When and where do two transverse waves on strings overtake each other?
Two strings, P and Q, with linear mass densities of 1.2 x 10^-2 kg/m are stretched under different tensions of 4.8 N and 7.5 N, resulting in wave velocities of 20 m/s and 25 m/s, respectively. Wave pulses are initiated at different times, with string P starting at t=0 and string Q at t=20 ms. The discussion clarifies that the speed of waves on the strings remains constant along their lengths due to the uniform tension applied, unlike a freely hanging rope where tension varies. Participants emphasize the importance of including units in calculations for clarity. The conversation concludes with a better understanding of the tension dynamics in this specific setup.
palkia
Two long strings P and Q ,each having linear mass density 1.2 x 10^-2
are stretched by a different tension 4.8 N and 7.5 N respectively and are kept parallel to each other with their left ends at x=0.Wave pulses are produced on the strings at t=0 on string P and at t=20ms at string Q.When and where will the pulses on Q overtake at on P.
Using the wave equation for the string ,I found the velocity at x=0 for P and Q to be 20m/s and 25m/s respectively.But I have one doubt about this question.Shouldn't speed of a wave in a string change with respective positions due to change in tension throughout the string...So does this not contradict the question
What change in tension?
Likes palkia
Change in tension in a rope having masses incrases linearly throughout the rope
You are thinking of a freely hanging rope. There is nothing in the problem formulation indicating that this is the case.
Also, you should always state units when giving values.
Likes palkia
What is the difference between freely hanging rope and this case?
I will keep in mind to mention the units next time .
A hanging rope has a gravitational force acting on it in its longitudinal direction. For force equilibrium, this means tension has to vary accordingly.
Likes palkia
And what does this case look like...are we holding the rope?
The strings are kept taut by pulling them at each end.
Likes palkia
Okay.I got this then
Thanx
