Trigonometry - Hot Air Balloon - Homework Question
The discussion revolves around solving a trigonometric problem involving the altitude of a hot air balloon as observed from two different locations. Jack observes the balloon at an angle of elevation of 57 degrees, while his friend, located 26 km away, observes it at 83 degrees. The correct altitude of the balloon is determined to be 49.4 km using the Sine Law and trigonometric functions. Participants clarify the importance of interpreting the angles correctly and suggest methods to solve the problem accurately.
  • Understanding of Sine Law: [(sinA/a)=(sinB/b)=(sinC/c)]
  • Knowledge of trigonometric functions: SOH, CAH, TOA
  • Ability to solve systems of equations involving trigonometric ratios
  • Familiarity with vector components in trigonometry
  • Learn how to apply the Law of Sines in non-right triangles
  • Study the properties of angles of elevation and depression in trigonometry
  • Practice solving systems of equations with trigonometric functions
  • Explore vector decomposition in trigonometric contexts
Students studying trigonometry, educators teaching mathematical concepts, and anyone involved in solving real-world problems using trigonometric principles.
Sabellic
Hello all, I am having trouble with the following homework question using trigonometric formulas and the Sine Law.
Here is the problem:
Jack spotted a hot air balloon from his house at angle of elevation 57 degrees. Jack's friend who lives 26 km from Jack's house spotted the same balloon at angle of elevation 83 degrees. Determine the altitude of the balloon to the nearest tenth.
Sine Laws: [(sinA/a)=(sinB/b)=(sinC/c)], Trigonometric Functions: (SOH, CAH, TOA)
Here is my solution:http://img143.imageshack.us/img143/4566/hotairballoonqc2.jpg However, the answer given in the text was 49.4 km.
Whereas, my answer is 33.7 km.
Can anybody tell me where I went wrong.
Thanks a lot.
Hmm...I get the same answer you did. I used vectors to set up the equations like this:
The horizontal components of side a and c should add up to 26.
c*cos(83) + a*cos(57) = 26
The vertical components of a and c should be equal.
h = c*sin(83) = a*sin(57)
You can solve those two equations for a and c. I get for a the same answer you did. This leads to the same height that you got.
I also considered that maybe the two observers were on the same side of the balloon. The observer at 57 degrees would be further than the observer at 83. However, you get a negative side length which means a solution is not possible in that configuration.
Yes, I thought so myself.
Did anyone else get the same answer?
Hi Sabellic!:smile:
erm … you've read into the question something that isn't there.
the elevations are in the same direction, and you've drawn them opposite. :frown:
Draw a leany-over triangle, and you'll find you get 49.4. :wink:
What's a leany-over triangle? When I think of leany-over triangle I think of an obtuse triangle because the point extends laterally over the base as if it is "leaning". But all of the angles are less than 90 degrees.
Yes … but one of them is an external angle! :smile:
(Where in the question does it say that they're facing in opposite direcitons? :rolleyes:)
Doh. Yep that works. I considered that case but got a negative range for one of the sides the first time. Just did it again and it works out.
Okay, I got the answer. Thanks.
However, if I didn't know the answer I would have thought the opposite directions is perfectly plausible. They didn't specify same directions. They didn't specify opposite directions.
What would be the right method of finding the solution? They didn't specify that one of them is an external angle. Should I solve the question two different ways and then see which one is best?
Well, they didn't specify that it was one-dimensional either, did they?
If the question uses a word like "elevation" twice without saying what it's an elevation from, then you should assume that it's from the same thing each time … eg north and north, not north and south, or north and east. :smile:
Very good advice. Thanks.
Um, I'm getting height = 33.7. Basically I let x be the distance from the 57 deg angle to the foot of the perpendicular and 26-x be the distance from the 83 deg angle to the foot.
Then it's just a system of two equations with two variables involving tan.
If x is the distance from the 57 angle, then 26-x would be the distance to the 83 angle if the observers were on opposite sides like the original poster has in his drawing. If they are on the same side, then the distance becomes x-26.
The horizontal distance from the guy further out from the balloon is a*cos(57), were a is the slant range to the balloon. The horizontal distance from the guy closer to the balloon is c*cos*(83). The two observers are separated by 26, on the same side, so this gives you
a*cos(57) – c*cos(83) = 26.
The vertical distance or height is the same for each, or
h = a*sin(57) = c*sin(83)
Solve for c.
c=a*sin(57)/sin(83)
Plug into first equation.
a*cos(57) – a*sin(57)*cos(83) / sin(83) = 26.
Solve for a.
a = 26*sin(83) / (cos(57)*sin(83) – sin(57)*cos(83) ) = 58.86
So the height is
a*sin(57) = 49.37
Hi Chrisas! :smile:
Nice solution …
but try to give hints rather than full solutions :smile:
(you did the same thing with a series summation thread …)
Dang, I made a wrong assumption. Hmm I remember doing problems involving both cases but don't remember how the wording was different. Oh well same two variable two equation problem pretty much. Though it might be a bit prettier if you applied the law of sines but I rarely did that in precalc for this type of problem :P.
http://img501.imageshack.us/img501/7728/hotairballoon2pl4.jpg
here's how it should look
Hi Sabellic! :smile:
Yes, that's it! :smile:
The only suggestion I'd make is that it's slightly neater if you do all the calculating in one go …
you aren't asked for a, so just prove that h = 26 sin83º sin57º/sin26º, and then calculate that directly.
(it has the extra advantage that if you get the wrong result, it's easier to see how to adjust it! :wink:)
10K
9K
9K
