Unconnected wall wart power consumption
41 replies · 10K views
noname12345
TL;DR
How much power (if any) does a plugged in but unconnected wall wart (transformer/rectifier) consume?
Hi.
Not homework. I left that behind me 40yrs ago:)
Eg. I have a phone charger labelled as:
Input: 100-240V~50/60Hz 0.3A.
____________
Output: 5V - - - - - - 2.0A
So, how much does it cost me if I forget to unplug it between uses?
Thanks.
russ_watters said:
No way to know for sure. I'd check with a wattmeter if you have one.
Russ is right. We would need more details.
However, 10 years ago those things were terrible. At one point, they were projected to become one of the major uses of electricity. But before that happened, the manufacturers made new ones much more efficient so that they don't use much power plugged in but disconnected.
You can get an idea by just putting your hand on the plugged in wall wart. If it doesn't feel very warm to your touch, it is not consuming much energy.
Reply
This isn't about either this one specific wallwart; but rather a desire to understand the principles involved.
What are the limitations on knowing? Have multimeter, can measure.
If the input was DC, then with no load on the output, the steady state current draw would simply be the input voltage / the primary coil resistance; and from that power consumption.
With AC, thing are complicated by induction effects, but with an open circuit secondary coil not so complicated?
If it can be measured, can it not be calculated?
What more details?
It can't be calculated because they aren't necessarily simple circuits; they may have control and communications circuitry in them as well.
Anyway, I just tested four different phone chargers with a Kill-A-Watt that reads out in tenths of a Watt, and all registered zero with no phone plugged in. Charging wattages ranged from 5.8 to 18.2W.
Reply
I've been assuming that any circuitry would be limited to a diode bridge and RC smoothing stage connected on the secondary side and thus open circuit when nothing is connected.
Now you got me wondering who my wall warts are talking to and what they are saying about me :)
That's really intriguing. If your meter is truly capable of measuring down to 1/10th Watt; that implies that the primary coil is being open-circuited when nothing is being charged. (Otherwise, 0.1W @ 240V means the primary coil would have to have a 576kΩ or higher resistance. Or 121kΩ at 110VAC)
But as any control circuitry must inevitably be powered from the mains input (via the transformer&inverter), how would it detect when something was plugged in, so that it could close a switch in the primary coil?
I know some of the latest high power "fast" chargers, do have some Constant Current circuitry in them and detect when the battery voltage has reached its "full charge" level in order to stop the charging; but the ones I'm talking about are nowhere near that sophisticated.
Don't worry, they are probably just talking to your phone and each other.
Agreed. So, whatever control they have runs on less than 0.5 watts (assuming the meter is accurate).
That would surprise me -- I assumed all the charging circuitry/logic was in the phone.
btw, if my phone's mah rating is at 5V (doubtful), it would be 20 W-h. If it were to be charged fully once a day, that's 7.3 kWh per year or at my electric rate, about $1.24.
Many modern wall warts have SMPS PS which can sleep at very low power consumption. They wake up occasionally to check if anything has discharged their output, or have some sort of interrupt circuit to wake them up. 100uA is really a lot for a MOS circuit to detect activity. I think it's the only way to get low standby power. AFAIK, no one would turn a 60Hz transformer on/off.
Reply
Do you have any of the old adapters that are just a transformer?
If there is such a thing, I don't own one. The oldest of the ones I tested are at most probably 5 years old.
Old folks have big boxes of those, with various voltage, wattage and connectors (but never the combination they need).
Edit: Oh, and I forgot polarity.
Reply
  • Haha
  • Love
Are we still talking about USB cell phone chargers? Because if we're going beyond that, yeah, I can provide test results from a bunch of them...
There are existing energy efficiency standards for these things and more on the way. One little wall wart may not seem significant, but what if everyone in your country has 10-20 of them plugged in all the time. That adds up to lots of wasted energy if they are still old school designs.
Here's a summary from a PS manufacturer. Since no one pays me for this anymore, I'm not really going to read the details, you can. But it looks like a standby power consumption limit of 100mW is a common requirement.
The days of 50/60Hz transformers are practically history.
Reply
Correct.
If the wall wart contains a mains frequency transformer, then the magnetising current will continue to flow when there is no output current. But the magnetising current is in quadrature with the voltage, so it circulates and does not constitute real power. Expect magnetising currents between 0.25% and 5% of the full load current.
