True/False: Qualitative Thermodynamics Question
  • Thread starter Thread starter yaylee
    Thermodynamics
2 replies · 7K views
yaylee
Which of the following statements about entropy and heat engines are true? (There is more than one right answer!)
1)The entropy of the universe can never decrease
2) The COP (coefficient of performance) of a refrigerator can never be greater than 1
3) All Carnot engines are reversible
4) A refrigerator lowers the entropy of the volume inside
5) If the temperature of the cold reservoir increases with the temperature of the hot reservoir unchanged, the efficiency of a Carnot engine will increase
6) Any process that includes adding heat to an ideal gas will increase the entropy of the gas
7)It is impossible have a net transfer of heat from a cold reservoir to a warm reservoir
8) All Carnot engines are more efficient than all real engines
9) All heat engines operating between the same temperatures have the same efficiency
10)Adiabatic expansion will lower the temperature of a gas
11) The entropy of a system can never decrease
12) The efficiency of a Carnot engine can never be 1
Entropy = dQ/T
efficiency of Carnot Engine = 1 - (Tc/Th), where Tc = Temp of cold reservoir, Th = hot.
Coefficient of Performance C.O.P = Qc/W, where Qc = heat absorbed into cold reservoir
Work done in ANY cycle, W = Qh - Qc.
Note: I bolded the correct answer, with explanation below the correct statement!
By definition, entropy will be equal to 0 in a Carnot cycle, greater than 0 in a real cycle..
By definition, Carnot engines are quasi-static, reversible processes.
Decreasing entropy is analagous to saying you are "removing heat" from the refrigerator.
e = 1 - Tc/Th. Increasing Tc will decrease e.
By definition, dS = +dQ/T, so dS is positive.
Simple definition.
Simple definition.
At absolute zero, this will be true.
Pls point out where I may have missed a true statement, or marked a true statement which is actually false. Many thanks in advance for your help! Infinite appreciation !
1) True, because it’s the whole system.
2) False. http://wiki.answers.com/Q/Why_coefficient_of_performance_of_a_refrigerator_is_greater_than_1
3)True
4)True
5)True. Imagine the difference between a refridgerator and a freezer.
6) "Yes, thermodynamically. In statistical mechanics heat increases the number of microstates and thus entropy which is proportional to their log." quoted from anna v, http://physics.stackexchange.com/q/47435/11833
You can refer to this too https://www.physicsforums.com/showthread.php?t=177049
7)False. That’s what refridgerators do.
8)True.
9)False. For example, Carnot is the most efficient.
10) True. In adiabiatic, [tex]Q=0, TV^{\gamma -1}=constant[/tex] and [tex]PV^{\gamma }=constant[/tex ]<br /> 11) True<br /> 12)True. Your explanation is wrong: (When [tex]T_c[/tex] is) At absolute zero, this will be false.<br /> <br /> All your true/false is correct. Lol why do you even ask.[/tex]
My answers are in italics:
1)The entropy of the universe can never decrease. True
2) The COP (coefficient of performance) of a refrigerator can never be greater than 1 False
3) All Carnot engines are reversible True or False depending on whether you include external mechanical irreversibility. An engine operating on the Carnot cycle but whose output work is dissipated due to friction is not reversible.
4) A refrigerator lowers the entropy of the volume inside True
5) If the temperature of the cold reservoir increases with the temperature of the hot reservoir unchanged, the efficiency of a Carnot engine will increase False. Efficiency will decrease (Efficiency = 1-Tc/Th).
6) Any process that includes adding heat to an ideal gas will increase the entropy of the gas True
7)It is impossible have a net transfer of heat from a cold reservoir to a warm reservoir True or False, depending on what it means by "net" transfer of heat. If "net" refers to the transfer of heat in the Clausius statement of the second law: "No process is possible whose sole result is the transfer of heat from a body of lower temperature to a body of higher temperature.", then the statement is true. .
8) All Carnot engines are more efficient than all real engines False. It depends on the temperatures the engines operate between.
9) All heat engines operating between the same temperatures have the same efficiency False. This is true only for all Carnot engines operating between the same temperatures
10)Adiabatic expansion will lower the temperature of a gas False. An adiabatic free expansion of an ideal gas results in no change in temperature.
11) The entropy of a system can never decrease False. The entropy of the system + surroundings can never decrease
12) The efficiency of a Carnot engine can never be 1True but it can get arbitrarily close to 1 as Tc → 0K. Absolute 0 is unattainable even in theory.
AM
