Trying to calculate relative speed between two moving points
The discussion revolves around calculating the relative speed between two moving points in a 2D rectangular coordinate system. Participants explore the mathematical formulation of distance and relative velocity, as well as the implications of their calculations. The scope includes mathematical reasoning and conceptual clarification regarding derivatives and relative motion.
  • One participant presents the positions of two points, P and M, and defines the distance and relative speed between them, questioning the correctness of their approach and seeking help with derivatives.
  • Another participant notes that explicit expressions for the positions are necessary to derive the relative speed and questions the use of a negative sign in the relative speed formula.
  • A different participant emphasizes that without explicit expressions, only derivatives of the components can be obtained, and also questions the rationale behind the negative sign for relative speed.
  • One participant suggests using specific functions to illustrate the concept of relative velocities, arguing that the distance between points does not influence their relative velocities.
  • Another participant expresses skepticism about using vector addition of derivatives to find relative velocities, seeking clarification on how this approach works.
  • A later post introduces a scenario involving two particles moving along different vectors, providing a numerical example to illustrate how relative velocities depend on vector directions and magnitudes.
Participants express differing views on the relationship between distance and relative velocity, as well as the necessity of explicit expressions for position to derive relative speed. The discussion remains unresolved, with multiple competing perspectives on how to approach the problem.
Limitations include the absence of explicit expressions for the positions of points P and M, which affects the ability to derive the relative speed accurately. Additionally, the discussion includes assumptions about the nature of relative velocities and the implications of vector directions.
hkBattousai
There are two points on the 2D rectangular coordinate system, namely P and M.
Their positions are function of time and are:
Position \, of \, P: \, (p_x(t), \, p_y(t))
Position \, of \, M: \, (m_x(t), \, m_y(t))
Distance between them is:
R(t) \, = \, \sqrt{(p_x - m_x)^2 \, + \, (p_y - m_y)^2}
And the relative speed (magnitude of relative velocity) between them is:
V_{pm}(t) \, = \, - \frac{dR}{dt}
Is it correct up to this step?
If so, can you please help me take this derivative?
If not, how do I calculate this relative speed?
Any help will be appreciated.
To get the derivative you need explicit expressions for the components of P(t) and M(t). Based on the information presented, all you can get is an expression involving the derivatives of the components.
Aside: why the minus sign for the relative speed?
There are no explicit expression. Speeds of these points are arbitrary.
Man's intuition :)
Think of it a little, correct me if I'm wrong...
Try something like y1= x^2 and y2 = x
let the x component velocities be the same for both functions then the y component velocities of the functions at any point as respects x would be the derivative of the functions at those points (slope) and the relative velocities of those point are the difference of the y component velocites.
I don't think the distance between the 2 points has anything to do with relative velocities since the 2 function above cross at x = 1.
I think that is correct but correct me if I am wrong.
jim pohl
dont see how vector addition of derivatives can find relative velocites between points could you give more details?
My understanding is that vector addiiton gives a new vector but then that new vector only represents a direction and magnitude but as I already pointed out the distance beween two points has nothing to do with relative velocity of those points - maybe I am not understanding your post i will study further.
later: do you mean the vector addition of the y and x component velocites? OK maybe thatll work - need to go over this
(If you have trouble reading this try holding down CTRL key while you move the scroll wheel on your mouse.)
A particle travels along vector A in the direction shown and crosses vector C at point a
Another particle travels along vector B in the direction shown and crosses vector C at point b
What is the relative velocity of points a, b if the particle along vector A has a velocity
of 2 feet per second and the particle along vector B has a velocity of 3 feet per second?
(using degrees in this example)
V = VA cos 110 + VB cos 40 = 2 cos 110 + 3 cos 40 = 1.61409 feet per second
The relative velocity of points a,b can also be zero. For the above triangle, any positive velocity along vector A will have a velocity along vector B such that the relative velocity of a,b will equal zero.
Example
The particle along vector A has a velocity of 2 feet per second as it did before. What is the velocity of the particle along vector B so relative velocity of points a, b equal zero?
-2 cos 110 / cos 40 = .89295 feet per second.
so relative velocity of 2 moving points are dependent on the velocity of a particle along the vector and the angles between vectors.
Possible implications.
An observer at point b looks along vector C and notices that a certain star at point a does not have a red shift. But that star could be traveling at .2C along vector A while the observer is traveling at .089295C along vector B. Einstein did indicate that there was no absolute motion. The reasoning is that the relative velocity of objects are dependent on their vector directions as well as the velocity along the vectors.
  • · Replies 25 ·
  • · Replies 22 ·
  • · Replies 20 ·
