Mentor
- 2,470
- 3,633
Still no FBD after 30 posts, so time to fix that. The vertical rod weighs 100 kg, and the wheels at the bottom have zero mass, so that rod is shown as a 100 kg mass at the rod center of mass (COM), which is 1 m above the ground. A mass M is at the same height as the COM of the rod, and 1 m to the left of the rod COM. The assembly is vertically supported by a vertical force at the bottom of the rod; that force is ##(100 + M) * 9.8## N. There is no horizontal force at the bottom of the rod because these are physics wheels - zero mass, zero friction.
The total mass is 100 + M, and the acceleration, ##a##, is unknown, so the total acceleration force is ##(100 + M) * a##. There is an equal and opposite force ##(100 + M) * a## from the car applied at point P. The FBD shows this:
Everything is in equilibrium. The total vertical force down is ##(100 + M) * 9.8## N, which is balanced by the vertical force up at the wheels. The total horizontal force due to the acceleration is balanced by the force from the car. The only unknown is the acceleration, which is calculated by taking a sum of moments about a convenient point. The two most convenient points are the COM of the 100 kg rod, and the point P where the force from the car is applied. Arbitrarily choosing to take moments about point P, the calculation is as follows:
The mass M has a moment ##M * 9.8 m/s^2 * 1 m = 9.8M## Nm. The acceleration force has a moment ##(100 + M) * a * 0.5m = 0.5 * a * (100 + M)## Nm in the opposite direction. So the final equation for a is $$9.8M - 0.5 * a * (100 + M) = 0$$
One equation with one unknown, solve for a. Alternatively, you can define the acceleration with the mass M unknown, and solve for M.