While the transformer is connected you must pay for the heating of the transformer by core hysteresis and the resistive losses in the primary winding only. But those losses will not be high. Expect a core loss current of 1% of the full load current.
If the circuit includes a regulator then you can expect a maximum of about 20 mA at 12 V = 240 mW. That holds also for switching converters, that have no mains transformer.
Wouldn't that mean it couldn't be charged if powered off; and letting your battery get completely flat would effectively brick it?
Indeed. I was wandering around my house looking at all the devices that use wall warts and are designed to be plugged in permanently:
Including: cordless vac; shavers; toothbrushes; hairclippers; PVRs; TV sticks; cordless phones; wifi hub; wifi extenders; LED desk lamp; LED monitors; alarm clocks; clock display/timers on conventional & microwave ovens; video games.
And then there are all the transient ones that often get left plugged in when not in use: phone chargers; tablet chargers; laptop chargers; camera battery charger; satnav charger; LED torch charger; car battery charger; ebike charger; cordless tools(screw driver, drill, dremel, etc.).
And several of them are well old -- 20yrs+ in a few cases -- so almost certainly linear tranformers.
It just got me wondering how much all that convenience is costing per annum.
Baluncore said:
Correct.
Thanks. That reassures me about most of the modern devices with SMPSs.
I still need to understand the costs of the older devices with mains frequency transformers. My understanding of
Baluncore said:
But the magnetising current is in quadrature with the voltage, so it circulates and does not constitute real power..
leaves something to be desired.
As far as I know, "quadrature" simply means the secondary is 90° out of phase from the primary; so I don't understand how that translates into "does not constitute real power"?
The power is the product of volts and in-phase amps.
If there is a 90° phase shift of current to voltage, the energy flows backwards and forwards = circulates. It is called Volts Amps Reactive, VAR, and does no real work.
Think of the integral of Sin(x) * Cos(x);
https://en.wikipedia.org/wiki/AC_power#Reactive_power
Okay. I read the wiki article (and several others linked from it); this is what I think I got from it:
Because the primary coil is reactive as well as resistive, the current flow lags the (AC) voltage rise and fall. And because both voltage and current keep reversing, the net current flow over a cycle is 0. Thus, the reactive nature of the coil effectively negates the resistance of the coil and no net power is drawn from the source, if the secondary coil is open and we ignore parasitic losses (eddy currents in the core).
Did I understand?
The concept of rise and fall confuses it. Think simply of phase shift.
The reactive current flow lags voltage by 90°, the resistive current flows in phase. The sum of those two gives the current an intermediate phase that can be resolved into a resistive and a reactive component.
Not quite, if voltage and resistive current change in phase together, the product would always have the same sign, so real power would always flow in the same direction.
Since the product of voltage and reactive current keeps reversing, the direction of energy flow alternates and there is no net energy flow, so no real power.
Buk said:
Thus, the reactive nature of the coil effectively negates the resistance of the coil ...
The reactive magnetising current still generates heat in the resistance of the primary. With no secondary load, the phase of the current in the primary is not quite 90°, because of the primary winding series resistance.
No, not if "powered off" doesn't really mean powered off.
Remember, USB is primarily a data transfer interface, and a 15 year old computer isn't going to have a database of phone/battery specs in it to regulate their charging.
Ok, re-reading your OP, I see it was a generic wall wart description even though the example was a phone charger. The variation is likely vast. I'll test a few non phone chargers tonight.
I will say that I have a whole-house meter and my minimum usage is about 250 watts. This includes a few devices that are truly powered on, such my network system and dvr.
Ooo-kay. But... :)
Reactance results from self-inductance. And inductance is due to a change (ie. rise or fall) of voltage...
I think this (from: https://en.wikipedia.org/wiki/Electrical_reactance) explains what you are saying:
"Reactance is similar to electric resistance in this respect, but differs in that reactance does not lead to dissipation of electrical energy as heat. Instead, energy is stored in the reactance, and later returned to the circuit whereas a resistance continuously loses energy."
So, a mains frequency transformer's primary winding will always consume power due to its resistance, regardless of whether the secondary winding is drawing current.
Your OP did not put a time limit on devices. I had a wall wart for my first laptop circa 1989. Things were much different back then.
