Understanding Acceleration Direction in a Pendulum Swing
  • Thread starter Thread starter ScullyX51
    Pendulum Vectors
The discussion revolves around understanding the direction of acceleration in the context of a pendulum swing, specifically as it moves through various positions from -π/4 to +π/4. The original poster expresses confusion regarding the relationship between acceleration and velocity, particularly in circular motion.
  • Participants explore the definition of "vector A" and its relation to acceleration. There are discussions about using geometric representations to analyze the acceleration direction in circular motion.
Some participants have provided insights into interpreting the problem, suggesting methods to visualize the acceleration direction. However, there is no explicit consensus on the approach to take, and confusion remains regarding the terminology used in the problem statement.
The original poster indicates a lack of clarity on applicable equations and expresses feeling stuck, which may influence the direction of the discussion.
ScullyX51
To understand that the direction of acceleration is in the direction of the change of the velocity, which is unrelated to the direction of the velocity.
The pendulum shown makes a full swing from -pi/4 to + pi/4. Ignore friction and assume that the string is massless. The eight labeled arrows represent directions to be referred to when answering the following questions.
What is the direction of vector A when the pendulum is at position 1?
What is the direction of vector A at the moment the pendulum passes position 2?What is the direction of vector A when the pendulum reaches position 3?
I have no idea what equations I should be using here...I am very stuck and could use some hints to steer me in the right direction.
All I know so far is that the acceleration is equal to the instantaneous rate of change in velocity.
Hi ScullyX51! :smile:
ScullyX51 said:
What is the direction of vector A …
I'm really confused …
is "vector A" the A in the picture, or is it the acceleration? :confused:
yes. I was very confused by that as well...but I am pretty sure vector a is referring to acceleration.
ok … then the question is asking where the acceleration is when something moves in a circle.
You can work this out using r and θ, or i and j, or just by drawing a little triangle where two sides are the velocities at angles θ and θ + dθ, and the third side is the change in velocity. :smile:
Thank you! :smile:
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 16 ·
