Trouble finding direction of two force vectors
The discussion centers on calculating the net force and acceleration of a block subjected to two forces, F1 and F2. The user initially confuses the dot product with vector addition, mistakenly stating that they calculated the net force as a dot product. After clarification, they correctly compute the net force as Fnet = 3i - 4j and find its magnitude to be 5. To determine the direction, they are advised to use trigonometry, specifically the inverse tangent function, after plotting the vector. The conversation highlights the importance of understanding vector operations in physics problems.
Gradyjenkinz
[/B]
A block of mass 2kg is accelerated by the two forces F1 = 8i + 3j and F2 = -5i - 7j, (a) What is the net force on the block in unit vector notation, and what is its magnitude and direction? (b) What is the magnitude and direction of the acceleration?
I'm not sure of the equation for the direction.
I was able to dot the two vectors to get the Force, but I am stuck from here.
By convention, i,j,k are the unit vectors (of length 1) in the positive x,y and z axis respectively. By using i,j,k you have already taken into account for direction.
In the back of my book it gives answers, and the answer for this involves a degree though.
Yes, that is the answer for the second part of the question, part (a):
I must've misunderstood your question.
You already have the net force in vector notation, am i right? Noting that i and j are unit vectors in the x and y direction, resolve your net force vector into the x and y direction. Then you should be able to see what you need to do to get the direction.
Hint: you need trigonometry
Gradyjenkinz said:
[/B]
Can you show your work so far? Note that forces sum to yield a net force.
Yeah sure. So far I dotted the two vectors and I got Fnet = 3i - 4j, then F=5 for the magnitude. I then plotted the vectors on a graph and not sure what to do from here.
I don't know what you did here, but the dot product of two vectors is a scalar, not another vector.
https://www.mathsisfun.com/algebra/vectors-dot-product.html
The resultant of two vectors F1 and F2 is found by vector addition, or Fres = F1 + F2
In other words, you add the i and j components of each vector together to produce the resultant vector.
Plot your net force similarly. Do you understand how and why the magnitude of 3i - 4j is 5?
Likes Gradyjenkinz
Note that what you did was not a dot product, it's a sum. You would write (8i + 3j)+(-5i - 7j) = 3i - 4j, not (8i + 3j)⋅(-5i - 7j) = 3i - 4j.
To find the angle, make a drawing of 3i - 4j.
Thank you, I got it. I plotted it and then took the inverse tan to get the angle.
