Transverse Oscillation of horizontal Mass-Springs system
The discussion revolves around the transverse oscillation of a mass-spring system, where a mass is supported on a smooth table and connected to two fixed blocks via springs. The problem involves analyzing the restoring force when the mass is displaced transversely, with a focus on deriving the relationship between the displacement and the restoring force.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the equations governing the restoring force and question the role of various variables, particularly the meaning of the extension variable x. There is discussion on how to approach the approximation for small displacements and the implications of these approximations on the equations derived.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the consistency of variable definitions and the nature of approximations in the context of small displacements. There is an ongoing exploration of how to simplify the equations to arrive at the desired form of the restoring force.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. The discussion includes considerations of small displacements and the assumptions that can be made in this context.
omegasquared
Mass M is supported by a smooth table and connected by two light horizontal springs to two fixed blocks. Each spring is of natural length L. Both springs are initially extended by L to get a total width between blocks of 4L. The spring constant of both springs is k.
When the mass is given a small transverse displacement, y, show that the restoring force is approximately ky.
See photo below:
F = kx
sinθ = o/h[/B]
Restoring force, Fr = 2kxsinθ
sinθ = y / (2L + x)
x = (y / sinθ) - 2L
First you should draw a diagram showing a small transverse displacement y of the ball, and draw a coordinate system. Then write your equations. For example, I don't understand why there is an x in your equations at all.
The x is to do with the extension of the spring which will occur when you displace the ball by y upwards.
sinθ = y / (2L + x)
Are you being consistent about the meaning of x? Is it the total extension of the spring, or the additional extension beyond its extension when y=0?
Additional extension beyond what it was (L) at y=0.
Then reconsider your equation for Fr.
Ah, good point.
So it should be: Fr = 2k(L+x)sinθ
Which would then be: = 2ky(L+x) / (2L+x)
Agreed?
omegasquared said:
Ah, good point.
Agreed?
Yes.
haruspex said:
Yes.
I'm still unsure how to get from there to simply ky however.
It says small displacements. If y is small, x is very small. What approximations does that allow you to make?
Expanding previously, Fr = (2kL+2kx)y / (2L+x), so if x is small then 2kx ≈ 0 and 2L + x ≈ 2L? Which would leave 2kLy/2L = ky but then surely the y on the top would make the whole thing ≈ 0?
What we're doing here is finding the first order approximation. You can think of it as writing the full form as the sum of a series of terms in which, as the displacement tends to zero, each term tends to zero faster than the one before it: a power series, say. The first order approximation throws away all except the first term.
Well, certainly, if you put y = 0, then you don't have to do anything. There are no oscillations! You are making an approximation, where y, and x are small compared to L. So expressions like L + x, where L is large, and x is small, are nearly equal to L. e.g., 1000 + 1 ~ 1000. If you look at the y on top, you cannot neglect it because you don't have anything to compare it with. After all, while 1 << 1000, 1 is not small compared to 0.
Thank you both for your help, in combination I believe I understand this much better now but I'll continue to ponder this idea of approximations (in terms of power series) over. Much appreciated!
