How does the Twin Paradox demonstrate the effects of general relativity?
  • Context: Graduate
  • Thread starter Thread starter PatrickPowers
    Paradox Twin paradox
The Twin Paradox illustrates the effects of general relativity through the use of the equivalence principle, as explained by Professor Daniel F. Styer. In an accelerating spaceship with two clocks, one at the tail (Clock T) and one at the nose (Clock N), the clocks experience different time intervals due to their separation. Clock N perceives signals from Clock T as spaced further apart, while Clock T sees signals from Clock N as closer together. This asymmetry leads to a definitive conclusion that Clock T will lag behind Clock N upon reunion, demonstrating the impact of distance on time dilation in accordance with special relativity.
  • Understanding of general relativity principles
  • Familiarity with the equivalence principle
  • Basic knowledge of time dilation concepts
  • Awareness of special relativity equations
  • Research the implications of the equivalence principle in gravitational physics
  • Study time dilation effects in accelerating frames of reference
  • Explore the mathematical formulation of special relativity equations
  • Investigate experimental confirmations of the equivalence principle
Physics students, educators, and anyone interested in the practical applications of general relativity and the nuances of time dilation effects.
PatrickPowers
Here is an explanations due to Daniel F. Styer, Prof Physics at Oberlin Daniel's original is at https://mail.google.com/mail/?ui=2&view=bsp&ver=ohhl4rw8mbn4".
He uses general relativity and the equivalence principle. The equivalence principle is not entirely true -- it IS possible to distinguish between gravity and acceleration -- but Daniel says that it is good enough for this purpose, that no one has ever succeeded in measuring the difference. Consider an accelerating spaceship and two clocks. Clock T is in the tail and clock N is in the nose. Each clock sends out a signal once a second. The situation is not symmetric. Clock N measures that clock T's signals come more than one second apart, and clock T measures clock N's signals as closer than a second apart. Both clocks agree that T is slower: no paradox.
What's neat about this is that this difference depends on the distance between T and N. The further apart, the greater the differential in speed. This is what you need to get agreement with the special relativity equations: it depends directly on the distance between the clocks. When the two clocks are reunited the T clock will be behind the N clock by the appropriate amount.
I am disturbed by the statement "The equivalence principle is not entirely true". I was under the impression that the equivalence principle is one of the best confirmed statements in physics - confirmed to ridiculously high precision (1 part in 10 to the 13 or something like that).
What I meant was that it is possible to distinguish a gravitational field from an accelerative psuedoforce. I read now that the equivalence principle is the equivalence of inertial and gravitational masses. Sorry about that.
  • · Replies 115 ·
9K
  • · Replies 70 ·
  • · Replies 21 ·
  • · Replies 48 ·
  • · Replies 31 ·
  • · Replies 208 ·
16K
  • · Replies 24 ·
  • · Replies 40 ·
