Understanding Barandes' microscopic theory of causality
456 replies · 47K views
iste said:
Again, the point is that in other measurement bases, the stochastic-quantum correspondence results in generalized stochastic processes that are difficult to interpret in terms of some freely-evolving system imo.
The classical configuration space is not inherently a measurement basis. It is a space of definite arrangements the system can be in. You are implicitly smuggling in an instrumentalist interpretation by calling it a measurement basis. As I have already explained: When the sample space is a space of measurement outcomes, that is a straightforwardly instrumentalist use of this formalism. When the sample space is instead a classical configuration space, the formalism gives us a microphysical conceptualization for kinematics and dynamics.
Sure, it may be plausible in a certain case; but if that is not general, then to me it is not coherent to use this formulation for a physical interpretation.
I don't understand "to me it is not coherent". By "to me it is not coherent", do you mean you do not personally understand the formalism as a means of interpreting quantum theory as a theory of unistochasatic processes on a microphysical level? Or do you mean you find it personally distasteful that the the formalism can have other purposes?
I mean "meant" for something else in the sense that I believe the indivisible stochastic process is a model that predicts the states of a system probabilistically  if you were to measure it.
By "I believe" are you saying it is your own personal conviction that sample spaces should be limited to measurement outcomes, as opposed to microphysical configurations independent of measurement?
I don't think classical configurations are an issue because its completely coherent to say what is being described is predictions about configurations of a system  if you were to measure it. At the same time, the reason why I think there are cases which are very ambiguous as to interpretation has nothing specific to do with configurations. I can envision a physical system described in terms of configuration space that has similar properties to spin in terms of the outcomes of measurements being inextricably entwined to the measurement interaction. Spin itself even conceivably can be given a configuration space.
You can build a sample space of measurement outcomes from a configuration space, but configuration space itself is not inherently a sample space of measurement outcomes. You are bringing in your personal insistence limiting the formalism to measurement outcomes but it is still not clear why other than it is "incoherent to you" to do otherwise.
[edit] - Consistent histories as presented by Griffiths is also a stochastic, realist, measurement-independent interpretation, and uses sample spaces in the formalism (see this chapter from his book). Do you also believe this is incoherent?
Morbert said:
Re/ Locality: The formalism should always strictly adhere to the principle of causal locality laid out in the new prospects paper. If this work brings tension with locality, it would be a different notion of locality.
Yes, it's a different notion of locality. "Causal locality" as defined in section VII of Barandes' paper means that, for a system composed of two parts that remain spacelike-separated (no local interaction), conditional probabilities factorize. In Cavalcanti's work, locality is equivalent to parameter independence, that is the probability of an (observed) event does not depend on spacelike-separated free choices.
Morbert said:
Re/ Wigner's Friend scenarios: Under this interpretation, a superobservation will not erase events that have already occurred. Ontologically speaking, Wigner's friend still recorded a definite outcome in the lab. Instead what a superobservation does is erase any record of these events, such that the events that occurred do not condition the state of the system after superobservation in any way. The memories Wigner's friend will have after the superobservation (assuming he survives it) will bear no relation to what actually happened in the lab.
I still have doubts about how Barandes' formalism addresses the local friendliness no-go theorem. What @iste and @Fra say about the violation of absoluteness of observed events (AOE) seems correct, but Barandes argues (as you described in the paragraph I quoted) that his interpretation is not relational, while AOE is quite close to relationality/perspectivism.
Lucas.
Fra said:
I you like those, there is also papers like this, which focus not only logical constructions but more inductive or algorithmic constructions, with addresses the emergence.
Law without law: from observer states to physics via algorithmic information theory, Markus P. Mueller​
https://arxiv.org/abs/1712.01826
That paper has an excellent perspective, but as the real thing is bound to be a lot more complex, ever paper so far are more like sort of toy models. So the gap to connecting to SM phenomenology is huge. But there are useful ways of thinking.
