LmdL
- 72
- 1
Hello,
How can I calculate a triple correlation between 3 signals A,B,C (each has 2 million samples)? I know xcorr do it for 2 signals by FFT each signal, multiplication and iFFT back. Since xcorr cannot do it for three signals, I try to do it "manually" by the above algorithm.
So, the "regular" cross-correlation:
F\left(s_1 \right) = \int_{-\infty}^{\infty}f^* \left(t\right)g\left(t+s_1 \right)dt
is a function of 1 variable s1 and therefore a vector. After FFT on each of the two signals I get 2 vectors in Fourier domain, multiply them element by element, get another vector and by inverse FFT get the cross-correlation, which is a vector.
Now I want to do the same to three signals. Triple correlation is:
F\left(s_1, s_2 \right) = \int_{-\infty}^{\infty}f^* \left(t\right)g\left(t+s_1 \right)h\left(t+s_2 \right)dt
which is a function of s1 and s2 and therefore should be a matrix.
After FFT on each of the three signals I get 3 vectors in the Fourier domain. Now, in order to get a matrix as a triple correlation, I need a matrix in Fourier domain as well. But I have 3 row vectors and how exactly can I get a matrix from them? I tried to multiply the first vector by a second one, element by element and then convert the third vector from row to column and multiply between them to get a matrix, but after inverse Fourier transform I get a wrong answer.
Do someone have and idea how to do it? Thanks!
