Understanding Acceleration Direction in a Pendulum Swing
4 replies · 15K views · last reply
ScullyX51
To understand that the direction of acceleration is in the direction of the change of the velocity, which is unrelated to the direction of the velocity.
The pendulum shown makes a full swing from -pi/4 to + pi/4. Ignore friction and assume that the string is massless. The eight labeled arrows represent directions to be referred to when answering the following questions.
What is the direction of vector A when the pendulum is at position 1?
What is the direction of vector A at the moment the pendulum passes position 2?What is the direction of vector A when the pendulum reaches position 3?
I have no idea what equations I should be using here...I am very stuck and could use some hints to steer me in the right direction.
All I know so far is that the acceleration is equal to the instantaneous rate of change in velocity.
  • Diagram of a pendulum swinging from a ceiling, with bobs labeled 1, 2 and 3 at the left extreme, bottom and right extreme, angles of pi/4 marked on each side, and a ring of eight labeled arrows A through H pointing in compass-like directions.
Hi ScullyX51! :smile:
ScullyX51 said:
What is the direction of vector A …
I'm really confused …
is "vector A" the A in the picture, or is it the acceleration? :confused:
yes. I was very confused by that as well...but I am pretty sure vector a is referring to acceleration.
ok … then the question is asking where the acceleration is when something moves in a circle.
You can work this out using r and θ, or i and j, or just by drawing a little triangle where two sides are the velocities at angles θ and θ + dθ, and the third side is the change in velocity. :smile:
