Where Should a 55kg Mass Be Placed to Balance a Suspended 25kg Beam?
  • Thread starter Thread starter unique_pavadrin
    Beam Torque
The discussion centers on balancing a 25kg beam suspended 1.3m from one end by placing a 55kg mass at the correct position. The beam's length is 2.7m, and its center of mass is at 1.35m. To achieve balance, the torque equations must be applied, leading to the conclusion that the 55kg mass should be placed 0.05m to the left of the pivot point. This calculation involves equating the clockwise and anticlockwise torques around the pivot.
  • Understanding of torque and its calculation using the formula τ = rF⊥
  • Knowledge of center of mass concepts for uniform beams
  • Familiarity with equilibrium conditions in physics
  • Basic algebra skills for manipulating equations
  • Study the principles of static equilibrium in physics
  • Learn about torque calculations in various contexts
  • Explore the concept of center of mass in different shapes and materials
  • Practice problems involving balancing forces and torques
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to explain concepts of torque and balance in practical scenarios.
unique_pavadrin
A beam of mass 25kg is suspended from a point 1.3m in from one side. Where must a 55kg mass be placed for the beam to be balanced?
\tau = rF_ \bot
This problem has me totally confused. I no that the center of mass of the beam is at 1.35m (assuming that it is uniform). Since the beam is suspended off the center of mass the 55kg mass needs to placed predominantly on the 1.3m section of the beam so that the center of mass of the combined beam and mass is at 1.3m mark. However I am not sure on how to calculate this, I am assuming that a torque (?) calculation maybe required, however I'm not sure on how to apply.
Many thanks for any suggestions and help
unique_pavadrin
I assume that 1.3m is the middle of the beam. I also assume that that is where the beam is suspended. One side is not suspended while the other is? If you put on the suspended side the beam falls while if you put it on the unsuspended side then the beam will remain still but not balanced. I believe that if the weight is put with the mass of the beam (in the middle) then it will still be balanced.
I think you missed out the part that the length of the beam is 2.7m. Unless youre doing a different question to the one I am thinking.
Leftward torque (or some call it moment) = Rightward moment
for the beam to be balanced.To find torque, F = perpendicular distance * weight
Assuming the beam is uniform,
You know the torque on one side (the side that the weight of the beam is acting on), so use it to find the perpendicular distance of the weight on the other side
thanks for the replies
sorry i forgot to mention that the beam is 2.7 m, so it is not suspended from the center
saplingg I'm an not too sure what you mean, sorry
Take where the beam is suspended as your pivot point. For the beam to balance, the sum of the torque around that point must be zero (this is what saplingg was getting at). There are two forces here, each providing torque. Use the equation you had in your original post.
okay thanks for that hage567
here is my working as i understand the problem:
<br /> \begin{array}{l}<br /> \sum \tau _{clockwise} = \sum \tau _{anticlockwise} \\ <br /> \sum \tau = 0 \\ <br /> \tau = rF_ \bot \\ <br /> \tau _{righthandside} = 1.4\left( {\frac{{25}}{{2.7}} \times 1.4} \right)\left( {9.8} \right) = 177.8518\,N\,m \\ <br /> \tau _{lefthandside} = 1.3\left( {\frac{{25}}{{2.7}} \times 1.3} \right)\left( {9.8} \right) = 153.3518 \\ <br /> \sum \tau = \tau _{righthandside} - \tau _{lefthandside} - x \\ <br /> x = \tau _{righthandside} - \tau _{lefthandside} = 24.5 \\ <br /> \tau = rF_ \bot \\ <br /> r = \frac{\tau }{{F_ \bot }} \\ <br /> F_ \bot = 50\left( {9.8} \right) = \\ <br /> r = \frac{\tau }{{F_ \bot }} = \frac{{24.5}}{{490}} = 0.05\,m \\ <br /> \end{array}<br />
from the above calculations the mass needs to be placed 0.05 m to the left hand side of the pivot point. is this correct?
thanks
I don't understand the (25/2.7 x 1.4) or the (25/2.7 x 1.3). Are you trying to take into account the mass of the beam at these points? I don't think you have to do that, if it is considered to be uniform.
Think of it this way: you want to solve for r_m let's say. r_m is the distance from the pivot point to the 55 kg mass. Specify the centre of mass of the beam from the pivot point. That way, you can just set up (r_m)(F_m)=(r_b)(F_b). I think this is what you're basically doing, but you're making it too complicated.
okay thanks hage567 ill look into it and see if i understand it
thank you
