Travel Faster Than Light: Going Back in Time?
  • Context: Graduate
  • Thread starter Thread starter GomezMan91
    Time
The discussion revolves around the concept of traveling faster than light and its implications for time perception, specifically whether such travel would allow one to see objects as they were in the past or future. Participants explore theoretical scenarios, paradoxes, and the nature of light and time, with a focus on speculative ideas and hypothetical situations.
  • Speculative
  • Some participants suggest that traveling away from an object at a speed greater than light could allow one to see that object as it was in the past due to the light reflected from it.
  • Others argue that while we can see distant objects as they were in the past, traveling faster than light is not possible, and thus no paradox exists.
  • A participant proposes that if one could travel faster than light, they might perceive time differently, raising questions about what happens when they stop moving.
  • Another participant emphasizes that no object with mass can exceed the speed of light, asserting that imagining such scenarios leads to nonsensical conclusions.
  • Some discussions mention tachyons as hypothetical faster-than-light particles, suggesting that future discoveries may challenge current understandings.
  • There is a contention regarding whether traveling faster than light away from an object could allow one to see into the future or past.
  • Several participants express skepticism about the validity of speculative discussions, warning against the potential for confusion and misunderstanding.
Participants generally disagree on the feasibility of faster-than-light travel and its implications for time perception. While some explore the concept creatively, others firmly assert that it is impossible, leading to a contentious discussion without consensus.
Participants express various assumptions about the nature of light, time, and mass, with some relying on speculative scenarios that lack empirical support. The discussion includes references to theoretical concepts that are not universally accepted.
GomezMan91
If you were to travel away from an object at a speed greater than light, would you begin to see that object go back in time? The way I have come to see it is that as you move away from an object at a speed greater than light, then you are eventually able to reach or pass light that was reflected from the object at an earlier time.
Any feedback on the subject would be most greatly appreciated as I am always eager to learn new things.
We are already seeing into the past. If I were to photograph an object 100,000 light years from earth, I'm seeint it as it was 100,000 years ago.
ANYWAY, I think you would just see its redshift.
http://en.wikipedia.org/wiki/Redshift
GomezMan91 said:
If you were to travel away from an object at a speed greater than light.
You cannot do this.
Which is why there's no paradox.
DaveC426913 said:
You cannot do this.
oh come on. Use you imagination?:wink:
I believe that you may be able to 'look' back in time, because of the reflected light, but the actual object that is going faster than light, would not actually go back in time, as time would still be moving forward around the object, not going backwards. But, if I am right (doubtful), this would raise the question of, 'What happens when you stop moving?' Would you in fact, be at that time that you were viewing, or would land in you own time again? It might be arguable that as you slow down again, time might go forwards and as you slow down you will get closer to the time you started moving.
Thank you all for your insight on the subject
If you were to suddenly stop you'd more than likely die :P. But if you were to stop what I think would happen is that you would start seeing time forward from the moment you stopped. Only if you start traveling towards the object at a speed greater than light would you be able to see into what to you at the time would be the future, but to the object would be the present and past.
Guys guys guys. This is claptrap. There is only heartbreak and sorrow (and locked threads) down this road.
You cannot travel faster than c. No object with mass can.
This is not merely quibbling. This is critical. To "use your imagination" to pretend that you can will generate all manner of silly, spurious paradoxes. "you'd see unicorns and elves"is as valid as any other answer.
Tachyons?
Alright, since no object with 'mass' can go faster than light, let's bring in an object with a mass less than 0. Monatomic metals. These metals, when brought to a monatomic state, can potentially weigh less than zero, if heated/cooled to a certain temperature (unique to the metal), thus, having no detectable mass.
You mean the past right?
But, if you went faster than light away from an object, then looked back, would you see into the future?
Show me.
DaveC426913 said:
Show me.
Well, I don't have enough posts to post URL's...so I will make 2 posts really quick.
Tachyons are an excellent example of faster than light particles, and although being merely theoretical (for now), the future can undoubtedly bring things that we do not foresee now.
If we don't imagine the impossible we can't accomplish the impossible. Imagination is one of our greatest gifts. Also a lot of current scientific material would have seemed "impossible" to many great scientists from hundreds of years back.
Yes. Absolutely. There's an Imagination Forum down the street.
I'm locking this thread until one of the Physics mentors get a chance to look into it. In the meantime, perhaps we could all take this opportunity to have a read through the PF Guidelines, particularly the part on overly speculative posts.
  • · Replies 23 ·