Here's a longer story from Wikipedia. It echos my simple advice. Just put your hand on suspected devices. If its not hot, it is efficient. But efficiency is in the eye of the beholder. What number means "efficient" to you?
https://en.wikipedia.org/wiki/AC_adapter#Efficiency
The issue of inefficiency of some power supplies has become well known, with U.S. president George W. Bush referring in 2001 to such devices as "Energy Vampires".[5] Legislation is being enacted in the EU and a number of U.S. states, to reduce the level of energy wasted by some of these devices. Such initiatives include standby power and the One Watt Initiative.
But others[who?] have argued that these inefficient devices are low-powered, e.g., devices that are used for small battery chargers, so even if they have a low efficiency, the amount of energy they waste is less than 1% of household consumption of electric energy.[citation needed]
Considering the total efficiency of power supplies for small electronic equipment, the older mains-frequency linear transformer-based power supply was found in a 2002 report to have efficiencies from 20–75%, and have considerable energy loss even when powered up but not supplying power. Switched-mode power supplies (SMPSs) are much more efficient; a good design can be 80–90% efficient, and is also much smaller and lighter. In 2002 most external plug-in "wall wart" power adapters commonly used for low-power consumer electronics devices were of linear design, as well as supplies built into some equipment.
External supplies are usually left plugged in even when not in use, and consume from a few watts to 35 watts of power in that state. The report concluded that about 32 billion kilowatt-hours (kWh) per year, about 1% of total electrical energy consumption, could be saved in the United States by replacing all linear power supplies (average efficiency 40–50%) with advanced switching designs (efficiency 80–90%), by replacing older switching supplies (efficiencies of less than 70%) with advanced designs (efficiency of at least 80%), and by reducing standby consumption of supplies to not more than 1 watt.[6]
Since the report was published, SMPSs have indeed replaced linear supplies to a great extent, even in wall warts. The 2002 report estimated that 6% of electrical energy used in the U.S. "flows through" power supplies (not counting only the wall warts). The website where the report was published said in 2010 that despite the spread of SMPSs, "today's power supplies consume at least 2% of all U.S. electricity production. More efficient power supply designs could cut that usage in half".[7]
Since wasted electrical energy is released as heat, an inefficient power supply is hot to the touch, as is one that wastes power without an electrical load. This waste heat is itself a problem in warm weather, since it may require additional air conditioning to prevent overheating, and even to remove the unwanted heat from large supplies.
Reply
Hm. If the battery is flat. It's off!
And a 15y/o computer is neither a wall wart nor a fast charger.
And USB plugs used for charging often (if not always) only have the power pins connected. No communication is possible.
Main draws in my house -- in roughly the order of consumption most to least -- are the electric kettle, electric oven, dishwasher, washing machine, two freezers and fridge. But all of those are high but intermittent power draw. Ie only when in use.
It's all the (20+) devices that are ostensibly off but none-the-less drawing standby current 24 hrs a day that add up I think.
I'd love to see the results of your testing of none-phone stuff. Though I think I am going to purchase a power meter, if I can find one that explicitly states it is accurate at very low power draw and not too expensive.
You got me walking round the house putting my hands on all the devices trying to detect heat :)
So far, the only one that is detectably warn to touch is my ancient rechargeable shaver. May be time for a new one.
Reply
Buk said:
Ooo-kay. But... :)
No, a rising or falling current, di/dt. For an inductor; V = L * di/dt.
Inductance has a positive reactance, capacitance has a negative reactance.
I feel like we're talking in circles. I just powered-off my pone, then plugged it into a charger. The screen lit up and an animated counter of the charge status appeared. So clearly it has some circuitry active even when powered off. Presumably even if the battery is completely dead this circuitry will still activate when the phone is plugged in, to control the charging and display the status.
Agreed; variety. Note though, that google tells me iphones require communication (identification) to work with a charger and will refuse to charge if they don't get it:
https://www.ifixit.com/Answers/View/418299/iPhone+6+will+not+charge+with+certain+chargers
Anyway, here's some results:
  • Microwave: 3.3W
  • Weather Station: 0.5W
  • Shark Cordless Vac: 6.2W. Charger only: 0
  • Receive-only DVR: On: 20.7W. Off: 20.7W
  • Network printer on: 9.7W. Standby: 5.2W
  • Multi-voltage DC PSU: 0W
The cable box/DVR is the most annoying. If left on all the time, that's about $31 a year. The one I tested I keep off from a power strip except when using it a few hours a week.
Reply
