Troubleshooting a Polynomial Function in Java
  • Context: Comp Sci
  • Thread starter Thread starter schapman22
    Debugging Java
6 replies · 3K views
schapman22
We must make a class used to evaluate a polynomial function of x. My problem is I am getting an array out of bounds exception when I run the main, and I can't figure out why.
If you could help me figure out this out of bounds exception it would be very appreciated thank you.
ex. P(x)= a0 + a1x + a2x2...
This is the class
Code:
public class Polynomial
    private int degree, i=0, size;
    private double answer;
    private double[] coefficient = new double[size];
    public Polynomial(int max)
        if(degree>=0)
            degree = max;
        size=max+1;
    public void setConstant(int subscript, double value)
        i = subscript;
        coefficient[i] = value;
    public double evaluate(int x)
        for(int index=0;index<coefficient.length;index++)
            answer = coefficient[index] * (Math.pow(x, degree));
            return answer;
This is the main
Code:
public class PolynomialDemo
     * @param args the command line arguments
    public static void main(String[] args)
        Polynomial p = new Polynomial(3);
        p.setConstant(0, 3);
        p.setConstant(1, 5);
        p.setConstant(2, 0);
        p.setConstant(3, 2);
        System.out.println(p.evaluate(7));
on Phys.org
It is because the length of the array coefficient is zero!
When you are creating the object of the class Polynomial, you are calling the constructor and it is updating the value of "size" but not the creating an array "coefficient" of length "size". It will be better if you define the length of the "coefficient" array inside the constructor.
therefore the correct version should look like this:
private double[] coefficient ;
if(degree>=0)
degree = max;
size=max+1;
This is the class
Code:
        if(degree>=0)
            degree = max;
        size=max+1;
        i = subscript;
        return answer;
This is the main
Code:
The problem seems to be that your constructor does not initialize degree. Here's what I think is going wrong.
In main:
Code:
This causes the constructor to be called, with the max parameter set to 3.
Code:
    if(degree>=0)
         degree = max;
    size=max+1;
Since degree is uninitialized, there's no telling whether degree>=0 will be true. I'm not sure what the purpose of the max variable is - it could possibly be eliminated altogether, and you could have the parameter of the constructor be degree.
Thank you, and now, that example i used in the main should set a polynomial like
P(x) = 3 + 5x + 2x^3 and when i evaluate for x=7 should result in 724, but I'm getting 686 which is just 2x^3. Can anyone see what I did wrong?
Never mind it works properly now. Revised the code to this.
Code:
        if(max>=0)
            degree = max;
        size=max+1;
        i = subscript;
        for(int index=degree;index>=0;index--)
            answer += coefficient[index] * (Math.pow(x, degree));
            degree--;
            return answer;
Ok I will do that thank you.
