Transverse sinusoidal wave on a string
The discussion focuses on solving for the amplitude of a transverse sinusoidal wave on a string, represented by the wavefunction y(x,t) = A*cos(kx + ωt + φ). The wave has a period T of 24.2 ms and a speed v of 28.3 m/s. Key calculations involve determining the wave number k and angular frequency ω, with k calculated as 9.17441 using the wavelength λ derived from the relationship v = λ/T. The phase constant φ is found using initial conditions, leading to the final amplitude A calculation, which requires careful attention to signs and units.
  • Understanding of wave mechanics and sinusoidal functions
  • Familiarity with wave properties such as period, wavelength, and speed
  • Knowledge of calculus, specifically derivatives for velocity calculations
  • Ability to manipulate trigonometric identities and equations
  • Study the derivation of wave properties from the wave equation y(x,t) = A*cos(kx + ωt + φ)
  • Learn how to calculate wave number k and angular frequency ω from given wave parameters
  • Explore the relationship between phase constant φ, initial displacement, and velocity
  • Practice solving problems involving transverse waves on strings using real-world examples
Students studying physics, particularly those focusing on wave mechanics, as well as educators seeking to enhance their understanding of transverse waves and their mathematical representations.
K3nt70
[SOLVED] transverse sinusoidal wave on a string
The wavefunction of a transverse sinusoidal wave on a string has the form y(x,t) = A*cos(kx +omega*t + phi), where x and y are in m, t is in s and phi is the phase constant in radians. The wave has a period T = 24.2 ms and travels in the negative x direction with a speed of 28.3 m/s. At t = 0, a particle on the string at x = 0 has a displacement of 1.80 cm and travels downward with a speed of 2.05 m/s. What is the amplitude of the wave?
y(x,t) = Acos(kx + wt + phi)
y(x,t) = A/(((x - vt)^2) + 1)
Despite my attempts using these equations, i have made ZERO headway. I think I am having a problem understanding where all the information in the question fits. I did a quick diagram to show what i THINK is happening (is probably not to scale). I guess i have to be PMed for anyone to see it?
What is y in these equations? What is A?
A is amplitude and according to my course notes, "At time t , displacement at given location x is y(x,t)."
Hi K3nt70,
You can already find k and w, because they give you the period and wave speed. What do you get for those values?
You also need the formula for phi as a funtion of the initial displacement and velocity in the y-direction (at x=0,t=0).
Once you have k, w, and phi, you can solve for A by using your first equation.
i solved for w fine, (259.64) but i don't know how to solve for k. I know that k = 2pi/lamda but i have no idea what lamda is in this situation..
edit: v = lamda/T gave me lamda,(0.68486) and then i solved for k using k = 2pi/lamda (9.17441). also, in order to use y(x,t) = Acos(kx + wt + phi) don't i need a value for t, time?
The problem gives you a value for the displacement at t=0 and x=0, so all you need now is to find phi and you can solve for A.
To find phi, your textbook should have a formula for phi in terms of the tangent of phi and the initial velocity and displacement at x=0. You have to be careful to use the right signs for the values; what do you get for that?
i can't find any formula similar to what you described above. all the formulas i found with phi also have amplitude in them.
You have:
y = A \cos (k x + \omega t + \phi)<br />
If you take the derivative, you find the speed of the particles in the y direction:
v_y = - A \omega \sin(k x + \omega t + \phi)
If you set x=0, and t=0, then you can plug in the displacement and initial speed they give you. What do you get for that?
Then you can take the ratio of the two equations, and convert the sine/cosine to a tangent. You get a standard equation which is something like:
<br /> \frac{v_y}{y} = -\omega \tan\phi<br />
where the v_y and y on the left hand side are the values at x=0, t=0.
ok, so I've worked out phi to be -77.2 I am going to put them into the velocity formula and solve for A...
edit: hmm my amplitude came out to be 4.305E-4 m which is wrong.
I don't see how you got phi to be -77.2; what numbers are you using to calculate it?
<br /> \frac{2.05 m/s}{0.0018 m} = -259.64 *tan\phi<br />
and solved for phi..
There are three things: The initial velocity at x=0 is negative; your denominator is not correct (there is one too many zeros); also, it's probably best to do everything in radians (it's easiest to plug into the formulas that way).
okay, so my new phase constant is 0.413368
so... -28.3 m/s = -A(259.64)Sin(0.413368)
i got -0.27 m for A which is wrong. Also, my calculator is now in radians :s
Remember that we have two speeds here; the speed on the left hand side of that equation is not the wave speed in the x-direction; it is the speed of the string in the y-direction, and so the number of the left needs to be -2.05 m/s
YES! thanks for you're help! This led to an addition two correct questions on my assignment.