Here one can loosely associate subsystem ~ agent, making inferences about its environment, and this whole inteactive game gives emergence of laws. I personally also see common traits with this
Precedence and freedom in quantum physics, Lee Smolin​
Where one can conceptually can associate precedene as beeing mediated by a kind of universal induction (by agents/subsystems).
All these ideas, brought together, and especially if you add Barandes corresondence and some of Rovellis ideas, to me at least, all indicate a common direction. Bot the connection to the logical correspondences, requiest extending them. But I find Barandes unistochastic to be more readily extendable, as it woul be natural to start by relaxting unistochasticy, in order to later recover it.
/Fredrik
Thanks @Fra for these references. I'll check them out! :smile:
Lucas.
Yes, and there is no tension between the non-interventionist account arXiv:2402.16935 and interventionist accounts so long as you are willing to grant that people themselves are fundamentally physical processes.
AOE is not violated, as standalone probabilities are epistemic. At all times, the system has a definite, observer-independent configuration, even if different observers have different information about it.
I have to clarify that the ontological ambiguity with regard to the indivisible stochastic process has nothing to do with configuration space. Neither did I envision the stochastic process in terms of measurement outcomes - my envisioning is counterfactual representation of physical configurations of the system were they to be measured. They have a literal, semantic meaning in terms of physical configurations, but only within the context of performing a measurement.
The formalism means that you can take any Hilbert-space representation of any observable and translate it to a generalized stochastic process that it corresponds to. These stochastic processes do not seem to always have a straightforward unambiguous meaning. For instance, spin or polarization outcomes conceivably don't physically exist until after the measurement interaction and branching takes place. If this is the case, the stochastic process describing the spin for some basis doesn't have a straightforward physical interpretation prior to a measurement interaction occurring. When you have cases like this, I don't see the stochastic-quantum correspondence as a good basis for a physical interpretation. I also suspect that the momentum representation suffers something similar.
You can then still represent the measurement device and physical system separately and model their interaction. But the information carried by the representation of the physical system is only ever the information one could get from measurement; in cases like spin, what this information is about may not even exist until after a measurement interaction has occurred, nonetheless it is represented between measurements and so must he a counterfactual, predictive representation of the configuration of the systems at some time but only if one were to measure it.
To be honest, I have looked up the consistent histories view in the past and I have never gotten to the point of delving deep enough to understand what exactly it is. My issue is the relation of the stochastic-quantum correspondence to physical interpretation when straightforwardly applied in some cases, which is enough to make me doubt its use in general. So my issue is specific to this formulation. I just think that because these generalized stochastic systems actually have a direct correspondence to the orthodox quantum formalism, their interpretation will be (almost) as ambiguous as the orthodox quantum formalism.
My belief is that these indivisible stochastic processes only carry information about the system at different times if it were to be actually measurement; this makes complete sense because empirical access in quantum mechanics is so restricted. It would be the most parsimonious account of orthodox quantum theory that is sufficient to replicate all predictions and can be arbitrarily applied to observables regardless of whether they only emerge within the measurement context or plausibly have a concrete existence between measurements.
Obviously, you can just ignore where there are issues and postulate otherwise (e.g. exiling some observables to the status of emergeables, only giving beable status to observables where it is at least plausible that they have their measured configurations don't depend on the measurement interaction), but that is too cognitively dissonant for me when one considers that the quantum observables behind these emergeables will all have generalized stochastic processes where they are the coordinate as a mathematical fact of the correspondence.
I would say that a formulation that in general only carries information about the physical structure of systems had they been measured is innappropriate to use as a formulation representing information about the physical structure of a system when it is not being measured; it is simply not what the stochastic-quantum correspondence does, which is translate an orthodox quantum theory carrying information about what happens when you make measurements into a stochastic process which is essentially isomorphic to the orthodox measurement statistics but just re-represents them in terms of the classical configurations of the system as it is being measured. In contrast, something like Bohmian mechanics is designed to represent information about systems not only between measurements but such that you can trace out their trajectories; this formulation is designed to do what it says it does, adding something beyond empirically accessible information.
