Two waves Interfereing resulting waves interferes with another wave
In summary, the two waves interfere with each other and the resulting wave has a different frequency and period than the original waves.
c-murda
67
[SOLVED] Two waves Interfereing...resulting waves interferes with another wave
Two traveling sinusoidal waves given by
Y1(x,t) = 3.87 sin (2.00x - 40.0t) and Y2(x,t) = 3.87 sin(2.00x - 40.0t + 120deg.)
interfere. The resulting wave interferes with
Y3 ( x, t) = 3.87 sin ( 2.00x- 40.0t)
i am confused...do i add the two first waves together, then add that wave with the third wave? do i need to change my degrees to radians?
Welcome to PF!
Sounds good to me!
I shouldn't think so.
alright so i guess i need to know how to add waves...
There are some rather obvious trig identities that you should be using here. Do you have a table of trig identities? If so, can you find one in which two sine functions are being added together?
i have my physics book which doesn't go to sinusoidal waves
Try looking for the angle-sum identity for sine. If you can't find it in your physics text, try a mathematics text or alternatively have a look on the internet :wink:
thnx... you mean like
sin(A+B) = sinAcosB + cosAsinB
i don't understand how that applies to the waves adding tho
Sorry, my bad! I meant sum to product formulae :redface:
Well, your waves are sinusoidal functions aren't they?
I'm talking about trig identities that come from a typical course in College Algebra and Trigonometry or Precalculus. Surely such a math course would be a prerequisite for your physics course?
ynet(x, t) = y1(x, t) + y2(x, t)
= Asin(wt - kx) + Asin(wt - kx + f)
= [2Acos 1/2(theta)]sin(wt -kx + 1/2 f).
And what is "theta"?
originally its 120 so...theta would be 60 for the first two interference and 30 for the 2nd interference?
sry i don't why the f's are f's they should be thetas
Right. And it doesn't matter if you call them all f's or thetas, as long as they are the same symbol.
So there is your formula for adding two sinusoidal waves with the same amplitude and frequency, but different phase angles.
ok so now i have a few more questions about the reamaing part of the problem.
its ask for
amplitude:
2ym cos 120/2 = 2*3.87*cos 60 = 3.87 (interference of 1+2)
2ym cos 60/2 = 2*3.87*cos 30 = 6.70(interference of resultant and 3)
correct?
Phase = 120/2 = 60 (interference of 1+2)
60 / 2 = 30 (interference of resultant and 3)
wavelength = i need help here...isn't it lambda?
defined as 2pi/k
frequency
defined as w = 2piF ; F is frequency?
defined as w = 2pi/T ; since f = 1/T
so F = 1/T
period:
wave number
this is k right?
i have 715 deadline please help
You are correct on all counts.
period
what about the period
defined as 2pi/k
so does that mean the final wavelength will be just pi?
c-murda said:
frequency
so F = 1/T
so does that mean final frequency will be 6.36?
period:
c-murda said:
wave number
this is k right?
that mean k= 2?
Those are all correct. And since you got the frequency, you can easily get the period.
for the final period would it be .157?
Yes indeedy.
What is wave interference?
Wave interference is the phenomenon that occurs when two or more waves meet and combine in a way that affects their amplitudes, resulting in a new wave pattern. This can happen with any type of wave, including electromagnetic waves, sound waves, and water waves.
How does wave interference occur?
Wave interference occurs when two waves with the same frequency and amplitude meet and overlap in space. They can either constructively interfere, where the amplitudes add up and result in a larger amplitude, or destructively interfere, where the amplitudes cancel each other out and result in a smaller amplitude.
What is the difference between constructive and destructive interference?
Constructive interference occurs when two waves with the same frequency and amplitude meet and the amplitudes add up, resulting in a larger amplitude. Destructive interference occurs when two waves with the same frequency and amplitude meet and the amplitudes cancel each other out, resulting in a smaller amplitude.
How does the phase difference between waves affect interference?
The phase difference between waves refers to the difference in their starting points or crests. When two waves with a phase difference of 0 or a multiple of 2π meet, they will constructively interfere. If the phase difference is a multiple of π, they will destructively interfere. Any other phase difference will result in a combination of constructive and destructive interference.
Can wave interference occur with more than two waves?
Yes, wave interference can occur with any number of waves. If multiple waves are present, they will all interfere with each other, resulting in a complex pattern of constructive and destructive interference. This can be seen in phenomena such as diffraction and standing waves.
