Trouble finding appropriate potential function
  • Thread starter Thread starter cwbullivant
    Function Potential
The vector field defined by F = 2xc x̂ + cz ŷ + cx ẑ is confirmed to be conservative after computing the curl, which is zero. To find the potential function, a specific path from the origin to (x, y, z) must be chosen for the line integral, as the integral's value is path-dependent unless specified. The discussion highlights the importance of correctly parameterizing the path and evaluating the integral, leading to the potential function V = -cx² - cyz. Ultimately, the correct approach simplifies the integration process, allowing for an easier calculation of the potential function and confirming the relationship between F and V.
cwbullivant
Given a vector field defined by:
## \vec F = 2xc\hat x + cz\hat y + cx\hat z ##
Is conservative
Find a potential function for F. Verify this by taking the gradient to recover F.
## V = - \int_a^b \vec F \cdot \vec dr ##
## F = -\nabla V ##
The field is conservative, and this was found easily by computing the curl and finding it to be zero.
To find the potential function, I tried to simply apply the second formula in section two, as such:
## \vec dr = dx\hat x + dy\hat y + dz\hat z ##
And to choose a path from (0,0,0) to (x,y,z).
So then:
## \vec F \cdot \vec dr = 2xcdx + czdy + cydz ##
And the resulting integral is:
## - ( \int_0^x 2xcdx + \int_0^y czdy + \int_0^z cydz ) ##
Which results in:
## V = -cx^{2} - cyz - cyz = -cx^{2} - 2cyz ##
But when I try to get back to F using the negative gradient of V, I get the correct answer for the x component, but the factor of two ends up giving me the wrong answer for the y and z components. I'm not sure exactly what went wrong or how to fix it at this point.
Your integral is wrong. Think more carefully about the path from the origin to (x, y, z).
Is conservative
That field isn't conservative. Presumably you mean the third term to be ##cy\hat z##.
## F = -\nabla V ##
What path are you choosing?
So then:
I don't follow that step. You need to specify a path.
Quite right, I did mean the last component to be ## cy\hat y ##.
When you say to specify a path, do you mean I need to specify a specific path, like (0,0,0)->(1,1,1), and can't do a generic path from the origin to some (x,y,z) (it's been awhile since I last did vector calc)?
If so, say I choose the path I mention prior, going from the origin to (1,1,1). Then the integral should result in:
## V = -c - cz - cy ##
And going from there, I'm not sure where to begin going in the other direction.
There is an infinite number of paths that connect (0, 0, 0) to (x, y, z). You need to choose one specific path to evaluate the integral.
That's true, and since F is conservative, it shouldn't matter which of those infinite paths I take. That's convincing for why I needed to choose a particular path, but after that, is the number that I got when using a straight line from the origin to (1,1,1) correct?
Based on that, the gradient of V is, problematically, nothing that even looks even a bit like the original function. I'm thinking the mistake is in evaluating the integral, but I can't seem to tell where that problem is.
You want to go from ##(0,0,0)## to ##(x,y,z)##, not ##(1,1,1)##. You will have to keep your variables straight. If you intend to use a straight line path, you need to write the equation of that path in the form ##\vec R(t) = \langle x(t),y(t),z(t)\rangle## and use that equation to evaluate the integral$$
\int_C \vec F\cdot d\vec R = \int_a^b \vec F \cdot \frac{d\vec R}{dt}~dt$$where ##a## and ##b## are the ##t## limits of your parameterization of your straight line ##C##. Since you haven't gotten the correct answer you obviously aren't doing it right. So show us your equation of the line and your setup of the integral.
Alternatively, since, as you have mentioned, the integral is independent of path, you could choose a different path (there are easier ones) or you can find the potential function by integration methods.
I'm not sure exactly what would be an easier curve than a straight line, but here's how I set up the straight line using the formula you gave me:
## \vec F = <1,1,1> ## (since it's a straight line, x(t), y(t), z(t) are all t from 0 to 1)
##\frac{d\vec R}{dt} = <1,1,1> ## (the derivative of a straight line is a constant)
So then:
## \vec F \cdot \frac{d\vec R}{dt} = 2tc*1 + tc*1 + tc*1 = 4tc ##
## \int_0^1 4tc dt = \left. 2t^{2} \right|_0^1 = 2 ##
But this is even worse than the first attempt. Is there some subtlety with using a straight line that I'm missing?
