Trig Assistance for CNC Machining/Engineering
10 replies · 5K views · last reply
megani
Trig help please! CNC Machining/Engineering
  • Engineering drawing of two circles on a sloped line with dimensions: 126.000 horizontal spacing, 86.000 vertical offset, 47.000 DIA and 78.000 DIA; angle labelled y is to be determined.
I redraw the picture. you mean by DIA ( diameter ) right ?. you can notice that the two triangles the one with the big circle and the one with small circle are similar.
$dR = \frac{39}{\sin y}, cr = \frac{23.5}{\sin y}, ch = \frac{86}{\tan y}$ now
$dR + cr + ch = 126 $ hence
$126 = \frac{39}{\sin y} + \frac{23.5}{\sin y} + \frac{86}{\tan y} $
$126 \sin y = 62.5 + 86 \cos y $
  • Geometry diagram of a rectangle with corners r, s, S and R, a red line crossing it diagonally, and green circles at two corners. Labels: 126 along the top, 86 down the left side, 39 and 23.5 on blue radii, angle y marked, and points a, b, c, d, h on the figure.
Sorry your picture is not working now.
Just not too sure with the distance from S - H?
you mean ch ? it is typo I meant $dh$. ch is perpendicular to SR so we have a right triangle $\tan y = \frac{86}{hd} $
$hd + dR + cr = 126$
Yes sorry HD...Initially I though 126-39-23.5 but there's a little gap between the circle, do you see?
- - - Updated - - -
- - - Updated - - -
Actually...gap next to big circle too! :-\
  • Geometry diagram of a rectangle rs RS with a red tangent line crossing it, two green circles touching the line, and labels 126, 86, 23.5 and 39 with angle y marked and point h below c.
yea I see it but it dose not affect the solution. "c" is the intersection between the tangent and the horizontal line "rs". and "ra " is perpendicular to the tangent it is a theorem the angle $acr = y$ I used sine definition to come up with $\sin y = \frac{23.5}{rc} \rightarrow rc = \frac{23.5}{\sin y}$
Hi megani,
Welcome to MHB! This appears to be part of a graded assignment. If so, are you allowed to receive outside help? I ask only to confirm that we aren't taking part in unallowed assistance.
Jameson said:
Hi megani,
Hi. No. I'm actually a learning support teacher (main focus numeracy) and my colleague and I are developing a revision workbook for some Dip. Engineering students and this was one of their resources.