I guess the criticism can only be characterized as aesthetic though in the sense that you can make it coherent by just ignoring certain observables. But to me, that seems ad-hoc when the stochastic-quantum correspondence can give these emergeables a coordinate role, indicating to me that a physical interpretation is not the most parsimonious way of characterizing the information these stochastic processes represent (i.e. your're effectively over-fitting the data). That said, getting rid of the wavefunction is a huge plus for the stochastic-quantum correspondence.
The configuration space provides the kinematics as per the first axiom. As such there is no ambiguity or need for a measurement context. Your concerns at best follow from a rejection of the kinematic axiom. As I have said many times now, you are critiquing something other than what is in literature.
I brought up consistent histories because it uses sample spaces sans measurement contexts. Both it and this formulation can readily use them without implying measurement contexts or counterfactual indefiniteness.
I would like to hone in on this for a moment:
Barandes presents a model of a generalized stochastic system as a tuple of the form ##(\mathcal{C},\mathcal{T},\Gamma,p,\mathcal{A})## where ##\mathcal{C}## is the configuration space. Is your objection that ##\mathcal{C}## is not selected by the formalism, and must be in the initial ingredients? It is true that this project does not seek to identify the one true ##\mathcal{C}## and so a choice of ##\mathcal{C}## amounts to a choice of model, and this formalism treats all models as on equal footing. But i) it would be enormously ambitious to try and identify a unique configuration space. Physical models, whether they are deterministic or stochastic, divisible or indivisible, begin with a choice of state space. And ii) I don't see how this limits configurations to only having meaning "were they to be measured".
I think Barandes's formulation is not limited to the stochastic-quantum correspondence but also incorporates (classical) configuration space as the ontology of the model. If we consider his work as starting from quantum mechanics and arriving at indivisible stochastic processes, I fully agree that nothing exists other than the configuration of systems at measurement times. However, in my opinion, Barandes postulates (i) a configuration space-based ontology, and (ii) a certain kind of stochastic process as the law determining time evolution, and then shows that this model is equivalent to Hilbert space QM. In a way, it is not so different from what happens with Bohmian mechanics.
Lucas.
My criticism is that if you take something like spin and translate it into a generalized stochastic process, you get an evolving physical system sampling configurations with certain probabilities that may not actually make sense ontologically, in which case the interpretation would be wrong and the generalized stochastic formalism must be carrying information about something else instead. There is also an obvious answer as to  why it is about something else instead: the stochastic process corresponds exactly to an orthodox quantum description of a system, and orthodox quantum theory doesn't really tell you anything outside of what happens when you measure something.
I'm not sure that the epistemic nature of probabilities leads to AOE. For example, relational quantum mechanics assumes that probabilities are epistemic, but denies AOE.
Anyway, let's assume you're right and Barandes' formulation/interpretation does not violate AOE, then how does the interpretation address the LF no-go theorem? To reproduce quantum predictions, one of the three assumptions (AOE, non-superdeterminism, locality) must be violated.
Lucas.
Sure, but then you could postulate anything. You can talk about physical systems that don't exist, you can talk about macroeconomics, you can talk about biology, psychology. There are conceivably a huge number of disparate models and systems that may evince behaviors of a quantum system to some degree by virtue of being describable as economic systems. For me, the validity of using the indivisible stochastic process as a physical interpretation is by showing that the indivisible stochastic process a quantum system corresponds to is in fact representing freely-evolving physical process and not some kind of amalgam of a physical system within a measurement context. I think Bohmian mechanics doesn't have to do this because with Bohmian mechanics you can more or less separate the parts of it that corresponds to the information in orthodox quantum mechanic, and the part of it that carries information about the other "hidden variables". There is no ambiguity because these hidden variables are effectively intentionally designed to represent what they represent in a way that is distinct from the orthodox quantum system and so don't risk conflation, imo. Whereas in Barandes' case you are pulling them out of a correspondence to (quantum) systems that people don't really have consensus on in the first place; there is nothing in your ontology which is not isomorphic to the information what you get from measurements, which is risky if there are cases where observables actually directly depend on the measurment interaction. To make your ontology incidentally, or accidentally even, contingent on that is imo a mistake. In the Barandes case it seems to me that if you want to make it explicit that some observables depend explicitly on a measurement interaction, like I believe Bohmian mechanics does, then you might have to kind of ignore aspects of the stochastic-quantum correspondence which are mathematically valid but you don't like because they may not agree with your physical interpretation.
