How Do We Find Turn-On Voltage from an I-V Graph?
The discussion revolves around determining the turn-on voltage from an I-V graph, specifically in the context of diode behavior. Participants explore different methods for extracting this voltage from the graph, including the use of semi-log plots and linear extrapolation techniques.
  • Homework-related
  • One participant asks how to determine the turn-on voltage from an I-V graph and mentions conflicting methods learned from a professor and found online.
  • Another participant questions whether the discussion pertains to a diode and suggests that the attachment size could be reduced for better accessibility.
  • A participant notes that the turn-on voltage does not have a universal definition and emphasizes the importance of following specific instructions for academic purposes.
  • One participant inquires about the factors that affect the turn-on voltage.
  • Another participant suggests looking up the "diode equation" as a potential resource for understanding factors influencing turn-on voltage.
Participants express differing views on the methods for determining turn-on voltage, with no consensus on a single approach. There is also a lack of agreement on the definition of turn-on voltage itself.
Participants reference different methodologies for determining turn-on voltage, highlighting the dependence on specific instructions and the variability in definitions. The discussion does not resolve the mathematical or conceptual steps involved in the analysis.
harryexe
How do we determine the turn-on voltage from a given I-V graph?
2. I have attached the picture. The graph which i need to obtain the turn-on voltage from is on the right.
3. I have searched the web and the closest answer I can find is from this website (link can't be posted due to lack of post) It says that "One method to consider begins with plotting the I–V data on a semi-log graph. Your
data should approximate a straight line, indicative of the exponential nature of the current
voltage relationship. An operational definition of the threshold voltage could be that value
of the bias voltage when the current reaches 0.01 mA. Extrapolate your I–V curves to where
they cross 0.01 mA current and use that as the working value of V0." However, during the briefing prior to doing the experiment and obtaining my data, the professor told find a gradient at one point of the curve and find the point where it intercept the x-axis (the voltage) which will give me the turn on voltage. No semi-log graph is needed here. But which point from the graph do i find the get the gradient to extrapolate? Thank you!
Hi harryexe. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Are we to assume this is for a diode? :wink:
I don't believe your 1.8MB attachment conveys any more information than would something of more reasonable size, such as 300KB. As a courtesy to readers, would you make sure that future attachments are of a less extravagent size? Most paint/photo programs allow you to save to a smaller size.
Turn-on voltage has no one universal definition. I'm afraid you are going to have to abide by the instructions you have been given, if you wish to satisfy the requirements of that person who will be marking your work. Turn-on voltage is not usually regarded as a precise parameter.
Thank you for your reply =] In addition, what exactly are the factors affecting the turn-on voltage?
Look up the "diode equation".
