Trying to understand space-time diagrams
  • Context: Undergrad
  • Thread starter Thread starter Kashmir
    Diagrams Space-time
61 replies · 8K views
Kashmir
I need your help. I've just begun learning about space time diagrams. Below is my doubt:An event is shown as a point on a spacetime diagram
Another frame has coordinates of space and time as:
##\begin{aligned} c t^{\prime} &=(\cosh \theta)(c t)-(\sinh \theta) x \\ x^{\prime} &=(-\sinh \theta)(c t)+(\cosh \theta) x \\ y^{\prime} &=y \\ z^{\prime} &=z \end{aligned}##It's said that the spacetime diagram corresponding to the new frame could be drawn on the previous spacetime diagram as shown below:
Then is that the time coordinate of the event in the new frame can be found as shown below (red line is parallel to the ##x′## line, ##(a,b)## is the intersection point of red line with ##ct′##axis)
Hence the new time coordinate is
##c t^{\prime}=\sqrt{a^2+b^2}##
? Is that correct?
No, it is ##\sqrt{a^2-b^2}##.
Why? Can you please explain it?
Because Minkowski space geometry is not Euclidean. The Minkowski space version of the Pythagorean theorem is ##s^2 = (ct)^2 - x^2##.
One more proof of my caution with Minkowski diagrams in the introductory SR lecture! It must be made clear before (!) drawing the first Minkowski diagram that there is no Euclidean geometry to be applied in it. The entire geometry in the Minkowski plane is governed by the fundamental Lorentzian form with signature (1,1) not by that of the Euclidean fundamental form of signature (2,0). And only the Euclidean one is a scalar product, i.e., positive definite, and only this one induces a norm ("length", "metric").
Well ... I think this is a question of terminology, technically it is a scalar product (a product of vectors that produces a scalar). It is, however, not an inner product, which necessarily comes with the requirement of positive definiteness. I have seen "scalar product" used in the more general sense as well as in the sense of being equivalent to an inner product (e.g., on Wikipedia (see second image) ... although that's not a solid reference of course).
The square of "distance" in Minkowski spacetime is not given by the Euclidean formula ##{(c\Delta t)^2+\Delta x^2}##, but by the Minkowski equivalent ##{(c\Delta t)^2-\Delta x^2}##. So the "length" of the line from the origin to ##(a,b)## (which is the time along it since this is a timelike interval) is ##\sqrt{a^2-b^2}##.
It is because of this
Notice that you used the hyperbolic ##\cosh## and ##\sinh## instead of the circular ##\cos## and ##\sin##. A circle is defined as ##r^2=x^2+y^2## but a hyperbola is defined as ##r^2=-t^2+x^2##. So when you are using hyperbolic "distances" you do hyperbolic rotations and vice versa.
This means that the distances you draw on the diagram are not directly the intervals in spacetime, and the angles that you draw on the diagram are not directly the rapidities in spacetime. On the paper distances are defined with circles and in spacetime intervals are defined with hyperbolas.
Ok is this how we interpret the space-time diagram: Given a point as shown in the figure, we find the projections of that point on the axis, in our case we've oblique axes, then the coordinates are given as:
##\begin{array}{l}
c t^{\prime}=\sqrt{a^2-b^2} \\
x^{\prime}=\sqrt{c^2-d^2}
\end{array}##Now let's say I've another space-time diagram as shown
In order to find the space coordinate of the point shouldn't I first find the projection on the ##x## axis and then write : ##x=\sqrt{x_0^2-0^2}##,which is simply how we used to do in euclidean geometry.
Dale said:
Yes, that still is the same.
Yes, but it makes the procedure consistent throughout.
Ok, that seems to be once more something not uniquely defined. My math professors always insisted on the positive definiteness of a scalar product (bilinear form in real and sesquilinear form in complex vector spaces). The analogue for the more general case of an "indefinite scalar product" was named the "fundamental form" of a (real) vector space.
I still don't understand how the angle between the two x and x'axes is ##\theta##?