To a certain extent, Bohmian mechanics is a typical realist interpretation. There is a clear distinction between the variables that represent the physical state of a system and the way in which probabilities arise as a result of the impossibility of knowing that complete description. Barandes' interpretation combines both concepts, so that the probabilities of future events depend on the information available about past events. This is a kind of combination of realist and information-based interpretations.
So yes, I think Barandes' interpretation is not without problems (*), but at least it seems to be self-consistent.
(*) I don't like those weird jumps as long as there is coherence between branches.
Lucas.
iste said:
My criticism is that if you take something like spin and translate it into a generalized stochastic process, you get an evolving physical system sampling configurations with certain probabilities that may not actually make sense ontologically in which case the interpretation would be wrong and the generalized stochastic formalism must be carrying information about something else instead. There is also an obvious answer as to  why it is about something else instead: the stochastic process corresponds exactly to an orthodox quantum description of a system, and orthodox quantum theory doesn't really tell you anything outside of what happens when you measure something.
To clarify, I understand "take something like spin and translate it into a generalized stochastic process" in two ways. i) Translate it to a general stochastic system with a configuration space directly constructed from spin labels and ii) Construct a general stochastic system that reproduces all spin statistics of the corresponding quantum theory.
Re/ i) this could be true. My understanding is a classical configuration space can't consist of intrinsic spin configurations. So I can happily grant that: I can happily grant that not all sample spaces can serve as a classical configuration space, and hence cannot be used to construct a general stochastic system. But this isn't implied by the stochastic-quantum correspondence. Instead, the correspondence tells us there is no quantum theory whose empirical content cannot be reproduced by a general stochastic system. E.g. see the next paragraph.
Re/ ii) It is straightforward to construct a general stochastic system that reproduces spin statistics. Barandes touches on it in arXiv:2507.21192. He introduces spin as a dilation-emergeable in a stochastic system with a configuration space of ordinary spatial arrangements. The correspondence guarantees that for any Hilbert space, we can construct a general stochastic system with a classical configuration space that reproduces the statistics of all observables.
Lucas.
I will have to admit my knowledge of the LF no-go theorem is minimal, so my response will be from the hip. From the paper:
In an EWFS, the assumption of AOE implies that, in each run of the experiment—that is, given that Alice has performed measurement x and Bob has performed measurement y on some pair of systems—there exists a well-defined value for the outcome observed by each observer, that is, for a, b, c and d. Formally, this implies that there exists a theoretical joint probability distribution P(abcd∣xy) from which the empirical probability ℘(ab∣xy) can be obtained
The transition map used by Alice and Bob will not have a division event at Charlie's and Debbie's measurement, and so no such joint probability distribution can be constructed. I.e. Once Alice and Bob start to interact with their respective Labs,the configuration of the Lab really can jump across quasiclassical branches. I.e.I.e. their superobservation will suspend the usual, dissipative, thermodynamic time evolution that makes ordinary macroscopic transition maps divisible and quasiclassical. Albert's nightmare is realized during the superobservations. But the labs are nevertheless in a definite configuration after Charlie's and Debbie's measurements, and there will be a standalone probability across lab configurations. It just can't ever be resolved: Alice and Bob can never learn it, and Debbie and Charlie cannot remember it.
But the generalized stochastic process exists! Again, the stochastic-quantum correspondence is fully general and can be applied to fields outside of physics. For me, the question is : "what does the indivisible stochastic process represent in quantum physics?" and that if getting an unambiguous physical interpretation out of it requires ignoring your first point i, then that is like overfitting because it doesn't represent the full generality or domain of applicability of the stochastic-quantum correspondence within quantum physics.
