How Do Weight Distribution and Torque Affect Scale Readings?
The discussion centers on calculating the scale readings when a 70.7 kg woman stands on a rigid board supported by two scales. The woman’s weight converts to 693.3 N, and her position on the board affects the readings on each scale. Using the moment equation n2 = d1w/d2, the user calculated n2 as 559.97 N, leading to a left scale reading of 133.33 N. However, the calculation was incorrect due to misinterpretation of distances related to the center of gravity.
  • Understanding of torque and moments in physics
  • Familiarity with weight conversion (e.g., kg to N)
  • Knowledge of equilibrium conditions in static systems
  • Ability to apply the moment arm concept in calculations
  • Review the principles of static equilibrium in physics
  • Learn about calculating moments and torque in rigid body mechanics
  • Study the concept of center of gravity and its impact on balance
  • Practice similar problems involving multiple forces and distances
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of torque and equilibrium in real-world applications.
jibjab
A 70.7 kg woman stands on a very light, rigid board that rests on a bathroom scale at each end. The total length of the board is L=2.1 m, and the woman's distance from the left of the board is 1.3 m.
What is the reading on the left scale? The right scale?
n2=d1w/d2
I converted the woman's weight to 693.3 N. For d1 I used half the length of the board, 1.05 m, and for d2, I found the distance the woman was away from the right side of the board relevant to the center of gravity on the board, which was 0.25 m. To find n2, I did
(693.3N)(1.05m)/1.3m and got 559.97 N.
I subtracted that amount from the woman's weight and got 133.33 N, which made sense since she was closer to the right side of the board, but the computer says no. Can anyone see what I'm doing wrong? I was following an example in the book.
Thank you!
She is standing on a very light board. No neglect its mass.
Let R1 and R2 are the reactions on the scales. Find the moments due to woman and R2 about R1. Hence find the distance of the woman from R1.
  • · Replies 42 ·
18K
  • · Replies 24 ·
15K
