Trigonometric substitution in ∫x²/√(4-x²)dx
Pindrought
Okay so I'm working on this problem
$$\int \frac{x^2}{\sqrt{4 - x^2}} \, dx$$
I do a substitution and set
$$x={\sqrt{4}}sinu$$
I get to this step fine
$$\int 4sin(u)^2$$
I know that u = arcsin(x/2)
so I don't see why I can't just substitute in u into sin(u)?
I tried this and I got
$$\int 4 * arcsin(sin(x/2))^2$$
which worked out to
$$\int 4 * \frac{x^2}{4}$$
which gave me
$$\int x^2$$
which would just mean the answer is
$$\frac{x^3}{3}$$
But looking at the mathhelpboards solver, this is wrong. Can anyone help me figure out what I am not understanding? Thanks a lot for taking the time to read.
$$\int 4sin(u)^2$$
which worked out to
which gave me
$$\int x^2$$
$$\frac{x^3}{3}$$
The differentials you didn't include in the integrals give us an idea why your approach isn't correct.
What you start with is
\[\int \frac{x^2}{\sqrt{4-x^2}}\!\color{red}{\,dx}\]
We then make the trig substitution $x=2\sin u\implies \color{red}{\,dx} = 2\cos u \color{blue}{\,du}$
Therefore,
\[\begin{aligned} \int \frac{x^2}{\sqrt{4-x^2}}\!\color{red}{\,dx} \xrightarrow{x=2\sin u}{} &\phantom{=}\int\frac{4\sin^2u}{2\cos u}\cdot 2\cos u\color{blue}{\,du} \\ &= \int 4\sin^2u\color{blue}{\,du} \end{aligned}\]
If we proceed with how you wanted to do things, if $x=2\sin u \implies u = \arcsin(x/2)$, then
\[\int 4\sin^2u\,du = \int 4\sin^2(\arcsin(x/2))\,du = \int x^2\color{blue}{\,du}\]
We can't say this is $\dfrac{x^3}{3}+C$ because the variable we're integrating with respect to here is $u$, not $x$! If you want to get $\,dx$ instead of $\,du$ in the integral, you are undoing what you just did with your substitution.
Instead, from $\displaystyle \int 4\sin^2u\,du$, you want to apply the trig identity $\sin^2\theta = \dfrac{1-\cos(2\theta)}{2}$ to get
\[\int 4\sin^2u\,du = \int 2-2\cos(2u)\,du\]
Can you take things from here? (Smile)
Therefore,
Thanks a lot Chris L T521, you really helped me understand what I was doing wrong.
