Turbulence - just a phenomenon of cavitation?
Turbulence and cavitation are distinct phenomena in fluid dynamics. Turbulence involves chaotic flow patterns resulting from tiny perturbations in a fluid, requiring an average velocity to exist. In contrast, cavitation is the formation and implosion of vapor-filled cavities in a liquid due to rapid pressure changes, which can occur even in standing fluids. Notably, cavitation can damage sonar transducers due to impedance mismatch and can emit light pulses under specific conditions, known as sonoluminescence.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure changes in liquids
  • Familiarity with sonar technology and its components
  • Basic concepts of phase changes in fluids
  • Research the principles of fluid dynamics and turbulence modeling
  • Explore the effects of cavitation on sonar systems and mitigation techniques
  • Study the phenomenon of sonoluminescence and its implications
  • Investigate the mathematical modeling of turbulence in both liquids and gases
Fluid dynamics researchers, engineers working with sonar technology, and students studying advanced fluid mechanics will benefit from this discussion.
Loren Booda
Turbulence -- just a phenomenon of cavitation?
Is turbulence exclusively cavitation of a fluid?
Please give me your insight on this idea.
No. Turbulence is a completely separate phenomenon from cavitation. Turbulence has to do with tiny perturbations in a flow growing to the point where the flow becomes highly chaotic.
Just to add in, cavitation has to do with fluids under high force (as in a boat's prop):
WIkipedia.org said:
Cavitation is the formation and then immediate implosion of cavities in a liquid – i.e. small liquid-free zones ("bubbles") – that are the consequence of forces acting upon the liquid. It usually occurs when a liquid is subjected to rapid changes of pressure that cause the formation of cavities where the pressure is relatively low.
http://en.wikipedia.org/wiki/Cavitation
Additionally, cavitation can occur near the face of a high power sonar transducer (transmitter). When the acoustic intensity gets so high that the low-pressure of the wave is strong enough to rip the water apart, it creats tiny bubbles of dissolved gas. Cavitation is "bad" for a sonar system because it creates a huge impedance mismatch between the transducer and the water. Also the imploding bubbles can physically damage the transducer face.
One interesting sidelight: If the conditions are right the cavitation bubbles will emit a picosecond pulse of light, the color depends on the kinds of dissolved gasses. This is called "sonoluminesence".
To emphasize what has already been said,
They are different and unrelated phenomena.
In particular you need a flowing fluid to exhibit turbulence, it cannot exist in a fluid with no average velocity.
Turbulence is a property of flow.
Cavitation, on the other hand can, and does, exist in a tank of standing fluid. It is not a property of flow.
edit:
Turbulence can, and does, occur in both liquids and gasses. It can either be a local or global property of the flow.
Cavitation occurs when the local input of energy to the fluid is sufficient to cause phase change from liquid to gas within the body of the fluid. As such it can only occur in liquids.
go well
  • · Replies 28 ·
