Trivial holomorphic first sheaf cohomology
  • Context: Graduate
  • Thread starter Thread starter lark
This discussion focuses on the concept of trivial holomorphic first sheaf cohomology, particularly in the context of subsets of the complex plane (C). Participants explore examples of open covers, such as U_1 and U_2, and their implications on cohomology, noting that connected open sets in C exhibit H^1(O) = {0}. The Mittag-Leffler theorem is referenced, indicating that certain functions, like e^{1/sin(z)}, can be expressed as sums of functions analytic in different regions. The conversation emphasizes the need for refinement in open covers to achieve trivial cohomology.
  • Understanding of sheaf cohomology concepts
  • Familiarity with the Mittag-Leffler theorem
  • Knowledge of analytic functions and their properties
  • Basic concepts of complex analysis, particularly in the context of the complex plane
  • Study the properties of sheaf cohomology in complex analysis
  • Learn about the implications of the Mittag-Leffler theorem on holomorphic functions
  • Explore examples of open covers in complex manifolds
  • Investigate the relationship between trivial cohomology and contour integrals
Mathematicians, particularly those specializing in complex analysis, algebraic geometry, or topology, will benefit from this discussion. It is also relevant for graduate students and researchers exploring sheaf cohomology and its applications in complex manifolds.
lark
What's an example of a set with trivial holomorphic first sheaf cohomology? I was thinking of subsets of C, and trying to think what would satisfy this.
For example, suppose you covered C by U_1=re^{i\theta}:r < 2 and U_2=re^{i\theta}:r> 1/2. Then if f(z)=1/z, \oint_{|r|=1} f(z)\neq 0, and he says the contour integral of a function in U_1\cap U_2 should be 0. So I don't think subdividing C this way is a good limiting open cover.
But what would be a good limiting open cover, other than just C by itself? One should be able to refine an arbitrary open cover of C into one which has trivial holomorphic first sheaf cohomology, since C by itself does.
Supposing you covered C by U_1=z: Re(z) > \pi/2 and U_2=z: Re(z) < \pi. I don't see how that open cover would have trivial first sheaf cohomology either since \displaystyle e^{1/ sin(z)} would be analytic in U_1\cap U_2 and I don't think e^{1/ sin(z)} could be expressed as the sum of a function that's analytic in U_1 and a function that's analytic in U_2. So would such an open cover need more refinement? Into what?
What's a good book on it?
Laura
I'm not sure I follow precisely what is going on (cohomology of which sheaf in particular?), but I'd suggest that simply connectedness is something to think about - if you have C\{0} then there's that standard logarithm thing isn't there.
I guess you mean H^1(O) = {0}. This is true of all connected open sets in C, but not in C^2, as I recall.
the point is whether there exists a function holomorphic in the set which does not extend to a larger connected open set. this is true of all regions in C.
another related problem is whether there is a divisor in that set which is not the zero set of a meromorphic function, but mittag leffler says there is not.
I guess the Mittag-Leffler theorem does say you could express e^{1/sin(z)} as the sum of two functions, one analytic in one half plane, one analytic in the other. It's pretty surprising.
I guess what Penrose says about trivial cohomology meaning that the contour integral is 0 for a function that's a coboundary, doesn't apply to the complex plane.
The idea of the sheaf cohomology group is that you have an open cover U_\alpha of the manifold, and holomorphic functions f_{\alpha \beta} defined on each intersection U_\alpha\cap U_\beta,, such that on triple intersections f_{\alpha \beta}+f_{\beta \gamma}+f_{\gamma \alpha}=0 (i.e. the f's are a cocycle), and a set of f's is considered equivalent to 0 iff f_{\alpha\beta}=g_\alpha-g_\beta, with g_\alpha analytic on U_\alpha, g_\beta analytic on U_\beta.
Laura
Surprising because e^{1/sin(z)} has essential singularities!
Laura
