the temperatures and pressures are equal and there is only heat transfer with no work performed.
I don't know if wiki is a good source, but it says that I need 4215 J / K / kg for cooling, while for heating I need 4165 J / K / kg , just for hydrostatic pressure for example 200bar. (https://en.wikipedia.org/wiki/Heat_capacity, April, 2024)
And flow is the same.
Martin Jediny said:
then if
n= P0 / P1
Where am I wrong?
Well you haven't connected that in any way to the first part. You didn't say anything about P0.
I'm skeptical that you know how to design a thermodynamic cycle, because you haven't even started/aren't trying. You're just pointlessly manipulating disembodied equations.
The Cp for cooling is exactly equal to the Cp for heating at the same pressure and temperature, I don't know how you got two different answers....
russ_watters said:
How did you get two different answers for the same point?
(Edit) you're assuming different temperatures and/or pressures, right? Did you specify them?
Let's create a random example. Let's say we have a continuous continuous flow of 1kg/s (Q=0.00104 m3/s (hot side)) of water in our plant. The cold water down entering the heater will have a temperature of 90°C. The water coming out of the heater will have a temperature of 95°C. The density of water in the hot column will be 961.9kg/m3 and in the cold column 965.3kg/m3. At a hydrostatic height of h1=1000m the pressure difference will be 34kPa. 10kPa I need for flow. Electric produce with turbine: 24kPa * 0,00104m3/s * 1000m *0,6 = 15W.
I have good thermal insulation and laboratory conditions throughout the height +90°C for cold column and 95°C for hot column. Zero heat flow zero heat loss.
Funding the laboratory is not a question of this thought experiment.
Heating:
5°C * 1kg / s * 4170 J /kg /K = 20850 W (by 100 bar pressure)
Cooling:
5°C * 1kg / s * 4210 J / kg /K = 21050 W (by 1 bar pressure)
For double high:
Electric produce with turbine: 30W
Heating:
5°C * 1kg / s * 4165 J /kg /K = 20825 W (by 200 bar pressure)
Cooling:
I round off my entire professional practice and use proven rules.
Now I am solving a thought experiment and questions are coming that I am trying to understand.
So now you do not want to use an incompressible fluid? You want to use water?
Martin Jediny said:
Heating:
Cooling:
[Edit] deleting while I rewrite. You changed the examples and I missed that.
I apologize if I caused confusion with an imprecise definition.
In any case, I want to use a real liquid and not water in the end result. but I don't want to complicate it now. the only problem is that the required transmission height is many times higher than for other liquids. But this is not a problem for a thought experiment.
Trying to make a cycle with an incompressible fluid is complicating things
Again, Why would a non-compressible fluid flow at all?
russ_watters said:
The heating and cooling values have to be the same otherwise you've made a mistake, and someone with professional experience with this subject matter should know this.
By this point the main flaw is pretty well established: you're picking and choosing when to consider it compressible or incompressible. Your approach is wrong: you can't use Cp * delta T here. You need to use states and subtract the enthalpies at the two states.
I guess I didn't understand what you wanted from me in the previous posts.
Yes, that was the first idea that heating and cooling are the same. Through enthalpy, it is 21.06 kJ / kg. Then I heat and cool 21.06 kW.
But if I have the same heating and cooling, then we will have to find another power source for my 15W electrics.
Martin Jediny said:
Heating:
Cooling:
What is your next step? It would be better if you gave us a diagram with all the states and processes labeled. Those two processes alone don't tell us much in isolation.
You're not giving us all the details of the cycle and making us guess. We don't like that. We can't tell if the numbers work unless we see them in the context of the rest of the cycle.
