Trigonometric inequality problem.
The discussion revolves around proving the trigonometric inequality 0 ≤ (1 + sin(x)) / (5 + 4cos(x)) ≤ 10/9 for all x. Participants suggest sketching the graph of the function to visualize its behavior and inquire about methods to determine its maximum and minimum values. There is a focus on ensuring the denominator is never zero or negative, which is crucial for the inequality's validity. One proposed approach is to analyze the critical points and prove that the expression 1 + sin(x) - (10/9)(5 + 4cos(x)) remains negative. The conversation emphasizes the importance of both the numerator and denominator in establishing the bounds of the function.
Michael_Light
Deduce that 0 ≤
≤ 10/9 for all values of x.
Is it possible to sketch a graph for
? How?
Or is there any methods to find the max./min. value of
Please enlighten me...
is the denominator ever zero or negative? if not try mutiplying through by it
or find the critical points to fiind max and min
If you can prove 1+sin(x)-\frac{10}{9}(5+4cos(x)) is always less than 0, you can get the less than part. If you think about the numerator, the greater than part also follows quickly.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
