Total internal reflection in prism
In summary: Wait a minute!Your first angle is right. I'm sorry. Your second angle is wrong. Looks like you took the 32 degree angle to be from the normal. But if you look at the diagram, it's not. The 20.5 degree angle should be from the normal to the surface, and the 32 degree angle should be from the normal to that 32 degree angle line. Do you see this? :grumpy:... Wait a minute!Your first angle is right. I'm sorry. Your second angle is wrong. Looks like you took the 32 degree angle to be from the normal. But if you look at the diagram, it
marpple
30
Light is incident normally on the short face of a 30-60-90 (degree) prism. A drop of liquid is placed on the hypotenuse of the prism.If the index of the prism is 1.68, find the maximum index that the liquid may have if the light is to be totally reflected.
sin ik = n1/n2
sin 60 = n1/1.68
n1= 1.45
it said that my answer is close enough only differ in significant figure. however, they didn't accept my answer. anyone how to solve this problem?? thanks
Your answer looks fine to me.
i was doing this problem in mastering physic..
and it turned out
"Very close. Check the rounding and number of significant figures in your final answer."
any clues about using mastering physics regarding to rounding the answer?
Since the calculation gives 1.45492..., it is possible that Mastering Physics made a rounding error and thinks it should be 1.46.
OMG..!
thanks..
it works..
mastering physics sometimes is really killing me with its rounding thingies.. :(
Good catch, RB!
You will probably not be surprised to learn that you are not the first to complain about problems with mastering physics. :yuck:
It was just a hunch.
If sin(60°)=0.8660... is rounded to 0.87, one gets 1.4616→1.46
That's where I was going to go. I wondered if the 60° was meant to be "exact" or really to only 2 sig figs (or 1 :wink:). But if that were true, then the answer should have been rounded to 1.5, which won't fly with Mastering Physics...
alright... another questions.. still regarding to internal reflection.. :)
A light ray in air strikes the right-angle prism shown in the figure (Intro 1 figure) angle B=32.0. This ray consists of two different wavelengths. When it emerges at face AB, it has been split into two different rays that diverge from each other by 8.50 degree .
Find the index of refraction of the prism for each of the two wavelengths.
so far,, what i did is...
for wavelength one...
n1 sin theta1 = n2 sin theta2
1 . sin 90 = n2 . sin 12
n2 = sin 90 / sin 12 = 4.809
for wavelength two...
1 . sin 90 = n2 sin (12+8.5)
n2 = sin 90/ sin 20.5 = 2.85
anyone knows where the mistakes are...??
thanks
This problem has nothing to do with total internal reflection, just plain old refraction. The first refraction is trivial--the rays pass straight through. You only have to worry about the second surface, where it goes from glass to air. What's the angle of incidence at that surface? What are the angles of refraction?
Yes, they (Mastering Physics) have botched this one. It's not uncommon in physics problems to give nice round figures and assume they're "exact", as they seem to have done with the prism angles here.
A commercial prism will typically have better than 0.05 degrees (and sometimes better than 0.01 degrees) tolerance. Not that introductory physics students should be expected to know that!
ahh..i thought it was total internal reflection since the ray coming in 90 degree,, but.. for total internal reflection 90 degree should be for the angle of refraction. :biggrin:
so, we don't need to consider from air to glass?
yess...yess...
blame mastering physics :wink:
Nothing to consider. The ray passes straight through (as shown in the diagram) since the angle of incidence is 0 degrees.
All the action takes place at the glass to air surface.
so, for the first wavelength
the angle of incidence is 32 degree, and the angle of refraction is 12 ??
for the second wavelength
the angle of incidence is 32 degree, and the angle of refraction is 20.5 ??
am i on the right track??
Your angles are off. Remember that the angles are measured from the normal to the surface, so you have to figure them out.
which one is not correct??
the angle of the incidence or the angle of refraction??
None of them are correct. :frown:
LOL
:biggrin:
ic,,is this because i took the normal wrongly..??
Beats me, since you didn't show your normal on the diagram. Looks like you took the angle of incidence measured from parallel to the surface instead of normal, and the angles of refraction measured from the horizontal line. :uhh:
LOL...
how did you know?? :shy:
ic,, i'll work on it :)
well, let me try again :biggrin:
the angle of incidence is 58 degree, and the angle of refraction is 70 ??
the angle of incidence is 58 degree, and the angle of refraction is 78.5 ??
Now you're cooking. :cool: :approve:
noooo...
it's still wrong :cry:
What values did you get?
n1 = 0.902 and n2 = 0.865
Show how you got those values. (Don't confuse the two indices of refraction when applying Snell's law.)
for the first wavelength..
na sin 58 = n1 sin 70
n1 = (sin 58 . 1 ) / sin 70 = 0.902
for the scond wavelength...
na sin 58 = n2 sin 78.5
n2 = (sin 58 . 1 ) / sin 78.5 = 0.865
actually, I'm not so sure about which one is the first wave and which one is the second.
so, here i assumed, one with 12 degree angle to the horizontal line as the first wave
You have things backwards. It should be:
[tex]n_{prism}\sin\theta_i = n_{air}\sin\theta_r[/tex]
It doesn't matter which is first or second, since Snell's law is symmetric:
[tex]n_1\sin\theta_1 = n_2\sin\theta_2[/tex]
What does matter is that you have the index of refraction matched with the correct angle. :wink:
In this case, the ray is going from prism to air, so the prism angle is the angle of incidence.
omg..i'm still thinking that it goes from air to prism.. LOL
1. What is total internal reflection in a prism?
Total internal reflection in a prism occurs when a light ray traveling through a denser medium (such as glass) strikes the surface of a less dense medium (such as air) at an angle greater than the critical angle. This causes the light to be completely reflected back into the denser medium, rather than passing through the surface.
2. How does total internal reflection work in a prism?
In a prism, light enters one of its faces at an angle smaller than the critical angle. It then reflects off the opposite face at an angle greater than the critical angle, causing total internal reflection. This allows the light to travel through the prism and create a spectrum of colors.
3. What is the critical angle for total internal reflection in a prism?
The critical angle for total internal reflection in a prism depends on the indices of refraction of the two materials it is made of. It can be calculated using the formula sin θc = n2/n1, where θc is the critical angle, n1 is the index of refraction of the denser medium, and n2 is the index of refraction of the less dense medium.
4. What are some real-life applications of total internal reflection in prisms?
Total internal reflection in prisms is used in a variety of applications, such as in binoculars and periscopes to change the direction of light, in fiber optics for communication and data transmission, and in optical devices like cameras and projectors to manipulate light. It is also used in certain types of microscopes and telescopes to create magnified images.
5. Can total internal reflection occur in any material?
No, total internal reflection can only occur when light travels from a denser medium to a less dense medium. This is because the critical angle is dependent on the difference in indices of refraction between the two materials. If the indices of refraction are too similar, the critical angle will be too small and total internal reflection will not occur.