Book writes
"FIGURE 4.13 A Lorentz boost as a change of coordinates on a spacetime diagram. The figure shows the grid of ##\left(c t^{\prime}, x^{\prime}\right)## coordinates defined by ##(4.18)## plotted on a ##(c t, x)## spacetime diagram. The ##\left(c t^{\prime}, x^{\prime}\right)## coordinates are not orthogonal to each other in the Euclidean geometry of the printed page. But they are orthogonal in the geometry of spacetime. (Recall the analogies between spacetime diagrams and maps discussed in Example 4.1.) The ##\left(c t^{\prime}, x^{\prime}\right)## axes have to be as orthogonal as the ##(c t, x)## axes because there is no physical distinction between one inertial frame and another. The orthogonality is explicitly verified in Example 5.2. The hyperbolic angle ##\theta## is a measure of the velocity between the two frames"
The transformation is given as
##\begin{aligned} c t^{\prime} &=(\cosh \theta)(c t)-(\sinh \theta) x \\ x^{\prime} &=(-\sinh \theta)(c t)+(\cosh \theta) x \\ y^{\prime} &=y \\ z^{\prime} &=z \end{aligned}##To find the angle ##x'## axes makes with ##x## axes I use
##0=(\cosh \theta)(c t)-(\sinh \theta) x## to get its slope as ##Tanh(\theta)## and hence the angle is ##{Tan}^{-1}(Tanh(\theta))## but the book says the angle is ##\theta## ? What did I do wrong?
##\theta## is a hyperbolic angle, not a Euclidean angle. The angle ##\theta## you show in your diagram is a Euclidean angle, but that's not what ##\theta## is in your book.
You treated ##\theta## as if it were a Euclidean angle; that's what using the inverse tangent function is doing.
You used a circular inverse. It should be hyperbolic. I.e. ##{\tanh}^{-1}(\tanh(\theta))## and not ##{\tan}^{-1}(\tanh(\theta))##
This is hyperbolic geometry. Intervals are given by ##s^2=-t^2+x^2## and correspondingly all of the trig functions are hyperbolic as well.
Yes, be cautious.
Also be cautious with position-vs-time diagrams in PHY 101!
Here too,
The entire geometry in the Galilean plane is governed by two fundamental degenerate forms with signature (1,0) and signature (0,1) not by that of the Euclidean fundamental form of signature (2,0). And only the Euclidean one is a scalar product, i.e., positive definite, and only this one induces a norm ("length", "metric“).
TL;DR
The geometry of any position-vs-time diagram (minkowski or Galilean) is not Euclidean!
(Be careful about drawing such diagrams in PHY 101!)
Walking through a field of Land mines!
Don't be afraid. It's not that scary.
We're here to help.
  • Love
We're here to help.
Thank you
PeterDonis said:
##\theta## is a hyperbolic angle, not a Euclidean angle. The angle ##\theta## you show in your diagram is a Euclidean angle, but that's not what ##\theta## is in your book.You treated ##\theta## as if it were a Euclidean angle; that's what using the inverse tangent function is doing.
. So on the piece of paper the lines ##x, x'## have an angle of ##{\tan}^{-1}(\tanh{\theta})## but in the Minkowski space the angle is ##\theta##? Is that right?
Book writes
QED! Again someone confused by the fatal idea to call rapidities "angles" and then even draw them in a Euclidean way in the Minkowski plane, which has no Euclidean geometry by definition.
Rapidities are no angles! You cannot draw them as angles in a Minkowski diagram. You have to construct the hyperbolae and then they are areas!
Hence the notation arsinh, artanh, etc. not arcsinh and arctanh as many seem to believe.
  • Love
Ok everything I've so far said has been wrong.
However Is it true that the hyperbolic angles of all points on the line ##x'## are same and equal to ##\theta## ?
The hyperbolic angles defined by the sectors on the unit hyperbolas?
You have to remember that the Minkowski plane is not the Euclidean plane, so the Minkowski diagram is an honest representation of the Minkowski plane but it is not an accurate representation. Just like a Mercator projection is an honest but not accurate representation of the surface of the Earth. You can't use Euclidean notions like length, angle, trigonometry. You have to use the Minkowski equivalents of interval, rapidity, and hyperbolic functions. They fit together in the same way - e.g. you take an inverse hyperbolic tangent where you would "intuitively" take an inverse tangent - which is why the answer is ##\theta=\tanh^{-1}\tanh\theta##, not ##\tan^{-1}\tanh\theta##
There are no angles! The meaning of the rapidity (here I use ##u## as a parameter) is as in the following picture:
The curve is the unit hyperbola
$$\vec{x}(u)=\begin{pmatrix} x(u) \\ y(u) \end{pmatrix}=\begin{pmatrix} \cosh u \\ \sinh u \end{pmatrix}, \quad u \in \mathbb{R}.$$
The green-shaded area can be parametrized as
$$\vec{x}(\lambda,u')=\lambda \vec{x}(u'), \quad \lambda \in [0,1], \quad u' \in [-u,u].$$
The area then is calculated using the Jacobi determinant
$$J=\partial_{\lambda} x \partial_u y - \partial_{\lambda} y \partial_u x=\lambda (\cosh^2 u'-\sinh^2 u')=\lambda,$$
i.e., the area is
$$A=\int_{-u}^u \mathrm{d} u' \int_0^1 \mathrm{d} \lambda \lambda = u,$$
i.e., ##u## is the area of the "hyperbolic segment" shaded in green.
