Transition from Poisson brackets to commutors?
In summary, the conversation discusses the rigorous proof of the transition from Poisson brackets to commutator relations in quantum mechanics. It is stated that the rule for this transition can be viewed as a postulate and that the proof is experimental, with physical predictions agreeing with experiments. The possibility of proving the reverse direction is also mentioned. One participant offers to show how to do it, and provides a lengthy explanation involving matrix elements, Fourier amplitudes, and the semiclassical limit. The conversation concludes with the statement that this is a gap in knowledge for many people.
dantypas
Hi to everyone.
I am a new member in this forum. I was wondering if there is a rigorous proof
on to how one passes from Poisson brackets to commutor relations in QM. Any help on that would be appreciated.
As far as I know, the rule that you can make the transition from CM to QM by replacing Poission brackets with commutators can be viewed as a postulate, from which you can derive QM (maybe with additional assumptions/postulates, I'm not very familiar with this). The "proof" is experimental, that is, the physical predictions of QM agree with experiment, at least to date.
Or are you looking to go the other way, from QM as derived from other postulates to the fact that commutators correspond to Poisson brackets in CM?
dantypas,
In principle, it should be possible to proof it in the reverse direction.
In the limit hbar->0 , the operators & commutators formalism should translate in Poisson brackets.
It is well known that the Schrödinger equation can lead to the classical least action principle of CM and the Lagragian formulation. This simple fact garantees that the proof will work. However, I have never seen a proof QM->CM focusing on the {} formulation.
Michel
I can show you how to do it, if you want to.
sam
dantypas said:
Hi to everyone.
Hi, it is rather well known that there is no unique way to do this: the troubles being collectively named as normal ordering problems and anomalies. Usually one chooses x,p as basic variables, quantizes the corresponding poisson brackets (which comes down to working in the Schrodinger representation) and builds up the representation from there.
samalkhaiat said:
sam
Yes I am interrested.
If possible, give us just a hint about how to do it.
Would it start by the evoluation of the density operator?
A good opportunity to fill a gap for me,
Michel
It is lengthy and requires some tricks.
NO, it is rather general. Here we go;
take the matrix element of commutator of two arbitrary operators in the coordinate representation;
[tex]\left[a,b\right]_{xx'} = \int dx'' [a(x,x'')b(x'',x') - b(x,x'')a(x'',x')][/tex]
change the arguments of all matrix elements as follow;
[tex]a(x,x'') = a\left( \frac{x+x''}{2}, x-x'' \right)[/tex]
[tex]b(x'',x') = b\left( \frac{x''+x'}{2}, x''-x' \right)[/tex]
etc.
now, expand the RH-sides in terms of momentum eigenfunctions;
[tex]a(x,x'') = \frac{1}{2\pi \hbar} \int dp e^{ip(x-x'')/ \hbar} a\left[ \frac{x+x''}{2} ,p\right][/tex]
[tex]b(x'',x') = \frac{1}{2\pi \hbar} \int dp' e^{ip'(x''-x')/ \hbar} b\left[ \frac{x''+x'}{2} ,p'\right][/tex]
In the semiclassical limit we take the differences between the coordinates to be small (wave packets).
