Triangle Area Problem: Which Side Lengths Yield Possible Areas?
  • Thread starter Thread starter Jameson
The triangle area problem discussed involves two sides of lengths 8 and 5. The maximum possible area of the triangle is definitively 20, achieved when the angle between the two sides is 90 degrees. The possible areas for the triangle are 20 and any value greater than 0, excluding 24, which exceeds the maximum area. Solutions were provided by members Sudharaka, soroban, and Reckoner, with detailed calculations using both geometric and calculus-based approaches.
  • Understanding of triangle properties and area calculation
  • Familiarity with Heron's formula for triangle area
  • Basic knowledge of calculus, specifically derivatives
  • Ability to interpret geometric representations of triangles
  • Study Heron's formula for calculating triangle areas in various configurations
  • Learn about the relationship between triangle angles and area maximization
  • Explore calculus applications in geometry, particularly optimization problems
  • Investigate the implications of the triangle inequality theorem on side lengths and areas
Mathematicians, geometry enthusiasts, students studying triangle properties, and educators looking for examples of area calculations in triangles.
Jameson
Insights Author
MHB
One side of a triangle has length 8 and a second side has length 5. Which of the following could be the area of the triangle?
a) 24
b) 20
c) 5
Congratulations to the following members for their correct solutions:
1) Sudharaka
2) soroban
3) Reckoner
Solution (from soroban):
[sp]One side of a triangle has length 8 and a second side has length 5.
. . [/color](a) 24 . . [/color](b) 20 . . [/color](c) 5[/size]
Code:
         5  *    .
        * θ            .
\text{If }\theta = 0^o\text{, the triangle has a minimum area of 0.}
\text{If }\theta = 90^o\text{, the triangle has a maximum area of 20.}
\text{Therefore: }(b)\,20\text{ and }(c)\,5\text{ are possible areas.}
[/size][/sp]
Two alternate solutions (from Reckoner):
[sp]Solution 1:
Consider the side of length 8 to be the base of the triangle. Since the side of length 5 will be adjacent to this, the height of the triangle must necessarily be less than or equal to 5. So, using the area formula \(A = bh/2\) with \(b = 8\), we have \[\begin{eqnarray} 0 < h \leq 5 &\Rightarrow& 0 < \frac12b\cdot h \leq \frac12b\cdot5\\ &\Rightarrow& 0 < A \leq \frac12\cdot8\cdot5 \\ &\Rightarrow& 0 < A \leq 20.\end{eqnarray}\] Therefore, the triangle must have an area greater than 0 but less than or equal to 20. Thus 24 is not a possible area.Solution 2, with calculus:
We shall call the length of the unknown side \(c\) and use Heron's formula to find the area of the triangle.
The semiperimeter of the triangle is \[s = \frac{5 + 8 + c}2 = \frac{13+c}2,\] so the area of the triangle is \[\begin{eqnarray}A &=& \sqrt{s(s - 5)(s - 8)(s - c)}\\&=& \sqrt{\left(\frac{13+c}2\right)\left(\frac{13+c}2 - 5\right)\left(\frac{13+c}2 - 8\right)\left(\frac{13+c}2 - c\right)}\\&=& \sqrt{\left(\frac{c + 13}2\right)\left(\frac{c + 3}2\right)\left(\frac{c - 3}2\right)\left(\frac{13 - c}2\right)}\\ &=&\frac14\sqrt{-c^4 + 178c^2 - 1521}.\end{eqnarray}\]
This expression is defined for \(c\in[3, 13]\). We do not need to consider negative values of \(c\) since \(c\) represents a length.
We then have \[\frac{dA}{dc} = \frac{-c^3 + 89c}{2\sqrt{-c^4 + 178c^2 - 1521}}\] so that, for \(c\in[3, 13]\), \[\begin{eqnarray}\frac{dA}{dc} = 0 &\Rightarrow& -c^3 + 89c = 0\\&\Rightarrow& c=\sqrt{89}.\end{eqnarray}\]
Testing the critical value \(c = \sqrt{89}\) with the endpoints of the interval \(c = 3\) and \(c = 13\), we see that \(c = \sqrt{89}\) produces a maximum area of 20, and that \(c = 3\) and \(c = 13\) produce a minimum area of 0 (these last two lengths would not form a valid triangle, but by taking values of \(c\) close to these we can create a triangle with area as close to zero as we wish).
Therefore, the area of the triangle could be any value \(A \in (0, 20]\). We cannot have \(A = 24\), as this exceeds the maximum area. [/sp]
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 21 ·
