Trigonometric Integrals by Substitution
awsalazar
I am unsure whether I have properly performed the integration of the integral ∫((sin(√x))^3*dx)/√x
When I used my TI-Nsprire CAS to take the derivative of my answer in order to check if I was correct, and it came out differently. Now I used some trig identities to manipulate the problem, so I figured that is why it was different. So when I stored the integral into one function and the solution into another function, values I would enter were different for each function. Can someone correct any errors I have made or confirm that my answer is correct?
I have attached my attempt at the integral as a .jpg file.
Your solution and answer are correct. Note that whatever answer your calculator had, you can merely subtract it from the original and see if the result is 0.
Thanks a lot guys, and good advice Karnage1993, a much easier process then what I was doing.