Barandes said:
This paper then states and proves a new theorem that establishes a precise correspondence between any generalized stochastic system and a unitarily evolving quantum system.
Barandes does indeed observe in arXiv:2309.03085 that a stochastic process ##(\chi,\mathcal{T},p,\mathcal{A})## is more general than a generalized stochastic system ##(\mathcal{C},\mathcal{T},\Gamma, p, \mathcal{A})##. But the correspondence he investigates is between generalized stochastic systems and quantum systems. I.e. It's not just that a quantum system can be modeled as a stochastic process, but that it can be modeled as a stochastic process "unfolding in an old-fashioned configuration space based on ordinary notions of probability and ‘indivisible’ stochastic laws". I.e. A generalized stochastic system. And note that such a system doesn't just get you one observable like spin. It gets you all observables.
You, on the other hand, are sketching a correspondence between specific eigenbases of a quantum system, and stochastic processes. This is fine, but you should not be surprised that it does not offer up ontological models. Instead what offers ontological models is the correspondence between quantum systems and generalized stochastic systems.
If you can show a quantum system (one that includes, say, spin states) has no corresponding generalized stochastic system, that would indeed be a killer blow.
[edit] - Tidied up language to be consistent with literature.
@iste One reason this discussion has gone on for so long is I wasn't sure I fully understood your concern. But now I'm pretty sure I do, and so I will start to wind down the conversation on my end unless some new aspect not previously articulated is brought up.
You, on the other hand, are sketching a correspondence between specific eigenbases of a quantum system, and stochastic processes. This is fine, but your should not be surprised that it does not offer up ontological models. Instead what offers ontological models is the correspondence between quantum systems and generalized stochastic systems.
Where does he talk about the even more general stochastic process? In that paper says he changes from the squiggly X to C because you can't define velocities fir a stochastic system. Honestly, you're paying too much attention to the word "configuration" when it doesn't make a difference wrt the mathematical result.
"the most general kind of stochastic process requires only a sample space, an initial probability distribution, and one or more time-dependent random variables, meaning time-indexed families of functions from the sample space to the real numbers. However, stochastic processes defined in this narrow way lack an ingredient that plays the role of a dynamical law. This paper will be concerned with a slightly modified construction that allows the probability distribution itself to vary in time, and that also includes the notion of a dynamical law."
"In defining a stochastic process to serve as such a model, one can take the sample space to be the system’s configuration space C"
Linguistically, "can take" seems subjunctive tense to me.
It doesn't seem like whether you talk about configuration, phase, state space, anything else, makes any difference. If this formulation can be applied to something like psychology, then it shouldn't make a difference. And in a sense it has been applied to psychology because people have used unitary and unistochastic systems to model psychological phenomena.
arXiv:2507.21192v1
Sure, but all these observables in their Hilbert-space representation are coordinates of generalized stochastic processes.
Morbert said:
You, on the other hand, are sketching a correspondence between specific eigenbases of a quantum theory, and stochastic processes
Thats exactly what Barandes does in his example. It should be valid for all observables equally by just doing what he does in reverse. And you can do that because the correspondence is bidirectional.
Yes, which is why I think its not a good way to construct a physical interpretation. Quantum mechanics already has an ambiguous physical ontology. This is just giving it a different representation and pretending it makes quantum mechanics less ambiguous when it in fact directly corresponds to the ambiguous quantum mechanics. Yes, you can probably make an acceptable interpretation. But imo this is ad hoc and does not give an honest reflection of what the generalized stochastic process you extract from a quantum theory is actually about.
Honestly, I'm not, as it is what connects a mathematical result to a physical interpretation. It's what lets you regard a quantum system as a generalized stochastic system with dynamical laws and a microphysical ontology. But I have explained that many times by now.
Yes, that's the point! So Barandes' interpretation addresses LF no-go theorem by rejecting AOE.
I think AOE implies something more radical. If a joint probability distribution cannot be constructed from the perspectives of Alice and Bob, then Charlie and Debbie's measurements are only events relative to them, but not to Alice and Bob.
