Ultrasonic crack detection in glass bottles
The discussion focuses on ultrasonic crack detection methodologies for glass bottles in a bottling plant. The standard vision and backlight approach is noted as challenging due to the bottle's shape, which complicates detection. An alternative method involves using ultrasonic techniques to detect changes in resonate frequency caused by cracks. The proposed technique includes tapping the bottle to analyze the sound produced, where a dull sound indicates a fracture, and the presence of harmonics can be used to assess the bottle's integrity.
  • Understanding of ultrasonic testing principles
  • Familiarity with sound frequency analysis
  • Knowledge of vision inspection systems
  • Experience with mechanical design for automated systems
  • Research ultrasonic crack detection techniques in glass materials
  • Learn about sound frequency analysis and its applications in defect detection
  • Explore vision inspection systems for complex geometries
  • Investigate mechanical design for automated bottle inspection systems
Engineers and technicians in the bottling industry, quality control specialists, and researchers focused on non-destructive testing methods for glass materials.
dc878787
I'm working on a project for a bottling plant that is trying to make a vision-based machine to detect cracked glass bottles before they attempt to fill them.
It seems that the vision & backlight approach is the standard way to do this in the industry, but the shape of the bottle in this application makes this a tricky/expensive machine.
I'm wondering if anyone has any experience with some type of ultrasonic crack detection methodology? I'm just going on a hunch here, but I think that at least some cracks should change the resonate frequency of a bottle enough to detect the change..
Can you provide a pic of the bottle's shape?
Shows a lot of flaws --- laser plus beam expander (cylindrical lens in front of laser level light source) and a diode array looking for reflections, or reduced transmission.
Support a bottle by one point, say by the cap, then tap the bottle so it rings like a bell at a fundamental frequency. If there is a fracture in a bottle it will sound dull and generate a short burst of harmonics of the fundamental frequency. I expect the harmonics generated to be even because the crack opens for part of the cycle but is closed on the other half cycle. With a good bottle the ringing will continue for longer at the fundamental frequency and there will be less 2'nd harmonic generated.
