Tension and Angle Analysis for Traction in a Broken Leg
The discussion focuses on the analysis of tension and angles in a traction setup for a patient with a broken leg. The mass of the boot and foot is 4.0 kg, while a 6.0 kg mass is used to create tension in the rope. The calculated tension in the rope is 58.8 N, and the proper angle θ for the upper rope is determined to be approximately 67.8°. The net traction force acting on the leg is calculated to be 79 N.
  • Understanding of Newton's laws of motion
  • Basic knowledge of trigonometric functions (sine and cosine)
  • Ability to perform calculations involving weight (w = mg)
  • Familiarity with forces acting on objects in equilibrium
  • Study the application of Newton's laws in static equilibrium problems
  • Learn about vector decomposition in physics
  • Explore advanced trigonometric applications in physics
  • Investigate the principles of traction and its medical applications
Students studying physics, particularly those focusing on mechanics, as well as healthcare professionals involved in patient care and rehabilitation involving traction methods.
defaultusername
An accident victim with a broken leg is being placed in traction. The patient wears a special boot with a pulley attached to the sole. The foot and boot together have a mass of m = 4.0 kg, and the doctor has decided to hang a 6.0 kg mass from the rope. The boot is held suspended by the ropes, as shown in the image, and does not touch the bed.
a) Determine the amount of tension in the rope by using Newton's laws to analyze the hanging mass.
b) The net traction force needs to pull straight out on the leg. What is the proper angle θ for the upper rope?
c) What is the net traction force pulling on the leg?
I have seen other people post this problem with different circumstances/variables, however, when I plug in my variables and try to make it work for my given problem I am finding myself stuck.
w=mg
a)[/B] Find the tension on the rope:
w = mg
= (6.0 kg)(9.8 [gravity])
w = 58.8 N (rounded to 59N) tension on the rope
b) Find the proper angle for the upper rope:
First I try to find the amount of force on the boot. using the same equation
w = mg
= (4.0kg)(9.8)
= 39.2 N of force acting on the boot
Then I take the sine to find the correct angle, right? So,
58.8 sin(θ) = 39.2 + 58.8 sin(15°)
θ = 54.42°
But I know that is incorrect. My book says that it's actually 67.8°. How? What am I doing wrong?
c) I can't even get to this point without answering (b).
w = mg
= (4.0kg)(9.8)
θ = 54.42°
----additional calculations----
58.8sin(θ) = 54.42°
sin(θ) = 54.42 / 58.8
sin(θ) = 0.9255
sin-1(0.9255) = 67.74°
That is close to 67.8°...but I am not sure if I did it correctly or not.
From there:
c) Tcos(15°)+Tcos(67.7°) = 1.345382
= (1.345382)(58.8°)
= 79.12N (rounded to 79N) net traction force pulling on the leg
I am shooting in the dark here and am not sure if I am even doing it correctly. Thanks in advance
defaultusername said:
θ = 54.42°
I think you mean 58.8 sin(θ)=54.42.
You answer in part c looks ok, but you are a bit careless in writing out your steps. The net force is 1.345382T, not just 1.345382, and the 58.8 is Newtons, not degrees.
w = mg
= (4.0kg)(9.8)
θ = 54.42°
58.8sin(θ) = 54.42°
sin(θ) = 0.9255
From there:
= (1.345382)(58.8°)
You did indeed do it right, and you helped me much. Although it was difficult to decypher exactly what you were doing. Your algebra wasnt clear. Thank you a lot. You helped me much.
  • · Replies 18 ·
16K
31K
