Total Number of Possible Combinations
  • Context: High School
  • Thread starter Thread starter tostenson
    Combinations
The discussion revolves around calculating the total number of possible combinations of hot dog options, specifically focusing on the number of sausage types and toppings available at a hotdog restaurant. The scope includes mathematical reasoning and combinatorial analysis.
  • One participant asks for clarification on whether all types of meat and toppings can be combined freely.
  • Another participant suggests that the total number of combinations, including all options, is 2^66, implying a formulaic approach to the problem.
  • A participant explains that with 65 toppings, there are 2^65 combinations of toppings, ranging from no toppings to all toppings included.
  • It is proposed that if each sausage type can be paired with any combination of toppings, the total combinations would be 10 (sausage types) multiplied by 2^65 (topping combinations), plus an option for no sausage.
  • Participants discuss the implications of including or excluding certain options, such as the possibility of not having a sausage or toppings at all.
Participants express differing views on the correct formula for calculating combinations, with some proposing 2^66 while others refine the calculation to consider the specific constraints of the problem. No consensus is reached on the final number of combinations.
There are assumptions about the ability to combine toppings and sausages freely, and the discussion does not resolve whether multiple sausages can be included in a single hot dog.
tostenson
Hello, I am a graphic designer working on a menu for a friend of mine and math was never my strong suit. Also, add the fact that I've been out of school for some time and don't do math regularly. Anyway, I have a pretty simple question that I could use some help with if someone doesn't mind.
I'm wanting to add a "total number of possible combinations" to his menu, since he has quite a few options.
So here's my query:
He has 10 types of meat
He has 65 different types of toppings
How many different combinations can he make out of all these items?
Thanks in advance for the help :)
Can you narrow the problem down some? Would it be possible to order a pizza (I assume that's what you're talking about) with all 10 types of meat and all 65 types of toppings? Or are there limits on the numbers of types of meat and toppings?
If you are wanting to brag about the large number of possible topping choices available, you answer is 275 = 37778931862957161709568. This allows the choices of "everything" or nothing and everything in between.
Sure to help narrow it down, he has a hotdog restaurant, which has 10 types of sausage choices and 65 different toppings. Though, I think LCKurtz nailed my question. The point was to say "you can choose from ___ different flavor combinations". Thanks :)
But I'm guessing that you can't order a hot dog with, say, four hot dogs on it, so you won't get all of the combinations that LCKurtz listed.
You're right Mark. So the formula would be 2 to the 66th power then?
I think so.
Dr. Seafood said:
I think so.
I don't think so. Let's work with the toppings first. Since there are 65 of them, and anyone of them could be included, there are 265 different combinations of the toppings. In case that's not clear, let's suppose there is just one topping, and it is either put on or not. That's two combinations for the one topping, which happens to be 21.
Now let's suppose there are two toppings, A and B. The different combinations are:
(no topping)
A
B
A and B
That makes four combinations for the two toppings, which happens to be 22.
In general, if there are n toppings, there will be 2n combinations of the toppings. For the 65 toppings, this means there are 265 possible combinations. This runs the gamut from no toppings at all, all the way to all 65 of them being on the hot dog, as well as every intermediate possibility.
OK, now let's figure out the combinations with a sausage included. Since there are 10 different sausages, and we are assuming that a hot dog won't have more than one sausage, for each choice of sausage there are 265 ways we can top it. That makes 10 * 265 different hot dog combinations.
If we also include the possibility that some doesn't want the sausage included, that makes 11 * 265 different combinations, one of which would be a hot dog with no sausage, and no toppings. IOW, just a bun.
  • · Replies 20 ·
  • · Replies 18 ·
