Can Ubuntu Run Efficiently on an External SSD?
  • Thread starter Thread starter member 428835
    Ssd Ubuntu
Ubuntu can be booted from a portable SSD connected via USB, but performance may be suboptimal, especially if the laptop lacks USB 3.0 ports. Users reported that internal SATA SSDs provide significantly better performance compared to external M.2 devices connected through USB. For optimal results, installing an internal SSD is recommended, particularly if the laptop supports M.2 connections. Upgrading the BIOS may be necessary for older machines to ensure compatibility.
  • Understanding of Ubuntu installation processes
  • Familiarity with SSD types: SATA and M.2 NVMe
  • Knowledge of USB standards: USB 3.0 and USB-C
  • Basic BIOS configuration skills
  • Research the performance differences between SATA SSDs and M.2 NVMe SSDs
  • Learn how to update BIOS on older laptops
  • Explore the installation process for Ubuntu on internal SSDs
  • Investigate external SSD enclosures and their impact on performance
This discussion is beneficial for system administrators, IT professionals, and users looking to optimize Ubuntu performance on older laptops, particularly those considering SSD upgrades.
member 428835
Hi PF!
Can I boot Ubuntu from a portable SSD on a computer, say a laptop? If I run ubuntu from a portable SSD plugged into a usb drive, will it run slow? We have this old computer in my lab, but it's Windows and runs Ubuntu from a VM, so super slow and awful memory. Or should I just buy another SSD, plug it into the motherboard, and go from there? What do you recommend?
Computer science news on Phys.org
Yes.
Maybe. How slow is slow?
That will work too.
Likes member 428835
Vanadium 50 said:
Yes.
That will work too.
How slow? I was thinking about using an M.2 SSD with 3400 megabytes/s. I was thinking of mounting to an external mount: M.2 NVME SSD enclosure adapter USB C 3.1 Gen 2 at 10 Gbps, 6 Gbps SATA PCIe. So this SSD mounted externally to this enclosure. I'd be running simulations that can take a few days. Does anything scream "no don't do it" to you?
I installed Centos on a USB 3 key. It took ~10x longer to install on it than on a USB 2 spinning disk. Running felt about the same as on the spinning disk. I eventually went with an internal SATA 3 SSD (a $10 bargain basement deal from Microcenter) which was faster than both and entirely acceptable.
My home area is on a remote server.
Likes member 428835
Probably; you may need to update the BIOS on an old machine.
Yes, particularly if the laptop does not have a USB 3 port.
This. You will get much better performance from a bog-standard SATA internal SSD (which is all an old laptop is likely to support) than an external M2 device over USB, and the setup will also be cheaper and more convenient.
I've just realized you said plug it into the motherboard. Does this laptop have an M2 port on the mobo? It is not that old then, and an internally mounted M2 drive will blow anything external out of the water.
If it doesn't have an M2 mobo you will instead be replacing the existing spinner installed in the SATA drive bay.
Likes FactChecker
pbuk said:
Probably; you may need to update the BIOS on an old machine.Yes, particularly if the laptop does not have a USB 3 port.This. You will get much better performance from a bog-standard SATA internal SSD (which is all an old laptop is likely to support) than an external M2 device over USB, and the setup will also be cheaper and more convenient.
The laptop is a mac, which I don't like tinkering with. I was going to add another SSD to the mobo of a desktop, but then I have to remote access. I think the better option might be to plug an external SSD into the mac and let it do its thing. Would the external SSD run substantially slower when going through a USB-c, thunderbolt, or USB3.0?
Maybe.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 30 ·
