Solve Tricky Integration: ##\frac{20\ln{(t)}}{t}##
  • Thread starter Thread starter squenshl
    Integration
To solve the integral of 20ln(t)/t, integration by parts is a straightforward method, but a simpler approach is using u-substitution with u = ln(t) and du = (1/t)dt. This leads to the solution of 10ln(t)^2, which is the square of the natural logarithm of t. It's important to clarify that the solution refers to the square of the natural log, not the natural log of t squared. Additionally, including a constant of integration is necessary for completeness in calculus.
squenshl
How do I solve ##\frac{20\ln{(t)}}{t}##?
Is it easier to calculate this without integrating by parts?
I'm not sure where to start.
Solving by integration by parts is easy - very few lines. I can't think of an easier way.
There is an easier way. Try a simple "u-substitution".
You have ##f\cdot f'## which is half of ##(f^2)'##. Done.
Likes epenguin and Tallus Bryne
I like the simplicity, but shouldn't it be just half of ##(f^2)## ?
edited: forgot the "half of"
##f^2## is the solution after integration, but I said ##f \cdot f' = \frac{1}{2} \cdot (f^2)'## for the integrand. Of course this all is a bit sloppy: no integration boundaries or the constant, no mentioning of ##\ln |x|## in the OP and no ##dt 's##.
Agreed. Thanks for clearing that up.
Substitute ##u = \ln t, du = \frac {1}{t}dt##
Thanks everyone. The solution is ##10\ln{(t)}^2##.
You might like to remove an ambiguity.
Is that the natural log of the square of t, or is it the square of the natural log of t ?
Also, I suspect that you need to include a constant of integration .
Typically for integrals involving ln in a typical calculus course...
Always try u sub. If that does not work, then integration by parts. Keep this in mind.
  • · Replies 26 ·