In a way, Barandes's formulation seems to avoid this relationalism by postulating the existence of a configuration that can jump between different branches.
Lucas.
iste said:
My inclination is that emergeables must be as real as beables. In terms of measurement and the Born rule they seem on equal footing. The only difference is that one isn't explicit in the stochastic process; it seems implicit (e.g. in the averaged dynamics) but equally real property of the world, not just of a measuring device. I haven't seen anywhere to my knowledge Barandes' formulation actually picking some preferred beable perspective on the universe; I believe he has even said his formulation is open about ontology. Surely his dictionary would allow you to take any quantum observable and make it a beable. Position beable where momentum is emergeable. Momentum beable where position is emergent.
Spin is an interesting example. Personally, I think that the outcomes of a spin measurement plausibly may very well be entirely a property of spin "measurements" in the moment rather than outside of the measurement. But I don't actually know, obviously. Just seems plausible to me. But surely, even though Barandes talks about spin as an emergeable from dilation, couldn't you describe or directly translate quantum spin as a beable? If that is the case, what would the stochastic process of the unmeasured universe (the spin part) between measurements represent if spin outcomes really were something that only exists after the measurement interaction. In that case, the spin beable between measurements couldn't be real in general but would have an instrumentalist interpretation. It seems to me that even though cases like position and momentum beables / emergeables can be seen as equally real between measurements arguably (albeit measurements will be disturbing), the formulation doesn't seem able to in and of itself specify what the stochastic process representing something in the universe means if it is plausible that outcomes of spin measurements are created in the moment of measurement. How could that stochastic process mean something outside of measurement if the outcomes being described only turn up after the measurement interaction? But maybe they don't, you tell me.
The pace of the discussion here went on faster than i could keep up, so not sure where to start rejoin. But in short I have a feeling that iste is trying to get an intuitive handle on the configuration spaces and what they can mean it exotic cases(where classical mechanical models breaks down) such as fermion spin states.
I think this is good to contemplate, but my way to handling this would required stepping outside of the basic SQC itself. The the line between reflection and speculation becomes fine IMO.
I have a feeling Morbert tries to stick more cleanly to SQC in the discussion, buy you want to get and understnading of it from your perspective. I symphatise with this.
SQC says there is a GSC and thus a configuration space, that correspondes to fermion dynamics in hilbert space. But what does it mean to understand the configuration space? It's just an mahtmaticla correspodence?
To me such understanding come first when we have a (first principle) the configuration space (and thus beables) from a minimal starting point. A starting point simple enough that noone will need further explanation. Ie we need to explain emergence of the "fermion" configuration space. This is something i can imagine when interpreting the GSC from ABM perspective, but then we are not discussing Baranders paper and its direct speculation. I simply can't offer a good answer without som speculation, so this is where it will have to stop to respect the formum guidlines.
The closes reflection that may be rooted in some issues of Barandes picture is that, I would say the "observer indepedence" of the division events is still dependent of how the total system is divided in subsystems. This is the non-trivial part, where I think the physics hides. If you divide a total system into parts, and insist that that is what you have, you need to ADD information. The division is simply ambigous. But Barandes SQC doesnt worry about that. The correspondence is there for any division. But different divisions describes a different physical system. And when you push this up to the "total universe" and consider a "closed system", you may thinkg that this is objective, but I disagree with that. I think - again via my projections from ABM and IGUS thinking the interal processes and decompositions correspond to "internal processes" of the system. Ie. internal "computations". An IGUS can be imagined to have different substructures, divide memory to entertain complementary data at hte same time, but in a shared mode (implying a generalized uncertainty relation). This is just general comments, without adding specific specualtiosn.
Then it means, different internal reorganisations of a system, although not immediately visible from outside, does make it a different "observer". This is why in my thining AOE does not hold. It hold if you freeze the ambigous division of the whole system. But for me, it is clear that the division into parts carries physical content.
This I think may also create beables from emeargables, via interal reorganisations. After all the "configuration space" is generically ABSTRACT space. It does not necessarily need to have a simple correspondence to a 3D classical mechanicsm model. I view the configuration space, information theoreitcally as a choice of the IGUS encoding.
