Total voltage, current and resistance
This discussion focuses on calculating voltage and current in resistors configured in series and parallel. To determine the total current in a circuit, first calculate the total resistance using Ohm's Law (V = IR) and the configuration of the resistors. In series circuits, the current remains constant, while in parallel circuits, the current divides among the branches. Understanding these principles allows for accurate voltage calculations across individual resistors.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of resistor configurations: series and parallel
  • Familiarity with Kirchhoff's Laws
  • Ability to calculate total resistance in circuits
  • Study examples of calculating total resistance in series and parallel circuits
  • Practice applying Ohm's Law to various circuit problems
  • Learn about Kirchhoff's Current and Voltage Laws
  • Explore the use of volt-ohm-ammeters for measuring voltage and current
Electronics students, electrical engineers, and anyone seeking to deepen their understanding of circuit analysis and resistor behavior in electrical circuits.
Lavace
I'm having problems understanding the voltage and current in resistors.
Basically, when resistors are placed in parrallel or series, how are you meant to work out the current and voltage running in each?
I was under the assumption you find the total current running in the circuit (when given V and the total resistance of the resistors in series or parralel, usually being you have to calculate the total resistance cause they're usually in parrallel).
Then you use this current to calculate the voltage running through it.
Or is it the other way round? I'm clueless on this!
Any help would be oh so perfect!
Cheers!
Yes. First calculate the total (resulting) resistance of all resistors together. You can (usually) do this when the resistors are in parrallel, series or a combination of both (do you know how?).
Assuming you know the voltage of the source, you can then calculate the total current through the circuit using ohm's law, V = IR.
An important 'detail' now is that the current through resistors in series will be equal, while the current over resistors in parrallel will not. (The current splits up between the two paths).
Once you know the current you can then use ohm's law again for each resistor R separately to find the voltage over that resistor.
Just apply Ohm and Kirchoff's Laws or use a volt-ohm-ammeter and measure them.
I recommend going through examples in your textbook on these types of problems (applications of Ohm's Law). Start with the easy ones and work your way to more challenging ones. As you practice these, the answer to your question will become clear.
  • · Replies 60 ·
10K
