Uncertainty principle and an electron
6 replies · 3K views
thenewbosco
question is:
use the uncertainty principle to show that if an electron were confined inside and atomic nucleus, diameter of [tex]2 x 10^{-15}m[/tex], it would have to be moving relativistically i.e. more than 0.1c.
what i have done is the following:
[tex]\Delta x \Delta p = \frac{\hbar}{2}[/tex]
then i set [tex]\Delta x = 2 x 10^{-15}[/tex] and solved for [tex]\Delta p[/tex]
from this i don't know how to solve for the speed, i considered replacing [tex]\Delta p[/tex] with [tex]\gamma m\Delta v[/tex] but this doesn't seem to work with the gamma in there.
what is a better way to solve this?
thanks
Must you actually solve for the speed? [it can be done, since you can write [tex]\gamma[/tex] in terms of v... but do you need to?]
While v>0.1c may characterize "relativistic", is there another way?
this was the hint that was given, that relativistic speeds were > 0.1c, but if you could give me a hint on comparing something else it would be appreciated.
i don't know of anything similar, but gamma will be less than or equal to 1. is this close to the right track?
Find [itex]\frac{\gamma v}{c}[/itex] (= [itex]\frac{\Delta p}{mc}[/itex])
Squre both sides and solve for v/c.
v < c
Therefore, gamma > 1