Barandes SQC does not explain this, and he is also somewhat agnosic of the meaning of the space, just like the meaning of hilbert space is even more obscure. But the GSC is at least classically looking from each inside perspective. But not from the system perspective. So it is a step forware but more work todo? I would only guess that Barandes would both expect and appreciate discussing potential connections to the correspondence. That is how i see its value. It does not immediately solve all the problems. I think he encouraged others to examine what the GSC would mean for various systems in one of his youtube interviews.
I hope it is clear that I am not putting forward any speculation here, I am just hinting general potential directions for sake of reflecting on SQC from different perspectives.
/Fredrik
This stochastic formalism rejects everywhere-divisible dynamics, something Bong et al don't consider. This is perfectly reasonable, given how new this stochastic approach is. But ultimately we can have a conditional probability fail to obtain while any observed event is still "a real single event, and not relative to anything or anyone."
Note that, as mentioned before, the jumping across quasiclassical branches is only induced by powerful superobservers with the ability to suspend relativity and with apparatuses many times the size of the observable universe. In the absence of such godlike beings, jumping is effectively impossible. David Albert doesn't have to worry: We can be confident in our history books as records of stuff that actually happened.
Why does the configuration need to jump between branches? I haven't really been following this topic.
I am not sure what GSC is. Do you mean GSS (generalized stochastic system)?
What Barandes shows is that we can associate any quantum system with a stochastic process unfolding on a classical configuration space of arrangements, and dynamics given by stochastic maps, allowing us to conceptualize a quantum system as such a process. He goes on in other papers to flesh out microphysical ontologies and microphysical causal relations enabled by this association. What iste is pointing out iiuc is that we can instead associated a quantum system with other stochastic processes: Ones for which the sample space does not have a straightforward classical conceptualization beyond measurement outcomes. Iste believes this undermines the former association. I don't. Nor do I take the ontological models enabled by the former as dogmatic metaphysical commitments. It is enough for them to be useful conceptualizations.
Ah! Of course, your "error correction" works well!
If that was the point then I agree with you. This is what i mean with seeing configuration space as "abstract" but still understandablecin terms to classical probability - not classical mechnics.
/Fredrik
I'm not sure I understand what you're trying to say here.
I think this contradicts something mentioned in Bong's article:
"the assumption of AOE implies that, in each run of the experiment (...) there exists a well-defined value for the outcome observed by each observer, that is, for a, b, c and d. Formally, this implies that there exists a theoretical joint probability distribution P(abcd|xy) from which the empirical probability ℘(ab|xy) can be obtained."
Then, according to the authors, the non-existence of a joint probability distribution implies that there is no "well-defined value for the outcome observed by each observer".
I fully agree on that!
Lucas.
Morbert said:
@Sambuco Re/ Wigner's friend:
There's an error preventing me from playing the video from here. Were you pointing out a specific moment?
Lucas.
We were talking about the case of Wigner's friend thought experiments, where a superobserver makes measurements that, in principle, give rise to interference between quasiclassical branches.
Lucas.
"the assumption of AOE implies that, in each run of the experiment (...) there exists a well-defined value for the outcome observed by each observer, that is, for a, b, c and d. Formally, this implies that there exists a theoretical joint probability distribution P(abcd|xy) from which the empirical probability ℘(ab|xy) can be obtained."well-defined value for the outcome observed by each observer".
I don't see how the bit in bold is true if dynamics are non-Markovian. [edit] - I.e.:
AOE + Markovian dynamics = joint probability exists
no AOE + Markovian dynamics = joint probability doesn't exist
AOE + non-Markovian dynamics = joint probability doesn't exist
It's not too important. At 2:58:01 he remarks on Wigner's friend scenarios. Even if a Wigner superobserver uses a stochastic map with no division events, Wigner's friend will still be in a definite configuration. The link is youtube<dot>com/watch?v=JsmX3YxiUj0&t=10681s