Thus, we expand all Fourier amplitudes on the RHS in power series in
[tex]\delta x = x - x''[/tex] and [tex]\delta x'' = x'' - x'[/tex]
keeping linear terms;
[tex]a(x,x'') = \frac{1}{2\pi \hbar} \int dp e^{ip\delta x/ \hbar} \left[ a(x,p) + \frac{1}{2} \delta x \partial_{x}a(x,p) + .. \right][/tex]
[tex]b(x'',x') = \frac{1}{2\pi \hbar} \int dp' e^{ip'\delta x''/ \hbar} \left[ b(x',p') - \frac{1}{2} \delta x'' \partial_{x'}b(x',p') + .. \right][/tex]
(note that these equations give the (semi)classical limit
[tex]x'' \rightarrow x[/tex]
of any matrix element:
[tex]c(x' \rightarrow x) = \frac{1}{2\pi \hbar} \int dp e^{ip(x-x')/ \hbar} c(x,p)[/tex]
later we use this for c = [ , ])
Let us go back and integrate the linear terms by parts
[tex]a(x,x'') = \frac{1}{2\pi \hbar} \int dp e^{ip\delta x/ \hbar} \left[ a(x,p) - \frac{\hbar}{2i} \partial_{x}\partial_{p}a(x,p) + O(\hbar^2) \right][/tex]
[tex]b(x'',x') = \frac{1}{2\pi \hbar} \int dp' e^{ip'\delta x''/ \hbar} \left[ b(x',p') + \frac{\hbar}{2i} \partial_{x'}\partial_{p'}b(x',p') + O(\hbar^2) \right][/tex]
Now, take a coffee break, then substitute these and other expansions of the matrix elements into the commutator and use the properties of Dirac's delta
[tex]\left[\hat{a},\hat{b}\right]_{xx'} = \frac{1}{2\pi \hbar} \int dp e^{ip(x-x')/ \hbar} \left[a(x,p)b(x',p) - a(x',p)b(x,p)
- \frac{\hbar}{2i} \left( b(x',p)\partial_{x}\partial_{p}a - a(x,p)\partial_{x'}\partial_{p}b + b(x,p)\partial_{x'}\partial_{p}a - a(x',p)\partial_{x}\partial_{p}b \right) \right][/tex]
Now we integrate by parts all the terms in (...) and pass to the limit by putting [tex]x' \rightarrow x[/tex] everywhere except the exponential.
For example:
[tex] \int dp e^{ip(x-x')/ \hbar} \partial_{x}\partial_{p}ab(x',p) \rightarrow - \int dp e^{ip(x-x')/ \hbar} \partial_{x}a \partial_{p}b[/tex]
Thus the commutator in the semiclassical limit
[tex]\left[\hat{a},\hat{b}\right]_{x'\rightarrow x} = \frac{1}{2\pi \hbar} \int dp e^{ip(x-x')/ \hbar} \frac{\hbar}{i} [\partial_{p}a\partial_{x}b - \partial_{x}a\partial_{p}b][/tex]
We almost there.Now the semi-classical limit of any matrix element
[tex][\hat{a},\hat{b}]_{x'\rightarrow x} = \frac{1}{2\pi \hbar} \int dp e^{ip(x-x')/ \hbar} \left{[\hat{a},\hat{b}](x,p) + O(\hbar^{2}) \right}[/tex]
By comparing Fourier amplitudes in the above two equations you get it
[tex] Lim_{\hbar \rightarrow 0} \frac{i}{\hbar} [a,b] = [a,b]_{PB}[/tex]
It is a gap in all textbooks.
regards
sam
Thanks a lot samalkhaiat.
Quite a hard Latex job!
Where did you learn about this?
With my best regards,
Michel
Playing with equations is my game.
regards
sam
1. What are Poisson brackets and commutators?
Poisson brackets and commutators are mathematical operators used in classical mechanics and quantum mechanics, respectively. They are used to describe the relationship between two physical quantities, such as position and momentum or angular momentum and energy.
2. How do Poisson brackets and commutators differ?
The main difference between Poisson brackets and commutators is their application in classical and quantum mechanics, respectively. While Poisson brackets are used to describe the evolution of physical quantities in classical mechanics, commutators are used to calculate the uncertainty in measurements of physical quantities in quantum mechanics.
3. What is the transition from Poisson brackets to commutators?
The transition from Poisson brackets to commutators occurs when moving from classical mechanics to quantum mechanics. Poisson brackets are replaced by commutators as the operators used to calculate the uncertainty in measurements of physical quantities. This transition is necessary due to the fundamentally different nature of classical and quantum systems.
4. Why is the transition from Poisson brackets to commutators important?
The transition from Poisson brackets to commutators is important because it allows for the description of physical systems at a quantum level. Classical mechanics is unable to fully explain phenomena at the atomic and subatomic level, so the use of commutators is necessary to accurately describe and predict the behavior of quantum systems.
5. How are Poisson brackets and commutators related?
Poisson brackets and commutators are related through the fundamental principles of classical and quantum mechanics. While they have different applications, both operators are used to describe the relationship between physical quantities and their evolution over time. In this way, they provide a bridge between the two branches of physics.
  • Classical Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