That's why the inverse functions of the hyperbolic functions are called "area functions", i.e., arcosh, arsinh, artanh.
In Euclidean geometry, one often hears the definition of angle as
##(\rm{angle})=\frac{\mbox{(arc-length along a circular arc)}}{\mbox{(radius of that circle)}}##.
This quantity is equal to the additive parameter ##\phi## used in a rotation,
and ##\tan\phi## is the slope and ##\cos\phi## is equal to the projection of a unit vector with respect to a reference axis.
The range ##0\leq \phi < 2\pi## covers the range of all possible directions.
In Minkowski spacetime geometry, one can declare the definition of M-angle as
##(\mbox{M-angle})=\frac{\mbox{(M-arc-length along a M-circular arc)}}{\mbox{(M-radius of the M-circle)}}##,
##(\mbox{rapidity})=\frac{\mbox{(spacelike-arc-length along a hyperbolic arc)}}{\mbox{(timelike-radius of the hyperbola)}}##
This quantity is equal to the additive parameter ##\theta## used in a Lorentz boost transformation,
and ##\tanh\theta## is the dimensionless-velocity and ##\cosh\theta## is equal to the time-dilation factor with respect to reference observer 4-velocity.
The range ##-\infty < \theta < \infty## covers the range of all possible timelike directions for a 4-velocity.
One can write an analogous description for Galilean spacetime geometry.
It turns out the Galilean analogue of the tangent function (Yaglom's ##\rm tang##)
satisfies ##{\rm tang\ }\eta=\eta##... so that, in Galilean relativity, velocities are additive [unlike in Minkowski spacetime geometry and "slopes" in Euclidean geometry.]
See page 7 of my old Spacetime Trigonometry poster:
https://www.aapt.org/doorway/Posters/SalgadoPoster/Salgado-GRposter.pdf
Note: "rapidity" should be drawn using a hyperbolic arc, not a circular arc!
The above can also be expressed in terms of sector-areas* on a plane (as noted by @Orodruin and @vanhees71).
While the sectors are metric dependent (due to the choice of "circle"),
that "two areas are equal", or more generally, that "two given areas have a certain ratio"
is independent of metric in the plane...
since "comparing areas in the same plane" is an affine concept (not a metrical one).
It's akin to "comparing segments on the same line".
(*) Due to @Orodruin and @vanhees71, I have grown to embrace the "sector-area"- interpretation. I found a way to use it in my "rotated-graph paper" approach to describe rapidity and, analogously, proper-time for piecewise-constant-accelerated motions [forthcoming paper].
However, I have not abandoned the "arc-length of a unit circle"-interpretation because it works and because it makes contact with the more commonly used definition of angle.
i.e., the area is
So you defined rapidity ##\theta## as area that lies inside two lines that touch the unit hyperbola . If rapidity is ##\theta## then one of the intersection point of hyperbola with the line is ##(cosh(\theta), sinh(\theta)##.
Now getting back to our figure :
The ##\theta## here is rapidity?
How are you defining ##\theta## on that diagram? For example, if we take ##v \to c##, what is the value of a) the rapidity; b) the ##\theta## shown on your diagram?
I am myself trying to understand that. My book gives me a transformation as:
And gives me a plot :
And then says that ##\theta## is the hyperbolic angle.
I've understood how we define hyperbolic angles or rather call them rapidity as shown by vanhees.
Now I want to link that concept of rapidity with the ##\theta## that's drawn on the book.
That's been explained several times already. Hyperbolic angles are a more abstract mathematical idea. They do not correspond to the internal angles on triangles drawn on a sheet of paper.
To answer my own question, as ##v \to c## the rapidity ##\theta \to \infty##. Whereas, the physical (Euclidean) angle shown on the diagram tends to ##\frac \pi 4##.
That means you have to reconcile the abstractness of Minkowski geometry with the physically Euclidean nature of any diagram you draw.
I would only add that algebra will never deceive you like this!
Well, not generally. It just so happens that the area forms of 1+1-dimensional Minkowski space is equivalent to the area form of 2-dimensional Euclidean space. A different metric in the plane however will not have the same area form.
