Troubleshooting Laptop Battery Detection Issues
  • Thread starter Thread starter R.Harmon
    Battery Laptop
A Sony VAIO laptop user is experiencing an issue where the battery is not recognized by the computer, indicating "not present" in the power meter. The user is hesitant to purchase a new battery for £139 without confirming whether the battery is indeed faulty. Suggestions include testing with another VAIO battery to determine if the issue lies with the battery or the laptop itself. There is a mention of a past recall of Sony batteries, prompting users to check if their battery is affected. Some users have resolved similar issues by performing a reset: shutting down the laptop, removing both the battery and AC power, then reinserting them. However, others continue to face the same problem despite trying this method, indicating that further troubleshooting may be necessary.
R.Harmon
Hi,
So I have a Sony VAIO laptop, and recently the batterys decided to stop being recognised by the computer (if I go to the power meter in the control panel, it reads the battery as "not present"), so I run off of AC power and disconnect the lead, the laptop just turns off. The problem is sony want £139 for a new battery, which is a little steep, and the last thing I want to do is replace the battery when that's not the issue. So I suppose my question is, is there anything else that could be causing the battery to not be recognised like this, other than the battery itself being faulty? Thanks for any help!
Rob
Computer science news on Phys.org
Do you know anybody else with a Vaio? You could swap batteries to see if the problem follows the battery or the laptop. If it stays with your laptop, it should be a pretty easy fix for a repair place familiar with Vaios. If the problem follows the battery, then a new battery would probably be the cheapest fix.
There was a huge recall of Sony batteries last year (or was it 2 years ago), is it possible you might have one of these batteries? If the machine is a couple of years old then you might want to check out the serial numbers against those of recalled batteries.
My Acer Timeline laptop battery stopped being recognized after I pulled it out while on AC power. It may be that your battery or the measuring circuit of the battery needs some kind of a reset.
I solved my problem by shutting down the laptop, then I pulled out the AC power cord AND the battery. Then I put the battery back in and rebooted. Now the battery was recognized.
ok so i have a similar problem. my vaio laptop (about 2.5 years old) recently froze while it was shutting off, so i pulled out both the battery and the ac adaptor and it shut down. i then put both back in and it turned back on, but in the bottom right corner it said änd still says "No battery is detected." i tried smallphi's solution, turning the computer off, taking both out, then putting both back in, but the same problem occurred. i know that the battery can't be the problem, because it has had no problems at all up until i did this. is there any other quick fixes to this?
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
18K
