Two masses connected by spring with initial velocity
  • Thread starter Thread starter Jahnavi
    Spring Two masses
18 replies · 3K views · last reply
Jahnavi
i)
##x_{cm} = \dfrac{m_1x_1 + m_2x_2}{m_1 + m_2}##
At any time t , ##x_{cm} = v_0t## and
##x_1= v_0t - A(1-\cos{ωt})##
From the above two ,
we get ##x_2 = v_0t + \dfrac{m_1}{m_2}A(1-\cos{wt})##
I'm not clear what to do in part (ii) .
I might have to use Energy conservation between times t=0 and time when the spring is in maximum elongation , but then what is the time when this happens and what is the maximum elongation of spring . Will it be the same amount by which it is compressed i.e L0
To answer that, consider energy totals.
I get ## A = \frac{m_2 L_0}{2(m_1+m_2)}##
It cannot be asymmetric in m1, m2. Please show your working.
Edit: I retract that. I did not register that the definition of A is asymmetric in m1, m2.
x1(t) has m2 and x2(t) has m1 in the numerator in their second terms respectively .
I rechecked my work .There should not be a 2 in the denominator .
Now the answer matches with the answer key :smile:
If you think ##A=\frac{m_2L_0}{m_1+m_2}## is incorrect please let me know .
Sorry, you are right. It is asymmetric because of the way A is defined.
Thank you .
Is the motion of m1 and m2 SHM with respect to the Center of Mass ?
Jahnavi said:
Thank you .
Certainly.
haruspex said:
Certainly.
SHM is of the form kcos(ωt+Φ) , but in this question it is k(1-cosωt) ?
Are the two equivalent ?
It is still SHM, just around a different equilibrium point.
Perhaps I misunderstood your question. Did you mean, it is SHM with the common mass centre as equilibrium point? If so, no.
Are m1 and m2 performing SHM as seen from Center of Mass frame ?
If so , then x1(t) and x2(t) should be equal to xcm + kcos(ωt+Φ) ?
This is not happening in this problem .
Instead they are written as xcm + k(1-cos(ωt) .
Your equation for SHM is unnecessarily restrictive. Let me quote Wikipedia:
The motion of a particle moving along a straight line with an acceleration which is always towards a fixed point on the line and whose magnitude is proportional to the distance from the fixed point is called simple harmonic motion [SHM]​
In the centre of mass frame, we can choose a point at offset k as that fixed point. It does not need to be the origin of the frame.
Sorry I don't understand . Please explain in the context of above setup .
Is x = A(1-cosωt) an SHM ?
Yes. There is a fixed point, x=A, such that the acceleration towards it is proportional to the distance from it.
So , even though the frame (CM frame) is moving , the acceleration is proportional to a fixed point .
Where is that fixed point in this problem ?
A point that is fixed within the frame.
In the ground frame it is not SHM. in the common mass centre frame there is a fixed point (k) satisfying the conditions to make it SHM.
Is the fixed point in the frame necessarily the point of equilibrium for the SHM in that frame ?
In this problem , for m2 , is the fixed point a distance ##\frac{m_1L_0}{m_1+m_2}## from the CM (origin) ?
Similarly , for m1 , is the fixed point a distance ##\frac{m_2L_0}{m_1+m_2}## from the CM (origin) ?
So , in the CM frame the displacement of m2 from the fixed point is basically ##-cosωt## ?
##-cosωt = cos(ωt+π)##
With respect to the fixed point in the CM frame, the displacement of m2 turns out to be x=kcos(ωt+π) which is indeed an SHM .
Is my understanding correct ?
Yes to all the above.
