Tire Torque & Traction Force: Sprocket Attached to Rear Axel
The discussion focuses on the relationship between torque at the sprocket and tire in a rigidly attached rear axle system. It establishes that while the torque at the sprocket and tire can be equal when the system is not accelerating, the forces exerted differ due to the varying radii of the sprocket and tire. The equation T_{tire} = T_{sprocket} - I\alpha is highlighted, emphasizing the role of the wheel's moment of inertia and angular acceleration. Additionally, it notes that power remains constant, but losses can occur between the sprocket and wheel, affecting the actual torque transmitted.
  • Understanding of torque and its relationship with force and radius
  • Familiarity with angular momentum and rotational motion principles
  • Knowledge of moment of inertia in mechanical systems
  • Basic concepts of power transmission in mechanical systems
  • Study the principles of torque in mechanical systems, focusing on torque = force * radius
  • Learn about moment of inertia and its impact on rotational dynamics
  • Research power transmission losses in mechanical systems, including bearing and joint losses
  • Explore the effects of acceleration on torque distribution in rigidly connected systems
Mechanical engineers, automotive technicians, and anyone involved in the design or analysis of drivetrain systems will benefit from this discussion.
Aashish sarode
my sprocket is rigidly attached to rear axel ,is there any difference in torque at sprocket and tire?
What do you get if you apply an angular momentum balance to the wheel?
will you please elaborate your question?
Or more basically, suppose you have some torque at the sprocket. Would you have to exert more or less rotating force at the tire to create that same torque at the sprocket? Remember that torque = force times radius.
less bcz torque =force*radius and in this case sprocket radius is less than that of wheels
The sprocket torque minus the tire torque is equal to the wheel moment of inertia times the angular acceleration of the wheel. If the bike is not accelerating, then the sprocket torque is equal to the wheel torque. (I assume that by sprocket torque, you are referring to the torque applied by the chain to the sprocket).
Exactly. The farther you get from the center of rotation the less the torque. So the torque at the sprocket is not the same as the torque at the tire.
If the car isn't accelerating, it sure is the same. The moments (torques) must balance. Just take the wheel and attached sprocket as a free body.
Where I is the inertia of the sprocket-axle-wheel-tire assembly and \alpha is the rotational acceleration of the assembly.
If there is no acceleration (\alpha = 0), then the tire torque is exactly the same as the sprocket torque. Otherwise, in typical assembly, the inertia should be small enough to consider that they are both practically the same as well (although, not necessarily a negligible difference).
The torque is absolutely the same. The force, however, is not, since as you pointed out earlier, torque is force multiplied by radius.
Chestermiller said:
The sprocket torque minus the tire torque is equal to the wheel not accelerating, then the sprocket torque is equal to the wheel torque. (I assume that by sprocket torque, you are referring to the torque applied by the chain to the sprocket).
power=torque*angular velocity , since p
hmm ,power remains constant i.e power =torque *angular velocity ,angular velocity for sprocket and wheel is same so torque nust be equal. Thank u all.
That is not always true, there can be losses between the sprocket and the wheel; friction at a bearing, losses through a CV joint, a dragging brake pad etc etc. Power still remains constant but not all of it makes it to the wheel:
Psprocket ≠ PWheel
Psprocket = PWheel + Pbearing losses PCV losses + Pany other losses
Whether these losses are small enough to be ignored depends on your system.
  • · Replies 30 ·
