Triple Star System: Find Period of Revolution in Years
  • Thread starter Thread starter NAkid
    Star System
The discussion revolves around a triple-star system where two stars of equal mass revolve around a central star. Participants are tasked with finding the period of revolution of the stars in years, given specific masses and the radius of their circular orbit.
  • Participants discuss the application of the period of motion equation and whether to consider the total mass of the system. Questions arise about the equality of periods for the two stars and the implications of their positions in the orbit.
There is an ongoing exploration of the gravitational forces acting on the stars and how to set up the equations correctly. Some participants suggest focusing on the forces exerted by the stars on each other and question the relevance of the masses involved.
Participants note the potential confusion regarding the relative masses of the stars and their distances, as well as the implications of using approximations in their calculations.
NAkid
A certain triple-star system consists of two stars, each of mass m = 7.00×1024kg, revolving about a central star of mass M = 1.69×1030kg in the same circular orbit of radius r = 2.00×1011m(see the figure). The two stars are always at opposite ends of a diameter of the circular orbit. What is the period of revolution of the stars in years(yr)?
https://cats.lsa.umich.edu/wiley-HRW6/Graphics/14-39.jpg
I know that the equation for period of motion is
T=2*pi*r^3/2 / sqrt (GM)
I'm just not sure if I can plug in values where M is the aggregate of masses M1 and M2..
I'm just a high school physics student, (so I could be wrong), but technically, if the stars are always at opposite ends, aren't the periods of the stars equal to each other? Which would mean using that equation and plugging in the 7E1024 and 1.69E1030 be correct?
Like I said, I could be very very wrong, but this is just my thought on the problem.
Go back to the basics:
[tex]F = m \frac{v^2}{R} = m \frac{4 \pi^2 R}{T^2}[/tex]
where here m is the mass of the star that you are focusing on and R is the radius of its orbit.
Now, the force will be the total force acting on that star so it will be the sum of the force of gravity due to the other two stars. Can you go on from there?
ok so the force of gravity is Fg = (GM1M2)/R^2
If total force is what you have above, should I set that equal to 2*(GM1M2)/R^2 -- or the sum of Fg of star1 on central star and star 2 on central star?
The equation I wrote is to be applied to one of the star in motion. So the force is the total force due to the other two stars. Note that the other two stars are AT DIFFERENT DISTANCES! So be careful with that
but their orbital radius is the same though?
i'm still confused, the force is the total force due to the other two stars - what does that mean? and how does gravitational force work into this equation?
Let's say we have stars A, B and C in that order. Star B is at rest. Stars A nd C are moving in a circle. The radius of the circle is the distance between star A and star B, right? (which is the same as between star B and star C) and is equal to 2 x 10^11 m.
Calculate the total force on star A. It's the sum of the force of star B on star A PLUS the force of star C and star A.
But I just noticed that the mass of stars A and C is really tiny compared to the central star (thos enumbers don't make much sense since the masses of stars A and C are comparable to the mass of a planet not of a star!)
Anyway... because the mass of stars A and C is so small compared to mass B, you can neglect the effect of the gravitational pull of star C on star A. In that case, the force of gravity on star A is simply the force of star B on star A only.
i think its supposed to be 10^24 and 10^30
the total force on star A would be G(mass starB) / (R)^2 + G(mass starC) / (2R)^2 ?
Almost. You still have to multiply by the mass of star A. So it is
[tex]\frac{G m_A m_B}{R^2} + \frac{G m_A m_C}{(2R)^2}[/tex]
as I said, it turns out that the second term will be negligible compared to the first since they used such a small mass for "stars" A and C (the masses are actually close to the mass of our planet!).
