Uncertainty and the speed of light?
The discussion centers on the implications of the Heisenberg Uncertainty Principle regarding the speed and properties of photons. Participants clarify that while the uncertainty principle applies to individual particles, it is often misunderstood as only relevant to ensembles. The principle states that the product of uncertainties in position and momentum (σx σp ≥ ħ/2) holds true even for single particles, including photons, which can have precise momentum but cannot be localized without violating the principle. The conversation emphasizes the distinction between individual measurements and statistical distributions in quantum mechanics.
  • Understanding of the Heisenberg Uncertainty Principle
  • Familiarity with quantum mechanics terminology
  • Knowledge of probability distributions in physics
  • Basic grasp of photon properties and behavior
  • Study the mathematical formulation of the Heisenberg Uncertainty Principle
  • Explore the implications of quantum mechanics on particle localization
  • Research the behavior of massless particles in quantum physics
  • Examine case studies on the measurement of position and momentum in quantum systems
Physicists, students of quantum mechanics, and anyone interested in the foundational principles of particle behavior and measurement in quantum physics.
Sandeep T S
By Uncertainty Principle speed of a particle cannot be constant. then speed of a single photon not?
Science news on Phys.org
No. I am not sure how you came up with this, so I don’t know how to address it.
According to uncertainty principle it's impossible to know the position and the momentum of a particle exactly simultaneously. The product of the uncertainties is >
ħ/2. If you would exactly know one of them, the uncertainty in the other must be infinite, which isn't possible. (If you detect a particle at all, you must have some idea where it is).
For particles not moving at the speed of light, the speed depends on the momentum, and if you knew the exact speed, you would know the exact momentum, and you would know nothing about the position at all, which is impossible.
However photons can have different momenta, even if they all move at the same speed, so there is no problem.
That is untrue. It is a statement about ensembles of systems, not about individual particles.
If there was a way to determine the position and momentum of a single particle with arbitrary precision, it would violate it for an ensemble as well. Just repeat.
In a statement like σx σp >= ħ/2 we're talking about a probability distribution for the position and momentum of a single particle.
I can measure the position of a particle with arbitrary precision and I can measure the momentum of a particle with arbitrary position, but this does not allow me to do the same for an ensemble. When I perform my arbitrarily precise measurements on each member of the ensemble, I will find that the results are distributed according to the uncertainty principle. As an extreme example, I can first measure the momentum of every particle in the ensemble and then discard those whose momentum does not fall in a specified and arbitrarily narrow range; this is a preparation procedure for an ensemble of particles with known momentum. Now nothing stops me from measuring their position; but I will find a spread of position values consistent with the uncertainty principle.
Talking about the probability distribution of a single measurement is like talking about the probability distribution of a single sample. Analogously, when I state that a tossed coin is biased to come up heads 60% of the time, I'm not saying anything about anyone toss, I'm making a claim about the ratio of heads to tails in a hypothetical ensemble of identically prepared coins.
But you're assuming in your example that the uncertainty principle applies to each particle. @willem2, I believe, is saying if the uncertainty principle doesn't apply to a single particle, as Vanadium implied, then you can determine the momentum and position of the particle to arbitrary precision at the same time. So to repeat your example, do this for a bunch of particles, discarding the ones that don't fall in the arbitrarily narrow ranges of position and momentum at the same time. You now know the momentum and position of the ensemble precisely.
You could also repeat the measurement multiple times with the same coin, and the underlying probability distribution will emerge.
From my understanding, the uncertainty principle does apply to a single particle. If the particle is in some state, you can calculate ##\Delta x## and ##\Delta p## based on that state, and the product of those two quantities will be greater than ##\hbar/2##. It has nothing to do with making measurements. It has to do with the waviness of nature at the quantum level.
My understanding is that ##\Delta x## is a measure of the spread of position measurements on an ensemble of particles all in that state. Similarly, ##\Delta p## is the spread of momentum measurements made on a similarly prepared ensemble. Their product is a property of the state (and thus the ensemble).
(I'm essentially agreeing with the post by @Nugatory above.)
That is not how I read his comment. To me it seems that he is talking about arbitrarily high precision for the position and momentum of a single particle.
Simultaneously?
vela said:
Simultaneously?
Yes
A photon can have a fairly precise momentum (to the extent that you can accurately determine its wavelength), but it can't be "localized" in a way that's compatible with the usual formulation of the Heisenberg Uncertainty Principle. The principle does apply, but the mathematics are different for massless particles. Nice summary here: https://arxiv.org/abs/1205.0516
  • · Replies 19 ·
  • · Replies 23 ·
