Transforming a Non-Linear DE into Bernoulli's Form
  • Thread starter Thread starter fluidistic
    First order Linear
17 replies · 4K views
fluidistic
Solve the following DE: [itex]2xyy'=4x^2+3y^2[/itex].
Bernoulli's DE: [itex]y'+P(x)y=Q(x)y^2[/itex].
I know that the original DE isn't under Bernoulli's form, but I have thought a lot on the problem and my feeling is that if I could find a change of variable to transform the general DE into a Bernoulli's equation, I'd be done. I have tried [itex]z=4x^2+3y^2[/itex], so [itex]z'=8x+6yy'[/itex] but this leads me nowhere. I am not even sure I can reduce the original DE into a Bernoulli's equation. This is the only way I think I could solve the DE, I don't see any other way.
I'd love some help.
Divide both sides by x^2
Don't you think this should be homogenous ODE instead of Bernoulli? :smile:
Okay thanks guys. I divided by x² but was stuck right away.
I checked out if it was homogeneous and indeed it was homogeneous of first order. I then opened my cookbook for DE's (Boas, 2nd edition) and followed his advice. I wrote the DE under the form [itex]P(x,y)dx+Q(x,y)dy=0[/itex], with [itex]P(x,y)=-4x^2-3y^2[/itex] and [itex]Q(x,y)=2xy[/itex]. He says I can write the DE under the form [itex]y'=f(y/x)[/itex].
And thus the change of variable [itex]v=y/x[/itex] is appropriate, according to him. The DE should then be separable. However I tried but got stuck.
I reach [itex]2x^3vdv+2x^2v^2dx-4x^2-3[x^2(dv)^2+xvdvdx+v^2(dx)^2]=0[/itex]. I don't know how to deal with the squared differentials nor the crossed ones (dxdv).
Any further help will also be appreciated. :)
You should not have squared differentials. If you are using the substitution v = y/x , presumably to replace the y , then you need to differentiate implicitly y = vx to find dy/dx in terms of dv/dx . You should be able to use this to replace y' with v' (and also y/x with v ) to produce a transformed differential equation that is easier to work with. (The result isn't pretty, but it is separable and integrable...)
Just to give you a little hint:
[tex]2xyy'=4x^{2}+3y^{2}[/tex]
divide by 2xy throughout:
[tex]y'=2(x/y)+3(y/x)[/tex]
Let v=y/x ,
dv/dx = ?
Thanks once again guys!
[itex]y=xv \Rightarrow \frac{dy}{dx}=v+x \frac{dv}{dx}[/itex].
Thus the original DE transforms into [itex]v+x\frac{dv}{dx}=2v+\frac{3}{2v}\Rightarrow \frac{xdv}{dx}=v+\frac{3}{2v} \Rightarrow \frac{dx}{x}=\left ( v+\frac{3}{2v} \right ) ^{-1}dv[/itex]. Now I must integrate to get v(x). Once I have v(x) I divide it by x in order to get y(x).
Let v=y/x ,
dv/dx = ?
I tried this way too but strangely I don't get "nice" stuff. [itex]dv/dx= \frac{1}{x^2} \left ( \frac{xdy}{dx}-y \right )[/itex]. If I isolate dy/dx, I don't even reach the one I got from the above way. All this, despite that y=xv in the first case and v=y/x in the second case. I don't understand how I can reach a different differential for dy/dx...
OK, so far. (And, yes, icystrike has a small typo in the resulting equation. The "3" should be "3/2"...)
You shouldn't still have that "y" kicking around in there. (I thought you were going from icystrike's equation, so this is a little puzzling. You should again have [itex]v + x\frac{dv}{dx} = 2v + \frac{3}{2v}[/itex].)
As I said above, the result isn't going to be very pretty. (Solutions of DEs often aren't...) You would reduce your transformed equation to [itex]\frac{dx}{x} = ( \frac{2v}{2v^{2} + 3} ) dv[/itex] and integrate from there.
Thank you again for your help.
Ah I see.
Well I used the derivative of the quotient y(x)/x. It's [y'(x)x-y(x)]/x²
I see. I think you have a small typo in the right hand side (I think you forgot a ^-1).
I already added the ratios and "flipped over" the result from your differential equation result for v : [itex]( v+\frac{3}{2v} ) ^{-1} = \frac{2v}{2v^{2} + 3}[/itex] .
Ah right I see now!
Do you have an idea what's my problem using icystrike's suggestion? Why can't I get rid of the y term and I don't reach the same expression for dv/dx.
fluidistic said:
Ah right I see now!
To be frank, I am still trying to figure out how you arrived at your result. The intent of icystrike's suggestion was to use v = y/x to completely eliminate y from the equation; you use Bernoulli's (whichever of the nine of them it was) idea to transform the original differential equation into a new one involving v and x that (hopefully) is easier to solve.
By making only a partial substitution, you created a situation that is harder to resolve algebraically than it needs to be. (It can probably be solved from there, but less easily. You would get rid of the y term by using y = vx .)
The equation contains y2 and 2yy'=(y2)', this suggest the substitution z=y2. With this substitution, the equation becomes linear.
ehild
Icystricke asked me dv/dx rather than dy/dx in function of dv/dx.
What I did for his way is [itex]v=y/x \Rightarrow \frac{dv}{dx}= \left ( \frac{xdy}{dx} -y \right ) \frac{1}{x^2}[/itex].
WOW! This work too! After isolating dy/dx and replacing y/x by v, I reach exactly the same expression for dy/dx than you. Nice!
Thanks guys for all your help. :biggrin:Edit: Okay thanks a lot ehild. I'm going to try this tomorrow (it's past 2 am here).
Then you live far to west from me. :smile:
Just to be able to check your derivation: it should be very easy, and results in y2=cx3-4x2.
ehild
ehild
Thank you -- that's good spotting and the result for y is faster to extract than it is to do so from v . (I assumed from the initial post that it was required to use Bernoulli's method.)
Yes TS should try this method too. That is a direct consequence of implicit diff.
Thanks. So I reached the same solution as yours. Problem solved. :smile:
