Trouble with local extrema graph
11 replies · 4K views
coverticus
Sketch a graph of a function f that is continuous on [1,5] and has no local maximum and minimum, but 2 and 4 are critical numbers.
Knowing 2 and 4 are critical numbers, I formed the base function x[tex]^{}2[/tex]-6x+8. Not sure how to go about sketching the graph the meets the stipulations beyond this.
Just draw it. No need to actually have a concrete function.
Also, note that x^3 has no maximum or minimum but has a critical point where? What does that point look like?
Also, are you sure it's [1,5]?
So just sketch a graph that has no local extrema on [1,5]? If so how are 2 and 4 critical numbers?
Yes it is [1,5], and x^3 has a critical point at 0, and it has a slope of zero. Correct?
I still need somewhat of a solid answer here, do I just sketch a graph where x=0 on [1,5] or something different? Any help here would be great.
You sketch a graph where x=2 and x=4 have horizontal tangents, but aren't maxes or mins.
does that satisfy the continuity?
Just draw the curve y=x^3 and look what happens at x=0. Now draw a curve with two points like that.
how can you do that without creating an extrema?
Put your pencil on a paper at x=1. Curve up until you reach x=2 then flatten out but don't go down. Increase out of the flat part till you get to x=4, then flatten out again. Then increase some more till you get to x=5.
