Does Integral Zero Imply Function Zero?
  • Thread starter Thread starter RJLiberator
    Integrals
The discussion centers on the implications of integral zero in relation to continuous functions. It is established that if \( a = b \), then \( \int_{a}^{b} f(x)dx = 0 \) is true due to the absence of width. However, if \( a \neq b \), the integral can still equal zero even if \( f(x) \neq 0 \) for all \( x \in [a, b] \), as demonstrated by periodic functions like \( \sin(x) \). The discussion concludes that for \( D \), if \( \int_{a}^{b} |f(x)|dx = 0 \), then \( f(x) \) must equal zero for all \( x \) in the interval, provided \( f \) is continuous.
  • Understanding of definite integrals and their properties
  • Knowledge of continuous functions and their characteristics
  • Familiarity with periodic functions, specifically \( \sin(x) \)
  • Basic concepts of absolute values in mathematical functions
  • Study the properties of definite integrals in calculus
  • Learn about the implications of continuity in functions
  • Explore examples of periodic functions and their integrals
  • Investigate the role of absolute values in integrals and their effects on function behavior
Mathematics students, educators, and anyone interested in understanding the properties of integrals and continuous functions, particularly in the context of calculus and real analysis.
RJLiberator
True or False? Let a and b be real numbers, with a < b, and f a continuous function on the interval [a, b].
a) If a=b then \int^{b}_{a} f(x)dx = 0
My answer: This is TRUE, because while this integral would have a height, it would NOT have a width and area being l*w will result in 0.
b) If a \neq b, then \int^{b}_{a}f(x)dx \neq 0
My answer: This is FALSE, because there will exist a height and a width, however, half of the area can be negative area and half of the area can be positive area canceling each other out and creating 0 area
c) If a \neq b, then \int^{b}_{a}f(x)dx = 0, then f(x) = 0 for all x \in [a,b]
My Answer: This is FALSE, however, I am having trouble finding an example.
D) If a \neq b, then \int^{b}_{a}|f(x)|dx = 0, then f(x) = 0 for all x \in [a,b]
My Answer: EDIT: This is True.
Correct answers?
Thanks for checking in with me and guiding me.
Seems correct to me. Why did you repeat two times the c question? As an example you could for istance think to a periodic function on a symmetric interval. Can you figure it out?
Hi val, thanks for the help.
The difference between c and D is the absolute value of f(x).
Periodic function on a symmetric interval? Would sin(x) be one?
Yes sin(x) integrated between -pi and pi is a perfect example for c. I didn't notice the absolute value, then are you sure about d?
Likes 1 person
OH. Wow. I see it now more clearly.
The absolute value negates the situation. It turns the negative area into a positive area causing the statement to be true.
Thanks 0_0.
Does anyone have any tips on proving these statements that I claim as true? More mathematically rigorous proofs.
Okay, I am having a little problem with C and D.
If I use sin(x) and integrate it between -pi and pi, then I receive an area of 0. But what does it mean for f(x) = 0 for all x as a set of [a,b] ? Do I merely plug in a number from the set into f(x). Example: sin(-pi/2) = -1 to disprove this statement?
If so, how come in D it wouldn't work the same way?
Well let me throw something out for a just because it seems like you have a relatively descent idea of how to go about this. I hope this will give you an idea as to how to state d.
Let ##F(x) = \int f(x)dx##
then ##\int_{a}^b f(x)dx = F(b) - F(a)##
What happens if a = b?
Now for d. I first want to clarify your wording:
Did you intend the bolded 'then' to be 'and'?
If so, state what you do know about ##|f(x)|## i.e. what do the | | symbols do to the possible outputs of f(x)?
Hi Bigyellowhat,
Yes, I did intend for the bolded to be 'and.' My apologies.
The possible outputs of f(x) must be positive in this scenario.
So this would mean that the statement cannot exist? It must be false.
The only value that makes f(x)=0 in D is a=b and a cannot equal b.
D is rather tricky. I understand it now, but if anyone has concrete examples, that would be great.
Essentially, I have to take the value of the integral of f(x)dx as equal to 0, even tho a cannot equal b.
Thus, the limited subset we are offered must always equal 0.
Interesting.
Interesting.
Note that for D to be true, f must be continuous. First, therefore, you might like to try to find a non-continuous f for which the integral is 0, but f is not identically 0.
To prove it for continuous f, you probably need to know the definition of continuity.
Note: it might simplify things a little just to assume that f(x) ≥ 0 and drop the modulus.
Likes 1 person
  • · Replies 20 ·
