Transformer questions - primary, secondary, gaaaah
  • Thread starter Thread starter sutekilady
    Transformer
The discussion centers on calculating the secondary voltage of a step-up transformer with 100 turns in the primary and 200 turns in the secondary, given a primary voltage of 100 V ± 2%. The correct secondary voltage is determined to be 200 V ± 4 V, as the uncertainty in the secondary voltage is derived from the primary voltage's uncertainty. The participant incorrectly selected an answer that included an additional percentage uncertainty, which was not applicable in this case.
  • Understanding of transformer equations, specifically Vs/Vp = Ns/Np
  • Knowledge of voltage and turn ratio in transformers
  • Familiarity with percentage uncertainty calculations
  • Basic electrical engineering principles related to AC circuits
  • Study transformer operation and applications in electrical engineering
  • Learn about calculating voltage ratios in transformers
  • Research methods for determining uncertainty in electrical measurements
  • Explore practical examples of step-up and step-down transformers
Students studying electrical engineering, educators teaching transformer concepts, and professionals working with AC power systems.
sutekilady
Transformer questions - primary, secondary, gaaaah!
Hello, I really need help with this. Much appreciated! Thank you so much in advance for any help!
A step-up transformer has exactly 100 turns in the primary and exactly 200 turns in the secondary. If the voltage in the primary is 100 V ± 2 %, what is the voltage in the secondary?
a. 200 V ± 4 V
b. 200 V ± 4 %
c. none of the other answers
d. 100 V ± 4 %
e. 200 V ± 2 V
Vs/Vp=Ns/Np
OK now here, I know the voltage should be 200V. But the uncertainty ... ? I really don't know where to even begin with that. I chose answer b. 200 V ± 4 %, and it was wrong.
Thank you!
There is no more uncertainty introduced in the secondary voltage, so it is still +/- 2%. To trick you, they omitted this selection and instead put the real value of 2% which is just 2% of 200 (4 volts)