You already have ##\vec F = c\langle 2x,z,y\rangle##. Don't use it for something different now.
What you have called ##\vec F## and should be ##\vec R(t)## above isn't the equation of a straight line because there is no ##t## variable in it. And as you have been told before you don't want the path to go from (0,0,0) to (1,1,1) anyway. It has to go to (x,y,z). I would suggest you have it go to (X,Y,Z) so you don't get your dummy integration variables dx,dy, and dz mixed with them.
It isn't exactly subtle. You need to start by writing the parametric equation of the line from (0,0,0) to (X,Y,Z). You can change the answer back to lower case once you have the line integral figured out.
Typos abound in the above post, sorry about that. It was supposed to be:
## \vec R = <t, t, t>, \frac{d\vec R}{dt} = <1,1,1> ##
So if the path is from (0,0,0) to (X,Y,Z), if I were to do it by integrating with dt, would I need to use bounds on t from 0 to, say, T?
LCKurtz said:
You need to start by writing the parametric equation of the line from (0,0,0) to (X,Y,Z)..
Is that supposed to be your response to my above quote?
I hit "enter" too soon. It's been edited to add the rest.
At the risk of repeating myself: YOU HAVE TO BEGIN BY WRITING THE PARAMETRIC EQUATION OF THE STRAIGHT LINE from (0,0,0) to (X,Y,Z). Surely your text tells you how to write the line between two points.
The general form is given as:
## x(t) = x_0 + at ##
## y(t) = y_0 + bt ##
## z(t) = z_0 + ct ##
And ## \vec R (t) = \langle x(t), y(t), z(t) \rangle ##
Since the line starts at the origin, the initial points (x0, y0, z0) are all zero. The end points are (X, Y, Z). So then if t goes from 0 to 1, then a = X, b = Y, c = Z.
So:
## \vec R (t) = \langle Xt, Yt, Zt\rangle ##
And by taking the derivative:
## \frac{d\vec R}{dt} = \langle X, Y, Z\rangle ##
Given that it returns the correct values for the start and end points, I'm pretty confident that this is the correct equation for the line.
And then I rewrite F with R(t) included:
## \vec F = \langle2cXt, cZt, cYt \rangle ##
And taking the dot product of F with the derivative of R:
## 2ctX^{2} + ctZY + ctYZ = 2ctX^{2} + 2ctYZ ##Applying that to the integral:
## \int_0^1 2ctX^{2} + 2ctYZ dt = \left. ct^{2}X^{2} + ct^{2}YZ \right|_0^1 = cX^{2} + cYZ ##
Which gives me the correct vector field upon taking the gradient, finally. Sorry for being so incredibly dense; that shouldn't have been half as difficult as I made it.
Now that you have solved the problem, I will show you what I meant about an easier path. Ignoring the ##c##, you have the integral$$
\int_{(0,0,0)}^{(X,Y,Z)} 2x~dx +z~dy +y~dz$$and you are free to choose the path. Think about the path that moves along the coordinate directions, first in the x direction, then the y direction, then the z direction. So the path has three sections$$
(0,0,0) \to (X,0,0)\to (X,Y,0) \to (X,Y,Z)$$That may seem like adding work but as you will see, you have lots of zeros, and you can let the variables themselves be the parameters.
On the first path both dy and dz are zero so you just have ##\int_0^X 2x~dx = X^2##.
On the second path both dx and dz are zero so you have ##\int_0^Y z~dy = 0## since ##z=0## on that segment.
On the third path both dx and dy are zero so you have ##\int_0^Z y~dz = \int_0^Z Y~dz = YZ## since ##y=Y## on that path.
Adding them up gives ##X^2 + YZ##. Same answer but less work since you can do many of the steps I have written out in your head.
