Understanding a Thermo Diffusion Equation Problem: A Comparison of Solutions
  • Thread starter Thread starter Quadruple Bypass
    Thermo
Quadruple Bypass
im given the equation:
k d[tex]^{2}[/tex]T/dx[tex]^{2}[/tex] = 0 over 0 < x < L = 0.4
with T(0)=T and -k dT(L)/dx = h(T(L)-Tinf)
i tried to solve it and i got
T(x) = (-h(T(L)-Tinf)x)*(1/k)
the book gives
T(x) = ( (k+h(L-x))T+h*x*Tinf)*(1/ (k+h*L) )
i don't understand what went wrong... help!
If you plug x = 0 into your expression, you'll find you get T(0) = 0, which is not the boundary condition you're given. You want T(0) = T.
Solving the ODE gives you T(x) = Ax + B. In your solution you appear to have dropped the B term and only solved for A. Keeping B and solving for it should fix the problem.
thanks i don't know why that happened. that just adds a +T after my original solution. i still don't understand where they got the '(k+h*L)' from...
Okay, I see what the other step they did is. Your condition on the derivate of T is defined in terms of T(L), so you get as your solution
[tex]T(x) = -\frac{h}{k}(T(L) - T_{\infty})x + T[/tex]
So, at x = L, you have
[tex]T(L) = -\frac{h}{k}(T(L) - T_{\infty})L + T[/tex]
so you need to solve for T(L). Plugging that back into your original expression should (hopefully) get you the book's solution.
